Old 12-13-2011, 05:55 PM   #1
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
Default Help With Diagnostics Log
Hey i keep getting missfire in cylinder 3, and joulting when under WOT. The car seems to not want to accelerate in joulting movement. I tried using fule line cleaner with no luck and also swapped 1st and 3rd ignition coil, they are fine what to do next? I dont even know where to start. I see my boost is peaking at about 10 though, im running 93 map with 94 octane and the weather was + 8 with next to no humidity.
https://docs.google.com/spreadsheet/...XI1NGp5TlY1WEE
its a stage 1 with just a bov as a mod, rest is stock. This was the 3rd gear pull
TheEugeneKam is offline   Reply With Quote
Old 12-14-2011, 02:03 AM   #2
snoopy_sti
Member#: 164942
2015 Porsche Cayman
I think I would go back to the stock BOV, your getting no boost at all. I am not expert but maybe that BOV is blowing off all your boost.
snoopy_sti is offline   Reply With Quote
Old 12-14-2011, 02:40 AM   #3
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
Yeah im thinking that the spring cant handle the load, ill try to find the stock and see if that changes anything. Its always cylinder 3 though so thats my big concern. Just wondering if crappy fuel injector can cause a drop in boost. Or could i have a leak somewhere in the system?
EDIT: I looked over all the data again and as far as i can tell my A/f is fine, fine knock learning is okay, dam is okay, feedback is alright. I am not sure what the correct value is for the waste gate duty, but its seems pretty consistent so i think it should be okay. My boost on the other hand is terrible. About only 60% of what should be made. I will install the stock DV instead of this crappy ass BOV and see if that changes anything, I shall update.
Old 12-14-2011, 10:26 AM   #4
Cobb Tuning
Member#: 4803
I would put the stock BPV back on with a new gasket. How long has it been since you reflashed the map or reset the ECU since this log?
Generally, the initial steps for diagnosing an actual misfire would be:
1. swap coil packs of offending cylinder with another to see if it follows (you did this already).
2. Replace spark plugs.
3. swap injector of offending cylinder with another
4. compression/leakdown test
Bill
Old 12-14-2011, 01:33 PM   #5
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
okay so i replaced the spark plugs also. if the stock DV doesent do the trick its injector swaping time
Old 12-14-2011, 08:21 PM   #6
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
UPDATE: Its injector swaping time stock under stock DV same stuff. At least i got around to taking off the crapy ebay BOV last guy had on it
Old 12-20-2011, 07:38 PM   #7
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
UPDATE: So i changed the fuel injector, same thing still going for a compression test tomorrow
Old 12-21-2011, 01:24 AM   #8
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Sorry to hear, I drove my 2007 STI like there was no tomorrow and it lasted, good luck on the compression test.
Old 12-21-2011, 01:57 PM   #9
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
well my compression was low 138, just at the bare minimum. So i will need to rebuild headers eventually. The misfire was due to something really stupid... the spark plug. We figured it was flooded when i sea foamed the car a while back. So that's solved, no more misfire issues, but the compression worries me.
https://docs.google.com/spreadsheet/...kpFd2U5X0FSbmc
Tempreture was +4C and it was raining a tiny bit.
Here is the new table, my boost is still low for a 94 map, with 94 octane, could that be due to low pressure? I know the compression should be about ideal 140-170 on this engine. Does not sound like im leaking boost, no whistle or anything.
Old 12-21-2011, 04:49 PM   #10
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Well your DAM did not learn back up yet to 1. It's only 0.81 I don't know if that will bring the boost up through when it learns itself back to 1.0
What was the pressure across all four cylinders?
Old 12-21-2011, 06:47 PM   #11
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
we just tested the 3 cylinder that was misfiring for now as that was the imidiate issue, my shop is busy as hell and he didnt charge me anythign . Im gonna check the pressure across all a little later to narrow down if its exahaust vale, head or the whole frigging thing.
Thats a good point, i didnt notice that. I will need to give it some time to learn, maybe the boost will come back up main this is the misfire stopped, i can deal with lowered power for now.
Old 12-21-2011, 06:48 PM   #12
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
double post
Old 12-21-2011, 07:14 PM   #13
snoopy_sti
Member#: 164942
2015 Porsche Cayman
I was trying to look for a log from my 07 STI and I beat on that car
Old 12-21-2011, 11:38 PM   #14
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
Im going to run some more test on boost tomorrow. My DAM is at 1 now, so i will see if the boost will increase with this. Also curious if DAM <1 could effect the outcome of compression test.
Old 12-22-2011, 12:21 AM   #15
snoopy_sti
Member#: 164942
2015 Porsche Cayman
The dam would not have effected the compression test, I know that much, I actually tried looking all over for the logs from my 07 STI but I could not find them. Sorry
Old 12-22-2011, 01:12 PM   #16
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
no worries, thanks
Look like I will need to have an engine build soon
Help with diagnostics tevako Newbies & FAQs 0 05-18-2009 06:13 PM
I need help with utec logs. PLEASE HELP! dman918 Engine Management & Tuning 3 05-04-2003 02:54 PM
i can't lose the knock, i need some help with these logs! Tobey Engine Management & Tuning 27 04-08-2003 02:48 PM
Help With UTEC LOGS. tuca33 Engine Management & Tuning 1 03-04-2003 04:28 PM
Help with Diagnostic Code, Please EnderW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-07-2001 12:04 PM
