#1 |
Member#: 272090
Exterior Mods
22b Style Hood Vents Bakemono Imports Replica S201 Hood Scoop(carbon) Bakemono Imports Replica S201 Mirrors Bakemono Imports Front lip(22b Extension style lip for rs bumper) - note: might try to find a OEM/JDM sport(22b style but for stock with fenders) Bakemono Imports Side Skirts Bakemono Imports USDM Rear Bumper Spats Bakemono Imports Mesh Fog Light Covers JDM STI Flat Fuel Door 17"x8.5" or 9"(undecided) Enkei Rpf1s Omiotek Paintjob(Charcoal more then likely) Omiotek Tinted Tails Omiotek Black Housing Headlights 25% Window Tint Interior USDM STI Seats USDM STI Carpet NavigationZealus Interiors Shift Boot/Ebrake Boot - 50/50 Blue/Black Alcanatara with reversed stitching Zealus Interiors Door Card Cutouts - Blue Alcantara Lizard skin sound deadening(removed the old crap) Battery relocation all parts are going on my 2001 RS Eclipse Navigation Rockford Fosgate 6.5" speakers(doors and rear deck) Rockford Fosgate Punch sub(came with the car so im gunna use it) Rockford Fosgate Amp JDM STI Hazzard Switch JDM STI V6 Cluster(same as usdm but tachs in the middle and higher speed rating) Pro Sport Green Gauges - wideband, oil temp, oil pressure, boost, volt, fuel pressure Engine Stock EJ251 Block EJ257 STI Crank EJ257 STI Rods EJ257 STI Pistons AAAB ARP Headstuds ARP Rod Bolts ARP Block Bolts ACL Race Bearings Ported Heads Delta Camshaft 1500 Grind Supercharger Cams 08+ OEM Subaru 11mm Oil Pump 08+ STI Blue 565cc Injectors OEM STI Fuel Pump OEM Gasket Overhaul Kit Grimmspeed Crank Pulley Gates Timing kit Pro Sport Sandwich Mishimoto Radiator Moroso Aluminum Oil Pan OBX Equal Length Headers CNT Catback Aeromotive Dual Inlet FPR transmission ACT Street Clutch ACT Flywheel Suspension WRX Front and Rear Sway Bar WRX Crossmember WRX Trailing Arms WRX Lateral Links Tein Super Street Coilovers JDM STI Strut Bar Chassis Braces STI Group N Bushing Set The Fun Eaton M90 Supercharger Ford GT500 Heat Exchanger(made by garret) WERKSCustom Blower/Idler Pulley Bracket WERKS Parallel Fuel Rail Mod WERKS Air to Water Setup WERKS Throttle Body Relocation WERKS Lightweight Battery Setup will add to this more later and will add pics aswell. so here it is as it came off the truck.. bought the car for 1k and it didnt run......threw a battery in it fired right up....sure enough had the typical subby rod knock.. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Member#: 272090
after i finished up the outside.... havent gotten to given the inside a cleaning yet....
![]() ![]() ![]() ![]() ![]() ![]() replica s201 scoop i got....never ever mounted payed half of what it costs new. ![]() ![]() ![]() |
#3 |
Member#: 272090
wrx suspension but not everythings there in the pic
![]() motor all torn down ![]() ![]() ![]() ![]() sti rods and mesh fog light covers ![]() ![]() |
#4 |
Member#: 272090
awww isnt it cute?
![]() ![]() ![]() ![]() pro sport oil pressure(still need to get more gauges) ![]() STI Seats and carpet ![]() ![]() GATES Timing Kit ![]() 11mm Oil Pump ![]() Flat Fuel Door Kit/JDM Hazzard Swithc ![]() Gasket Rebuild Set |
#5 |
Member#: 272090
![]() greddy emanage blue $88 shipped ![]() STI Blue Injectors ![]() Moroso Oil Pan(1k on it) $325 shipped and its normally a $700 pan. would like to put a special thanks out to moroso aswell for going out of their way. the dipstick design the pan had sucked. they had me ship them the pan. they welded in a new adapter that uses the stock dip stick and also cleaned and decked the pan to check for flatness and included new studs and gaskets of no charge to me and it was a 1k turb around including shipping days. amazing service. ![]() ![]() ![]() |
#6 |
Member#: 272090
before
![]() after ![]() ![]() ![]() ![]() got this heat exhanger from a shelby gt500 owner i recently did a clutch on...best price free ![]() ![]() some painted parts ![]() ![]() |
#7 |
Member#: 272090
some painted parts
![]() ![]() p://i905.photobucket.com/albums/ac253/boosted106/photobucket-3640-1321589176022.jpg[/IMG] ![]() ![]() ![]() ![]() sorry for the crappy pics cant seem to get good enough light... will get some more when i finish the ac compressor. |
#8 |
Member#: 272090
andy from zealus(ript) interiors has been awesome to deal with. i was not happy with the previous color match he had sent me and he was more then pleasent at helping me find and sending me samples and what not. needless to say we got something REAL close to the sti seats.
![]() ![]() out with the old and in with the new ![]() also got my headlights apart today(glass lenses) ![]() ![]() |
#9 |
Member#: 272090
more painted parts
![]() ![]() grimmspeed master cylinder brace ![]() my ej251 block with complete sti internals. ![]() ![]() ![]() shot of the cylinder head.... other one looks exactly the same lol..... cleaned up. mild porting and delta 1500 cams ![]() ac compressor finished up so you get the idea with the black pullies on there with the color i chose for the engine and waht not. ![]() ![]() |
#10 |
Member#: 272090
ACT Street Cluthc
ACT Street - Lite Flywheel ![]() Aeromotive Dual Inlet FPR ![]() Smoked Fender Markers ![]() progress from today and yesterday. ARP Headstuds Installed ![]() ![]() ![]() ![]() |
#11 |
Member#: 272090
got the motor all masked up and ready for wire brushing(ignore the purple valve cover....its a spare i used to test a color for the woman)
![]() ![]() ![]() you can see the top portion i did compared to what it was previously. ![]() started prepping the headlights for the retrofit project..... paint doesnt like to stick to chrome sound i made it a task to rid of it totally before ![]() ![]() after ![]() ![]() |
#12 |
Member#: 272090
more progress
finished cleaning up the underside of the block and heads. ![]() ![]() alllll clean! ![]() all prepped cleaned and final taped ![]() ![]() primer ![]() painted! ![]() ![]() |
#13 |
Member#: 272090
![]() test fit pictures with my sti blues and zero drifts rails. another update coming in a couple hours. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#14 |
Member#: 272090
painted the 11mm oil pump
![]() painted the gates tensioner pulley ![]() painted the gates water pump ![]() got some parts from ajw today... grimmspeed crank pulley and phenolic spacers ![]() ![]() |
#15 |
Member#: 272090
couple better pics of the block
#16 |
Member#: 23553
Vehicle:ZOMG my car is actually working!!! |
WOW, never saw anybody paint a motor like that on a Subaru. Just wondering, why did you paint the timing belt tensioner?
#17 |
Member#: 272090
in all honesty because if i pulled the timing cover ever and i saw a casted aluminum piece i would shoot myself in for not painting when i painted everything.
i know your not going to see it. the bushings, the pulley and what not where all completely masked up so none of that got painted just the tape you see in the pics..its little details like that to me that count and even though it wont be seen it took me a whopping 5-10 minutes of prep work and masking to just do it and make everything colored rather then leaving that one silly piece the aluminum color. |
#18 |
Member#: 139996
Vehicle:2004 Subaru WRX STi PSM |
looks good so far! i like it!
#19 |
Member#: 272090
thanks
#20 |
Member#: 182551
Vehicle:2004 STi PSM |
whew that is a lot of work! but damn i love builds like these. great job man.
#21 |
Member#: 272090
thats for the compliments... the goal was to do this build on a budget but without cutting corners and doing it the way i wanted. i didnt give myself a budget because i know the budget rule too well and it usually goes over by 30-50%. also im not afraid to pass up good deals on certain parts like the moroso pan and pistons and stuff so ive spent some more money then what would of normally of been seen in a budget build but its going to be the car i want. thanks for the compliments
#22 |
Visiting NASIOC Timeout
Member#: 70710
Vehicle:2002 04STi Swaped RS w/PPGS & 02 Wagon w/PPGs |
Looking Good! Your block color choice reminds me of the Legacy SS build I did a few years ago.
http://forums.nasioc.com/forums/show...light=crap+box Im totally on the same page with your statement of doing a budget build without cutting corners. |
#23 |
Member#: 272090
thanks man ill check it out when im off work.
#24 | |
Member#: 139996
even if i am broke, if i find a good deal, i find a way to get the money so i would save 100+ |
#25 |
Member#: 272090
exactly that how i look at it... i save money where i can but depending on the part i dont feel like skimping.
yeah ive built more cars then this so ive learned. the cobalt that made octobers issue of modified magazine is mine, then i have a drag car too. this is my first scooby do though lol. ive been around the cars a long time just never actually owned one. |
| Thread Tools | |
| Display Modes | |
| My Supercharger Build | Skidd | Normally Aspirated with bolt-on Forced Induction Powertrain | 150 | 09-07-2011 11:40 PM |
| WTB : Omiotek WTB Thread(motor parts) | omiotek | Private 'Wanted' Classifieds | 3 | 09-06-2011 12:46 PM |
| VIsubi's Raptor Supercharger build | LetItSnow | Normally Aspirated with bolt-on Forced Induction Powertrain | 57 | 02-12-2011 07:11 PM |
| A supercharger build with actual power(Not Mine) | ToneWrx02 | Normally Aspirated with bolt-on Forced Induction Powertrain | 15 | 01-31-2011 03:09 PM |
| What's needed to tune supercharge build on a 2.2L? | NC_OBS | Normally Aspirated with bolt-on Forced Induction Powertrain | 1 | 05-06-2009 02:00 PM |
