Old 01-10-2014, 08:38 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - Borg Warner EFR 8374 Build Final Results - Over 700whp!
Here she is after WAY too long!
We finally got all the fueling issues settled with an A1000, surge tank, and all new -10 lines from the back. Of course that worked like a charm and we now have all the fuel we need. We then had set back with the Spec clutch as it completely let go at about 27psi of boost. We then went with the new RPS carbon-carbon twin disc setup to hold the torque.
So after all that waiting, some fresh oil, and a final check, we get her on the dyno today and started cranking things up. We ended up at 707whp (601whp Mustang Calibration) at 32psi! The turbo definitely has more in it, but this is a great place for the car to be.
Event: Custom Tune/Dyno
Ambient Temp: 75 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2006 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 707whp @ 7000RPM
Peak Torque at RPM: 630ft-lbs @ 5350RPM
Target Boost: 32psi peak
Fuel: E85
Engine/Power Modifications:
EQ Stage 3 Shortblock (Darton Sleeves, CP Pistons, Manley I-Beam Rods)
EQ Stage 3 Heads (Supertech +1mm Valvetrain, Cosworth S2 Cams, Full P&P)
Borg Warner EFR 8374 T4 1.05a/r Twin Scroll Turbo
Full Race Twin Scroll Header, UP, DP
Dual Tial EWG's
Cosworth Intake Manifold
EQ Tuning FMIC
EQ Tuning Intake
EQ Tuning Catch Can
EQ Tuning Custom Coolant Reserviour
ID2000cc Injectors
Aeromotive Fuel Rails with EQ Line Kit
Aeromotive FPR
Walbro 450lph feeding a surge tank, feeding an A1000 Pump
Tuned with Cobb Speed Density
Invidia Q300 Catback (a bit restrictive at this power level )
Here is the dyno chart with native Dynocom calibration:
And here is the chart with the Mustang Dyno Calibration (.85CF):
And here is a crappy phone video:
Now we just need to figure out what tires will hold this thing!
-- Ed
Old 01-11-2014, 12:03 AM   #2
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Now that a serious powerband! Great work Ed!
Old 01-11-2014, 12:33 AM   #3
Doogie29th
Member#: 228414
05' Spec A bw 8374
GRP 753whp E85 6mt
Great job guys. Nice curve and numbers.
Doogie29th is offline   Reply With Quote
Old 01-11-2014, 12:44 AM   #4
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Finally!!! Glad it made the power we knew it could. Now make him take it to the track.
renosubby is offline   Reply With Quote
Old 01-11-2014, 11:18 AM   #5
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Sick results!!
Do you have a chart with boost on it?
What head studs?
Paul is online now   Reply With Quote
Old 01-11-2014, 12:36 PM   #6
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'll grab a boost chart on Monday, but it was hitting full boost in the mid-high 4's on the dyno. I'm curious to see what it does on the street. Really phenomenal spool for this power level! We're running the MAP H11 studs.
-- Ed
Old 01-11-2014, 01:11 PM   #7
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
My opinion the best graph from all the recent big power cars. Congrats. I am convinced are cars need the t4 turbo's now from your graph and the one from mine. Again good job!
02WRX2.5 is offline   Reply With Quote
Old 01-11-2014, 06:12 PM   #8
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I agree man
Layvon is online now   Reply With Quote
Old 01-12-2014, 12:36 AM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Thanks guys. I was really impressed with the spool and especially transient response of this turbo. Especially considering the rest of the setup and the overall power potential. I think this thing has another 50whp in it fairly easily.
-- Ed
Old 01-12-2014, 10:35 AM   #10
nevadaflat4
Member#: 378477
nice numbers man gotta love the efr stuff
nevadaflat4 is offline   Reply With Quote
Old 01-12-2014, 10:36 AM   #11
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Wow! very nice holding power all the way to redline.
Old 01-12-2014, 01:30 PM   #12
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Beast
Old 01-13-2014, 01:37 PM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Thanks! I'm hoping to extend the redline to 8k RPM but I think we'll need to pull the catback to let it hold power up there.
-- Ed
Old 01-13-2014, 03:58 PM   #14
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Very nice power!
jnorth85 is offline   Reply With Quote
Old 01-13-2014, 05:14 PM   #15
Mr_Flamenco
Member#: 378503
pretty impressive results.
how much you are getting at 1 Bar of boost (14 PSI)?
i know this is a subaru forum. but doesnt hurt asking would you expect similar result on a 1JZ?
Mr_Flamenco is offline   Reply With Quote
Old 01-15-2014, 12:06 PM   #16
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'm not sure what it was at 1 bar. I don't know anything about the 1JZ, but as long as the motor can handle it, this turbo will do it.
-- Ed
Old 01-21-2014, 08:29 PM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Just did a little road tuning... This thing hits 30psi by 4300RPM in 4th gear! Also hits 24psi in 1st gear! Really impressive!
-- Ed
Old 01-21-2014, 08:44 PM   #18
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Impressive.
Do you have any logs? What were intake temps?
Old 01-21-2014, 09:05 PM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'll pull up some logs tomorrow. Intake temps in the mid-high 70's.
Old 01-21-2014, 09:28 PM   #20
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Awesome!
Old 01-28-2014, 10:36 AM   #21
SWRocket
Member#: 338985
2004 WRX SW V8TT
Awesome! Congrats man!
Could you post photos of your twin scroll exhaust manifold and uppipe?
Tks
SWRocket is offline   Reply With Quote
Old 01-28-2014, 11:59 AM   #22
klenboy
Member#: 130521
2006 Subaru STi
This is making me want to put my EFR 7670 on soon!
klenboy is offline   Reply With Quote
Old 01-28-2014, 12:06 PM   #23
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Any luck with these data logs?
Thanks!
Old 01-28-2014, 02:57 PM   #24
SWRocket
Member#: 338985
2004 WRX SW V8TT
Could you tell us what clutch and flywheel you use?
I have a project for 600whp, and my ACT Xtreme is not so good now...
Thanks!
Old 01-29-2014, 02:05 PM   #25
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Thanks!
We ended up with the RPS carbon/carbon clutch and flywheel combo. Amazing setup! Please let me know if you're interested in it and I can get you pricing.
-- Ed
