Old 12-16-2011, 12:21 PM   #1
Jondoe1980
Member#: 291697
2013 WRX STI Limited
Ice Silver Metallic
Default Easiest way to check for bad o2 sensors?
I am throwing a CEL 0420 for cat threshold. I have checked for exhaust leaks but my IAM is still 11! I have a tactrix cable and romraider for anyone that can help me analyze the data.
Jondoe1980 is offline   Reply With Quote
Old 12-16-2011, 11:02 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
do a drive cycle, get it up to operating temp then cruise at 50mph for 2 minutes with no loads on, no slowing or speeding up, no hills, then lift off the throttle for 5 seconds and accelerate back to 50, repeat 2 more times.
You'll want to monitor A/F and O2 sensors, speed, throttle position. For the 2 minute stretch you want 5 seconds per division to see how the sensors are reading - steady versus erratic. Then switch it to .5 seconds per division for the decelerate section so you can see if the O2 is reacting faster than the A/F sensor.
Post up what you get.
O2 sensor resistance should drop pretty quickly to about 30 and stay relatively flat. If it's all over the place, there's either a bad sensor or bad wiring.
CosmoTheCat is offline   Reply With Quote
Old 12-20-2011, 12:12 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
its done....throw it away
What's the easiest way to check your O2 sensor? BGPunk2001 Off-Topic 44 07-24-2009 02:56 PM
What's the easiest way to search for your own posts? thehalogod Off-Topic 25 05-12-2008 08:30 PM
Whats the best way to check for compression? nos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 01:56 PM
What's the best way to check for exhaust leaks? wgknestrick General Community 5 02-20-2003 10:33 PM
Good way to check for exhaust leak garface Normally Aspirated Powertrain 7 03-06-2002 10:14 AM
