#1 |
Member#: 287176
Vehicle:2005 STi WRB |
I know there are a few threads about this, but I think mine is in a different location...unless I'm super special. I'm losing gas (like literally filling up every day) and I need to get this resolved ASAP.
I don't want to go and get raped by the dealership, so lemme know if I can do this myself or not. I have minimal experience on our engines. ![]() By chriskarel at 2011-12-16 zoom in a bit... ![]() By chriskarel at 2011-12-16 view from the top looking down. it isn't pooling a lot, but it's def there. ![]() By chriskarel at 2011-12-16 I fear that the manifold has to come off to get to those lines. I'm not even sure exactly which is the culprit, but it's under there somewhere. Help friends! :/
#2 |
Member#: 287176
PS this started when the cold weather hit if that matters.
#3 |
Member#: 248282
International
Vehicle:2002 WRX 298 whp |
I dealt with that, same location... ended up with parallel fuel rails...
#4 |
Member#: 287176
that's what I might end up getting too. You mind sharing how much that cost?
#5 |
Member#: 248282
International
like $300 maybe... keep in mind that intake manifold has to be removed if not is a pain...
#6 |
Member#: 287176
$300 for the rails, or rails and labor?
#7 |
Member#: 287176
I'm gonna try to do this DIY this week, any info is appreciated!!
#8 |
Member#: 287176
sweet guys
#9 |
Member#: 248282
International
$300 for the rails, try to get new manifold gaskets... if you want to go further do the tgv delete and get 4 manifold gaskets, if not just 2 gaskets...
#10 |
Member#: 224544
Vehicle:2005 Impreza WRX PSM |
I had the same problem and I just fixed it this past weekend. It was that the hose clamps under the turbo inlet were at least 3 turns loose. I then tightened them up and went away for a bit then the other side started to leak. The only way to fix it is to pull the the intake and replace all the rubber hose for the fuel line and double up the fuel line clamps. Plus while you are in there; there is no reason not to do the TGV delete and maybe put on a aftermarket turbo inlet. It is just an extremely poor design on Subarus part.
#11 |
Member#: 287176
not gonna lie, I think pulling the intake manny off is way above my level. I would do more harm than good probably. So off to Subaru to pay $94/hr. for labor. :'(
#12 |
Member#: 206720
SWIC
Vehicle:2002 WRX Wagon Silver |
This is just like the bugeye fuel line leaks that are getting fixed by Subaru. I would call SOA and tell them what you are seeing. I have to fix my leak soon. You must be losing a lot of gas if you have to fill up every day. This might be dangerous so get it looked at soon.
#13 |
Member#: 248282
International
Have fun! post some pics!
#14 |
Member#: 287176
Today is 55 degrees and it's totally fine. But when it's under 40ish degrees I lose literally 1/8 tank in like 10 miles
#15 |
Member#: 206720
SWIC
Dude that is a major leak. Better not drive till this is fixed.
#16 | |
Member#: 22412
SWIC
Vehicle:2012 Legacy 2.5GT Ice Silver Metallic |
an eighth of a tank every 10 miles is a very bad leak - I'd try not to drive if at all possible (an engine fire is a tad more expensive to deal with than replacing fuel rails) - did you try to get a screwdriver on the hose clamps and tighten them up? |
#17 |
Member#: 133023
Vehicle:2005 WRX STi Silver |
I had this same problem in my '05 STi. I called up Subaru, explained the problem, told them that there were some NHTSA cases opened about this same problem, and Subaru took care of fixing the problem. I would recommend calling SOA.
#18 |
Member#: 246146
NESIC
Vehicle:2005 WRX PSM |
| Thread Tools | |
| Display Modes | |
| 05 wrx fuel leak in cold weather? | skirex | Factory 2.0L Turbo Powertrain | 17 | 01-08-2009 04:23 PM |
| 08 sti motor in 05 sti need help! | sleepysubie | Subaru Conversions | 19 | 09-29-2008 09:49 AM |
| 05 STI - COBB uppipe install - I can't stop the leaking | AnorexicSTI | Factory 2.5L Turbo Powertrain | 3 | 10-04-2006 10:14 AM |
| aftermarket exhaust for my 05 STI - help me decide | nkkilla | Factory 2.5L Turbo Powertrain | 60 | 01-10-2005 02:04 AM |
| asking for advice - fuel leak in engine! | daWagon | Factory 2.0L Turbo Powertrain | 7 | 10-19-2004 11:26 AM |
