Old 12-20-2011, 07:53 AM   #1
05flat4
Member#: 293121
2008 Legacy Spec.b
QGM
Default 2005 wrx motor replacement/rebuild
I am looking for a motor for my 2005 wrx. It currently has rod knock. It isnt bad, still runs fine. I need to get my DD back on the road. Can somebody point me in the right direction to get a new motor. Ideas I have tossed around
Stock 2.0 swap.
Build my current block with forged internals
sti longblock swap using stock heads.
My budget is 5 grand. Open to ideas and any help. goal for this car was about 280 WHP on stock turbo. For my budget I just dont think its gonna happen. I have an installer and I am very willing to pay shipping cost to get motor hear.
05flat4 is offline   Reply With Quote
Old 12-23-2011, 02:05 PM   #2
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
How many miles on the current long block? If <80K you could just swap the short block with and OEM for ~$1800 bux + labor + ~$700 in gaskets, fluids, bolts.
If >80K miles you may need headwork and while in there you might as well swap oil & water pumps and timing belt too, and all that installed (with the above) will come dam close to $5K. Heads on EJ205 can be pesky (albeit 05s are a bit better than 02/03s), some develop hairline cracks around plug holes and on hi mileage engines valve seals will need replacement. (basic decent head jobs are ~$500)
a (re)built longblock ej205 with moderate aftermarket parts (perhaps even a 2.1stroker) and fresh everything will run ya ~$8K installed
Other option is to consider a CCR engine for ~$4.5K New everything, in and out in a day at your local shop. www.ccrengines.com
REDrum is offline   Reply With Quote
Old 12-23-2011, 05:47 PM   #3
05flat4
Member#: 293121
2008 Legacy Spec.b
QGM
its gonna cost me 1500 for a install. Just gonna be a bit outa my range. Thanks though REDrum.
Old 12-27-2011, 08:51 AM   #4
05flat4
Member#: 293121
2008 Legacy Spec.b
QGM
MOTOR PURCHASED. I got a built stage 0 motor from S and R performance. They have helped me so much with the whole process. Thanks marti for being such a help. Engine is going to be installed by andrewtech in maryland.
HELP! Rebuild 2005 wrx motor in northern Virginia. 05flat4 Built Motor Discussion 44 01-03-2012 07:16 AM
Fs 2005 Wrx Motor Complete 50k richy_21 Engine/Power/Exhaust 17 08-01-2010 03:52 AM
2002 WRX Motor Needs Rebuild, make an offer! bdr2488 Engine/Power/Exhaust 16 03-22-2010 01:45 PM
WTB: 2005 long block or complete wrx motor replacement Saabaru flat Private 'Wanted' Classifieds 2 10-06-2009 01:56 PM
f/s 2005 wrx motor meglissWRX Engine/Power/Exhaust 0 09-20-2008 12:58 PM
