Old 12-15-2011, 12:16 AM   #1
adbramsay
Member#: 152345
2000 R34 GTS-T sedan
Default EJ20r piston specs
Hey guys, anyone know where I can find piston specs for the ej20r or if they are the same as the g or k?
adbramsay is offline   Reply With Quote
Old 12-15-2011, 12:21 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
almost sure they are the same (as in they will fit). but check compression ratio, some are different.
i beleave EJ20r is 8.0, EJ20H is 8.5, and EJ20G could be 8.0 or 8.5.
has to be different pistons, head cc is all 46cc, on all but 89-93 Legacy GT/RS.
this is the info i have.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-15-2011, 03:55 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
1997-1998 engines:
EJ20R and EJ20K have 8.0 CR
EJ20G and EJ20H have 9.0 CR
The pistons can be interchanged depending on what CR you're looking at. But make sure to use all four of the same engine/type as they do not have the same part number or weights!
Marnix is offline   Reply With Quote
Old 12-16-2011, 12:06 AM   #4
adbramsay
Member#: 152345
it is going to be a custom block ej20g closed deck block with custom forged ej20r pistons mated together. so if ej20k pistons work then that will suffice, is this accurate?
Old 01-23-2012, 11:23 PM   #5
adbramsay
Member#: 152345
guys I have one more question, motor goes in at the end of the week, what will be the problem if compression is raised to 8.2/8.3:1 instead of the 8:1?
EJ20R Headgasket replacement question: headbolt torque spec mysubarusti4life Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-08-2011 11:17 AM
High compression piston specs? jackolafedon Normally Aspirated Powertrain 0 03-31-2011 09:39 PM
sti v4 piston specs mudbug Pre-2002 Factory Turbo Powertrain 3 08-15-2009 03:17 PM
Piston specs shooter4fun Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-18-2006 06:41 PM
where do I get the stock 00 piston spec? IMPBOY Normally Aspirated with bolt-on Forced Induction Powertrain 14 05-28-2002 09:29 AM
