Old 08-11-2002, 11:42 AM   #1
ChrisV-FL
Member#: 16609
2006 B9 Tribeca
2004 Mazda RX8
Question Bigger TURBO and What else to go with it???
OK If I get a Bigger turbo then what other thigns Imight have to get..I know that a biegger intercooler but how canI getthe ECU to no cut my fuelat 18 Psi with the bigger turbo???
Would I need right a way bigger injector and Fuel pump or can I run the Stock components??....
ChrisV-FL is offline   Reply With Quote
Old 08-11-2002, 11:52 AM   #2
mrtrex
Member#: 12223
2005 WRX
If you do a turbo xs unichip fuel cut is raised to around 21psi. I dont believe cobb and vishnu use fuel cut built in there systems. You could get away vf-28 or 29 without injecters or even a FP turbo would be good. A larger fuel pump and pluggs would be needed at ant turbo up grade. Get some gauges also. You cpuld also do a fuel controller but it does not control timing like the unichip. If you go vf-30 on up injectors, pump and pluggs are needed.
mrtrex is offline   Reply With Quote
Old 08-11-2002, 11:52 AM   #3
Quantum-Racing.com
Vendor
Member#: 20483
If you don't get the pump and injectors, you could run very low boost. Ideally you want at least injectors and fuel pump for the fuel side and an intercooler.
Quantum-Racing.com is offline   Reply With Quote
Old 08-11-2002, 12:09 PM   #4
ChrisV-FL
Member#: 16609
2006 B9 Tribeca
2004 Mazda RX8
Default COOL
Well I do have gauges already in to monitor every thing.....I'll looking for choiceson the differents turbos ......also what ECU Controler other than a UNI Chipis is out there and recomended for the REX???
Old 08-11-2002, 04:40 PM   #5
scaryfastskier
Member#: 7893
2010 F150 & Iron883
Husky TE449 + TXC250
UNIchip is not a brand...it is a part. It is a chip that works with the stock ECU (computer). It is considered plug and play because you more or less just plug it in, and it starts functioning with the car. Vishnu, TurboXS, COBB....they all offer one. There may be more, but that is all that I can pull off the top of my head. The chip will control timing, boost, and air/fuel ratio.
If you don't want a unichip, you can replace the stock computer with a standalone unit such as a link. This is costly and hard to manage/tune....unless you know what you are doing and are quite good at it. No offense, but if you are asking a question such as the one found in this post, stay away from this route. (at least for now) It would be fairly easy to cause some major damage to your car.
A third route would be to buy air/fuel controllers, boost controllers, timing controllers, etc. and have about a half dozen mini-computers in your car. This would work, but I am pretty sure it would be a HUGE pain in the ass for someone that is not very skilled at tuning.
You asked how to remove boost cut: There is a product called a "boost-cut defender" that will do it for you. I beleive MRT makes it, but I am very unsure. Look it up.
You say you need a bigger intercooler....I would say that the injectors and pump are more important the intercooler, but
FOR GODS SAKE DO A SEARCH!
An entire encyclopedia's worth of information could be written to answer just the simple questions you asked. Most everything that could be discussed about our cars and mods, has been discussed (most likely twice ). Try running a search and you should be able to find more information that you would ever want. If you still have questions after reading through the old posts, then ask some questions.
Grant - hopes this helps
PS gauges are very important, but they are not going to do any good unless you know how to read them and what the acceptable parameters are.
scaryfastskier is offline   Reply With Quote
yes another 2.5 swap.....and all the questions to go with it lin4tw Subaru Conversions 13 04-06-2009 10:12 PM
FS: Haltech e6x and everything needed to go with it robbie2883 Engine/Power/Exhaust 0 03-10-2009 12:44 PM
need some help with deciding what motor to go with BallzToTheWallz Built Motor Discussion 2 07-23-2007 12:15 PM
Ask the OT: What wine to go with spiced roasted chicken and potatoes? Mencius01 Off-Topic 17 04-21-2007 05:48 PM
new sighting and a suby wave to go with it SAND_MAN1 Texas Impreza Club Forum -- TXIC 0 03-12-2005 12:50 PM
