Old 12-21-2011, 01:02 AM   #51
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
just travel
synolimit is offline   Reply With Quote
Old 12-22-2011, 11:32 AM   #52
hakira
Member#: 74211
SSM WRX 4DR
@synolimit
You have any sound clips of your car running?
hakira is offline   Reply With Quote
Old 12-22-2011, 12:57 PM   #53
Vash337
Member#: 282107
2011 wrx sedan
obsidian black
interesting
Vash337 is offline   Reply With Quote
Old 12-22-2011, 04:41 PM   #54
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
I think now you're getting why I gut the car before going to the track lol... also why I just picked up the aluminum bumper beam.
My goal is 2700lbs dry once this thing isn't my dd. I think the clutch when combined with an act street flywheel shaves off 12 lbs.... other than that the weight removal on the crank pulley and ds aren't as effective because the moment on those is already so small. The big savings is in the clutch/fly, and wheels and brakes. Even if those wilwoods are lighter, being a larger diameter may hurt you more than the weight helps (aluminum hats are nice savings though), just food for thought.
RicersWetDream is offline   Reply With Quote
Old 12-22-2011, 07:44 PM   #55
synolimit
Member#: 225225
11 WRX
I just removed both bumper beams
Since dry weight now is 2934 I could see another 234. I mean that's gutted full interior though. I know the wilwood 4 pots are -26lb and 99% sure OEM size. The rears are getting made now so I'd guess another -20 there. -13.4lb on the drive shaft. You gotta weigh your OEM hood! I do plan on getting a CF hood and trunk but I don't think it's much. My trunk is already light! I'd guess on both maybe -15-20lb if your lucky. I know the clutch/flywheel is another -20ish if you go full Carbonetic. Hell right there your at 100 lb with full interior.
i know gutting the inside and sound deadner will drop some more so it will be close. the problem with me is ill add it right back when i put in a role cage for the track. id guess those have to be at least 200-300 lbs.
Old 12-22-2011, 07:56 PM   #56
synolimit
Member#: 225225
11 WRX
Originally Posted by hakira View Post
@synolimit
no i dont. to me any subi with a EL header sounds the same. a ton quieter than UEL header, smooth, clean, more evo sounding but not 100% ricer/civic. you tube exhaust cutout and ewg and there you go.
i guess on my car its hard to tell everything though because there is so much! i mean on spool up the intake is sucking like mad! the turbo is whining like crazy. the ewg opens and you hear all that. the exhaust is loud in boost. and then the cutout is like a vibrating freight train! just so much going on.
cant wait for one day to get straight cut gears to add to the madness!!
Old 12-23-2011, 12:53 PM   #57
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
A chromoly cage is in the 125 lb range if I recall correctly... use the right stuff and it's not too much added back in.
My oem hood weighed in at 45 + guts when I took it off. The seibon weighs in at about 20-21, and I swapped the guts onto it but cut maybe a lb off when I hacked up the insulation to not cover the vents.
I just don't feel good completely removing both bumper beams on a dd. If I'm going to the track and back, sure, but that's why I'm going aluminum on the front one. I may just leave the rear one OEM to help out with the f/r weight distribution.
Old 12-23-2011, 02:30 PM   #58
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Originally Posted by djc1827 View Post
Phatron where is Phatbotti tuning? I see the nastiest cars being tuned by them? 11.50 on that sti...I know its gutted but damn thats moving
Phatbotti has no real location. We contract. We are from CT and CA, and travel all over the continent. I use a few dyno's in the northeast, and consider one in Norwalk, CT my home. Not having a facility enables us to extend our customer base world wide.
I did work with that 11.50 stock turbo car too
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 12-23-2011, 03:33 PM   #59
synolimit
Member#: 225225
11 WRX
o cool, thats not to heavy. how many points and how crazy of a cage is that?
sweet, a hood should really come in handy then!
Old 12-23-2011, 03:36 PM   #60
synolimit
Member#: 225225
11 WRX
tweaked the cutout closed map a little and installed 1 step colder plugs. the TQ really has me happy now!!!!!! the cutout open doesnt seem to like the same map. looks like ill have to have 2 maps.
Old 12-26-2011, 10:34 PM   #61
djc1827
Member#: 238618
2011 WRX
11.82 stock 5sp/eng vf52
-Mikey
Very impressive man....Do you believe you can street tune a car just as effective as a dyno tune? I know some tuners do a street tune after they dyno tune. Do you think e85 is much more forgiving than meth/pump/racegas? I am shooting for 11.60s without any serious weight reduction. Maybe the spare and pass seat at most. I def think its possible with a good 60ft....like 1.65. Oh yea one more question...I was going to get tuned on my winter rims which are 24lbs vs my summer rims which are 15lbs...is that gonna kill my dyno numbers?
djc1827 is offline   Reply With Quote
Old 12-27-2011, 04:20 PM   #62
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
I'm not a tuner, but mine always says if you're knocking on E85 you're doing something horribly wrong.
We even had a pull run up to 12.8-13.0:1 AFR early on at one point and not a blip, egt's kept below 1450* too.
Old 12-27-2011, 04:21 PM   #63
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Dang nice numbers
07wrx84 is offline   Reply With Quote
Old 12-28-2011, 04:35 PM   #64
gigabyte86
Member#: 287097
2009 WRX VF52
Gray Hatch 315/345
i'm just wondering if the PnP grimmspeed manifolds will make any difference at all. everyone raves about them(hence why they're sitting in a box right next to me haha). i wish i could do a before and after with JUST THEM. aka first one ever but unfortunately i'm doing tgv deletes as well. i've heard it's a great combo and p&l recommended(Paul did anyways).
oh syno, how did you like your perrin pulley, i had one on my 05 LOVED it but i bought a grimmspeed this time around for the 09.
gigabyte86 is offline   Reply With Quote
Old 12-29-2011, 03:36 AM   #65
Lrn2Corner
Member#: 246224
2012 WRX Sedan
12 Rav4 V6
The only thing I am not liking is where your torque falls off in your rpm range. The numbers are surely impressive but it just starts falling off fairly quickly around 4500 RPMs.
Lrn2Corner is offline   Reply With Quote
Old 12-29-2011, 03:55 AM   #66
synolimit
Member#: 225225
11 WRX
It's a stock turbo. Boost also tapers off there so not much I can do.
Old 01-02-2012, 12:16 AM   #67
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
I trapped 100mph with 260awhp @ 13.5
2011 wrx stage 2
Subie_Noob_Brian is offline   Reply With Quote
Old 01-02-2012, 12:54 AM   #68
synolimit
Member#: 225225
11 WRX
the mph and time are what i did bone stock, 13.3 at 101. the hp is irrelevant. something doesnt seem right at that stage 2 unless its the worst track in the world and 100+ or no traction and freezing out.
Old 01-02-2012, 12:43 PM   #69
hakira
Member#: 74211
SSM WRX 4DR
or bad launch
Old 01-02-2012, 02:56 PM   #70
GeneralTJI
Member#: 152680
I made 2 11 second pulls on a stock 2.0 with afr's at 13.3:1 on E85 one night when I forgot my laptop.... looked up in 4th on the first pass, saw the wideband... prayed for a good outcome... it lived, so I did it again
GeneralTJI is offline   Reply With Quote
Old 01-02-2012, 04:31 PM   #71
Frostybeverage
Member#: 266862
2011 Impreza WRX
WR Blue
Pics of the car?
Frostybeverage is offline   Reply With Quote
Old 01-02-2012, 05:18 PM   #72
synolimit
Member#: 225225
11 WRX
winter mode. fyi the black hot dog bun shape vinyl things you see on the door frames are to protect the paint from the OEM roof rails for my bike mount setup. o and next week 20% tint finally! i hate being without it.
Old 01-02-2012, 06:11 PM   #73
Subie_Noob_Brian
Member#: 288037
It was my first time on a track. I was pretty confused lol
Old 01-06-2012, 01:35 AM   #74
djc1827
Member#: 238618
2011 WRX
With all that weight reduction you guys should be going faster than me....the only stock turbo sti's that are going faster than me are gutted and aren't running stock engines. Taking out the those crash beams is crazy man, you rear end somebody and you will be sorry bro. Nice build tho, I will post a thread soon. Hitting the dyno monday, will have my fresh rims on too, fmic is installed with all the other parts. Ill post some nice pics and dyno numbers....mustang dyno tho so you know they will be lower than most. Thats where timeslips come into play
Old 01-06-2012, 03:55 AM   #75
synolimit
Member#: 225225
11 WRX
Just ran my friends data logs through air boy and there dead on for his tuners brand new mustang.
2010 WRX VF52 331/374 on 93+ 317/351 on 91 boost-o-matic Proven Power Bragging 32 01-23-2013 03:09 AM
11 wrx hatch wheels bigvicswrx Interior & Exterior Modification 11 12-19-2011 09:28 AM
FS : Nameless Axelback $350 fits hatchback came off 11 wrx Jermaine2011wrx Engine/Power/Exhaust 2 12-16-2011 11:32 PM
09 WRX Stock Turbo Retuned on 93 - Airboy Plot RicersWetDream Proven Power Bragging 6 08-27-2011 10:19 PM
Max PSI on 93 octane, conflicting results. Tgui Open Source Reflashes 4 05-28-2009 10:55 PM
