Old 12-20-2011, 12:49 AM   #1
Skoobaru05
Member#: 296923
2005 Impreza WRX
Subaru Blue
Post Removing 05 WRX rear bumper
I looked around on the forums today just to get an idea if there was a step by step walk through on how to remove the rear bumper on a 04/05 WRX Sedan. As I could not find one I have created one.
We all have one retarded friend and sometime we let them drive our precious cars for reasons we still don't know. Mine backed up into another car causing no damage to the 70's model Cadillac but causing a large dent in my rear bumper right on the corner of the drivers side.
To Begin with you will need a deep well 8mm socket, Deep Well 10mm Socket, Deep Well 12mm Socket, an appropriate size ratchet, and a phillips head screw driver. Also you may need a flat head screw driver depending on how your crappy plastic clips are cooperating.
Begin by removing the plastic screw clips that hold down your carpet inside your trunk.
Fold back your carpet so you can get to the 4 8mm nuts holding your tail lights in. Remove the 4 8mm nuts on either tail light and unplug the electrical clip. Gently pull the tail light out and place it somewhere safe.
Next remove the 10mm screw on inside of your rear fender. This one may cause you some trouble because of limited space, just keep at it.
Next crawl your ass under the car and pop loose the 5 plastic clips (screws) or whatever those things are called. This may require a flat head screw driver (it did for me).
Sorry no image available for these plastic pops spaced out pretty well and I don't think the forum needs the extra 5 pics.
Next right underneath where the tail light would normally be you will find a 10mm odd shaped bolt marked #1 in the pic. Be careful with this as it crewed into plastic and will strip out if over tightened. There are also 2 more plastic pop screw thingies (#2 & #3).
We're almost there. Next you got back inside your trunk and behind the carpet just below and towards the center of the bumper from where the tail lights were you will find two 12mm nuts that need to be removed.
Finally pull the bumper loose but not all the way off. The Licence plate light still have to be removed. If you have a second person this is easy if not you may want a electric screw driver. You remove the two outer most screws.
That's it for the bumper removal.
This next information should only be done if you're confident in your abilities. I am not a licensed auto technician but I did receive this information from a man who did body work for 40+ years.
Now if you have a dent like mine you will need a heat gun or a hair dryer, heat resistant gloves (mechanics gloves work great), and a towel. I find it best if you lay the towel on grass and lay the bumper on top of it. Heat the inside of the bumper a little at a time checking the flexibility every 30 seconds, longer if you use a hair dryer. Press and hold the bumper in the correct spots till they cool. If the bumper is still warm there is a chance the bumper will not set correctly. It is almost impossible to get the entire dent out, but should get it damn close if you take your time and have patience.
This is my finished bumper prior to touch up paint.
If this post helps at least one person I won't feel like I wasted my time :P Good luck to you all.
Skoobaru05 is offline   Reply With Quote
Old 12-20-2011, 12:50 AM   #2
Skoobaru05
Member#: 296923
2005 Impreza WRX
Subaru Blue
If I missed a step that anyone sees let me know, I took like 30 pics I probably just lost one as I was watching a football game while writing this.
Old 12-20-2011, 07:05 AM   #3
Omega_2nr
Member#: 298119
Excellent post man - and good info on the heating of the rear bumper. This should come in handy 8)
Omega_2nr is offline   Reply With Quote
Old 02-11-2012, 11:50 PM   #4
enlighten
Member#: 261806
Subaru Stars
thanks for the write-up...
I had a similar mishap.
I got the big part of the dent out with a $12 heat gun from Harbor Freight
How did you smooth the edges out?
Did you use a metal block or any other tools?
enlighten is offline   Reply With Quote
Old 05-28-2012, 03:03 PM   #5
Blueboost
Member#: 80467
04 JBP STI
04 WRB STI R.I.P.
Thumbs up Excellent write up.
Just replaced my 2004 sti rear bumper.
Excellent job explaining and good pictures!
Blueboost is offline   Reply With Quote
Old 07-05-2012, 09:28 AM   #6
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Nice. Use the heat gun. It's worth the ten bucks at Harbor Freight.
sackytar is offline   Reply With Quote
Old 11-26-2013, 01:22 PM   #7
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Do you happen to have pics of the foam and bumper beam itself? I'd like to see how the whole thing fits together and attaches.
Some idiot rear ended me and I'm probably going to have to replace the rear beam.
EDIT: ah... I haven't visit Oswald in awhile... found this:
http://www.oswaldperformance.com/Doc...structions.pdf
and this
chimchimm5 is offline   Reply With Quote
Intake manifold removal 05 WRX ganzhimself Newbies & FAQs 1 07-05-2011 06:46 PM
NJ: WRB Chargespeed V1 Front Bumper, WRB 05 WRX Rear Bumper, Front Bumper Beam wrxwhip Exterior/Styling 14 09-30-2008 11:25 AM
how to remove 06 wrx/sti bumper? scoobyc Interior & Exterior Modification 3 09-04-2007 03:14 AM
FS: 05 WRX Front bumper,exhaust, IC, TANABE GF210 SPRINGS boost4life MAIC Private Classifieds 10 03-16-2006 12:05 AM
Factory Cd player removal 05 WRX warrenglas Car Audio, Video & Security 3 09-04-2005 08:15 PM
