Old 12-17-2011, 12:47 AM   #1
Tin Knocker
Member#: 253513
03 Impreza WRX
Sedona Red Pearl
Exclamation Need a little bit help.....03' WRX with JDM V7 Heads - Engine Harness Question
Hey everyone, I have an 03' WRX with JDM V7 heads. Since I could not source a JDM V7 Engine Harness, I picked up an 04' STi Engine Harness.
Can I use an 04' STi Engine Harness with my current setup or would it be better to splice in the AVCS and Rear Magnetic Cam Sensor harnesses?
Any help would be greatly appreciated. Thanks in advance.
- Matt
Tin Knocker is offline   Reply With Quote
Old 12-17-2011, 01:37 AM   #2
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Go to IAperformance and just buy the premade wiring kit... (Do you have the version 7 ECU?) I assume u do if you are trying to get the AVCS to work.
Jubert39 is offline   Reply With Quote
Old 12-17-2011, 01:38 AM   #3
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Old 12-17-2011, 02:51 AM   #4
Tin Knocker
Member#: 253513
03 Impreza WRX
Sedona Red Pearl
I currently have the IAperformance harness and a version 7 ECU. the problem is my orginal engine harness does not have plugs for the AVCS
and when I plug the IAperformance harness into the big black and big gray plug there is no wires on the other side of the plug to make a conection. so I figured if I bought a 04' STI harness it would solve my issues. However, the 04' STI harness seems to have more plugs than my 03' wrx. Am I doing this right?
Thanks!!
Old 12-17-2011, 09:40 AM   #5
Tin Knocker
Member#: 253513
03 Impreza WRX
Sedona Red Pearl
Bump.....
Old 12-17-2011, 11:25 PM   #6
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Thanks!!
im confused, isnt that what the point of the wiring harness is? Your stock 03WRX engine harness has no AVCS (duh), thats why you have to use the IA wiring kit and "manually" wire it in, via the instructions from IA. Then u plug into your ECU and you should be good to go. When I had my 04 WRX swapped to the JDM, i didnt need to get an STI harness....
On second thought... which IM are you using?
Old 12-17-2011, 11:26 PM   #7
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
yea nvm, you might need the STI harness....
Old 12-24-2011, 01:37 PM   #8
N8WRX
Member#: 99395
2015 Impreza WRX
World Rally Blue
Your talking about the engine harness correct? the IAperformance kit is for the chassis harness. Inorder to do this right your going to need the ej207 engine harness you cant use the usdm 2.5 without wiring changes. Using the ej207 engine harness, the stock chassis harness and the AVCS wiring kit all you need to do is plug it all in and install the AVCS kit in the pinout blocks for the ECU and pass+drivers heads. As far as anything on the block they should plug into the v7 engine harness.
N8WRX is offline   Reply With Quote
02 WRX to JDM STi Ver. 7 engine. Do you need more than AVCS harness? garface Subaru Conversions 40 03-26-2010 09:33 PM
06 WRX with JDM STi pinks - feedback? my name is joe Brakes, Steering & Suspension 3 05-02-2009 10:50 PM
WTT: 04 WRX with JDM V7 STI wing in WRB, FOR 04-05 WRB WRX winged virjose Exterior/Styling 8 01-25-2007 05:06 PM
For Sale: 2002 WRX wagon with jdm V7 engine and jdm V7 ecu (AVCS) jonepachek Tri-State Area Private Classifieds 0 05-31-2006 09:19 PM
Post picture of WRX with JDM V7 STi strut! txl146 Member's Car Gallery 6 12-22-2005 11:26 PM
