Old 12-18-2011, 01:45 PM   #26
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
ETS kit looks awesome! Nice number and graph! well done guys!
YZ86 is offline   Reply With Quote
Old 12-22-2011, 02:13 AM   #27
Ohhey1
Member#: 260297
2006 STI White
HTA Green Methanol
I love this! I am currently making 420whp on my DD with pump/methanol and looking for the next step (turbo decisions). You guys feel 500whp is good without sleeves? Another thing I am researching.
Ohhey1 is offline   Reply With Quote
Old 12-22-2011, 08:48 AM   #28
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
No guarantees with anything, but from experience 580-600whp is about the limit. A stock bore (99.5mm) engine can handle more than one bored over (100mm).
500whp shouldn't be a problem at all
No Limit Motorsport is offline   Reply With Quote
Old 12-22-2011, 12:22 PM   #29
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Man, I can't wait to finish off my build with this turbo. I really like the relocated water tank bracket. The entire kit looks great. I do have on question, how are you dealing with the heat coming off the downpipe? From what I can see, it sits really close to the firewall and a/c lines.
Would love to see a video of this thing on the road.
Jose
Pacobeagle is offline   Reply With Quote
Old 02-05-2013, 12:26 PM   #30
jockeygolfs
Member#: 260868
2011 STI
How was the ETS rotated installation? Looks nice and clean.
jockeygolfs is offline   Reply With Quote
Old 02-05-2013, 04:12 PM   #31
BraveSTi
Member#: 262030
Impressive.
BraveSTi is offline   Reply With Quote
Old 02-06-2013, 10:27 AM   #32
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Originally Posted by Bariga View Post
ETS is a new APS you guys rock!
Not even close! I have had APS stuff and threw that stuff away!
ETS is true Quality in everything they build and very well Engineered. As well as top notch good people! Congrats on your setup and great choice on your setup.
Matt
02WRX2.5 is offline   Reply With Quote
Old 02-06-2013, 11:45 AM   #33
Extreme Turbo Systems
Member#: 194655
08 STI
^^ Thank you.
Michael
Extreme Turbo Systems is offline   Reply With Quote
Old 02-06-2013, 11:59 AM   #34
jockeygolfs
Member#: 260868
2011 STI
This thread and the responses from ETS have me sold.
Old 02-09-2013, 02:58 AM   #35
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
[email protected] / JR Tuned
Great job on the build I run the ETS fmic on my EVO love it!!! Glad you guys are making suby parts! 522whp on 93oct with this powerband should beat my 93oct 1/4 mile pumpgas record! Good luck guys!
OVeRBOOSTn is offline   Reply With Quote
Old 03-06-2013, 12:01 AM   #37
Justin V
Member#: 98747
07 WRX
I'm helping with a friends build and this kit was just ordered from ETS. I can't wait to see what it will do.
I do have a question though, I see some of these other PTE 6262 and 6266 just surpassing the 400 mark, and most are on 02-07 sti's. Do you think the dual AVCS heads on the newer ones helped much in this regard, or is this just a pretty aggressive tune? I assume so with 28psi on pump gas.
Justin V is offline   Reply With Quote
Old 03-06-2013, 12:40 AM   #38
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Why 2 step colder plugs when still on 93?
Zee Biker is offline   Reply With Quote
Old 03-06-2013, 08:21 AM   #39
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
35r's and 6266's should make between 420-510 on pump depending on the dyno and boost.
I made 510 on 93 pump at 25 psi. topspeed tuned on an aem acu
28 psi is definitely aggressive though lol ^. and dual avcs is usually worth 10-15 plus ft lbs over single. also helps with spool
stretchedk7 is offline   Reply With Quote
Old 03-06-2013, 08:22 AM   #40
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
second this ^^. one step should be perfect.
Old 03-06-2013, 12:00 PM   #41
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
All on lower boost then this!
02rex62 is offline   Reply With Quote
Old 03-06-2013, 01:05 PM   #42
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
exactly lol!
Old 03-06-2013, 01:07 PM   #43
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
6266 is a bad boy turbo! should make about 380-430 at 18 -20 psi. and 440-540 from 22 to 30. and thats not on e85
540 being a super efficient setup with no bottlenecks and good cams/tuner
Old 03-06-2013, 01:54 PM   #44
Justin V
Member#: 98747
07 WRX
The only reason I ask is because if we are only going to see 400+ we could have stayed stock location with a blouch dom or atp 3076 and seen full boost sooner and similar numbers.
I guess we'll consider some head work now, but all the shops have said stock heads can support 500
stretchedk7: Doug from topspeed will most likely be tuning this car after its been broke in. I hope to see similar numbers to yours
Old 03-06-2013, 02:14 PM   #45
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
If you are building the motor, do the head work. Like they say you make power with the heads and you hold the power with the block. Cams, port/ bowl and valve train work will make the turbo work more efficiently and extend your power band to the right and if done right will extend the PB to the left. I did the head work on my build and have a solid 4k power band! I have a Dom 3.5XTR because I had a bit invested in a custom up pipe & EWG exhaust work with my Killer B header. If I was to rotate a turbo on my build this 6266CEA is the turbo I would use!
Old 03-06-2013, 02:50 PM   #46
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Btw all my numbers were stock head castings just big cams and valvetrain
Old 03-06-2013, 04:33 PM   #47
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
hello justin i tuned this car.every pt turbo has done what i asked it to do.perform great with all applications-this car was built very well and flowed great air.the tune was not to aggresive at all just a great combination of parts.this car will be going to e 85 very soon then we will get aggressive with her..
dave
PerformanceAutoSolutions is offline   Reply With Quote
Old 06-26-2014, 07:49 AM   #48
zman17
Member#: 357718
2004 wrx sti
psm
What do you think this car would of made on e85?
zman17 is offline   Reply With Quote
Old 06-26-2014, 09:47 AM   #49
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
They should take it to the track first it's been 3 years and nothing how many times will it be revived without (proven power), cars probably had 2 more engines by now.
spoolinsti05 is offline   Reply With Quote
Old 06-26-2014, 09:31 PM   #50
shomspeed
Member#: 166371
2007 WRX STI
Its nice you guys achieved this amount of power on pump gas, i don't think its wise though to drive around daily on such a tune on pump gas without water/meth injection, especially if your goal is relatively high boost on pump gas. A 100mm bore setup even makes it more crucial to not have any detonation at all. But that's just my 2 cents
shomspeed is offline   Reply With Quote
ETS Sneak Peak - 08-09 Front Mount Intercooler Kit for ETS Turbo Kit Extreme Turbo Systems Vendor Announcements 32 10-06-2011 10:03 PM
PhatBotti Tuning Miami: One NICE 06 STI, Built 2.5, AMS 35R .63, 28psi on 93 octane PhatBotti Tuning TKR Proven Power Bragging 40 08-26-2011 06:41 PM
Derrick's 04 STI - Stage 2 plus, 93 octane, make the stock turbo cry Innovative Tuning Proven Power Bragging 0 08-23-2011 05:32 PM
2011 WRB STI Limited : 360 whp/350 torque @ 23 PSI on 93 Octane Diso09WRX Member's Car Gallery 32 08-09-2011 03:44 PM
Wrx / Sti Rotated Gt3082r Turbo Kit aspenghost Engine/Power/Exhaust 33 11-20-2008 03:36 PM
