Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 12-20-2011, 07:43 PM   #1
Ko3n3k3
Member#: 273925
Default Wiring 2002 WRX Harness to V7 207 ECU
I have created a spreadsheet comparing these two pin outs and have ran into a problem with the Fuel Pressure Sensor Signal Wire. On the WRX it is saying that it is B135 / 15 (B15) and it is no where to be found on the 207 Manual. Any help would be appreciated.
Here is a link to the Pin-Outs I am using.
2002 WRX: http://www.northursalia.com/modifica...ng/wrxpin.html
and
V7 207 : https://docs.google.com/open?id=0By8...I0YzNmMzcwNGZi
So far I am thinking these are the changes I have to make
Switch C15 to C16
splice A5 off of a16
and I'm having problems with Changing B15 to B8 since B8 is already something.
Any help is greatly appreciated.
Ryan
Ko3n3k3 is offline   Reply With Quote
Old 12-21-2011, 08:13 PM   #2
Ko3n3k3
Member#: 273925
If anyone knows anything it would be very helpful. Thanks
Old 12-24-2011, 02:34 PM   #3
N8WRX
Member#: 99395
2015 Impreza WRX
World Rally Blue
if your putting a v7 jdm ej207 into a 2002 usdm wrx all you need to do is plug it all in. ECU will plug in and match up and the head connectors as well. The only difference is they add 8 wires (4 passenger side, 4 drivers side) for AVCS in the JDM cars. IAperformance sells a plug and play kit you just remove the pin blocks and install the wires running 4 from the passenger head pin block and 4 from the drivers one right to the ECU. they use all the same pin blocks just the USDM cars they left those spots for the AVCS empty. its about the easiest swap you can do.
N8WRX is offline   Reply With Quote
Old 12-24-2011, 02:40 PM   #4
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
This. It's a plug and play affair.
Kris.is.awesome is offline   Reply With Quote
Old 12-27-2011, 09:03 PM   #5
Ko3n3k3
Member#: 273925
Idk guys ... I have looked at pin outs for both and found several differences. See these links please. I pray it is plug and play but please tell me the validity of these links
USDM 02 WRX: NorthUrsalia.com: 2002-2003 WRX ECU Pinouts
JDM 2002 STi: http://bebeu.free.fr/43R-STi_Eng.pdf
and these are the differences between the two in spreadsheet form from the links above
https://docs.google.com/spreadsheet/...URBZ0hzRGxqaXc
Old 12-27-2011, 09:37 PM   #6
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I'll say it again too....its plug and play.
You can run/repin the AVCS through the TGV wires since they are shielded and go directly to the ECU, or get the IAP harness kit like N8WRX mentioned. Besides the AVCS the only other difference is the JDM EJ207 does not run one of the sensors on the TB. I think its the temp sensor or something, all that you need to do with that is leave it unplugged. If you pin out all the pins on the ECU in the JDM vs USDM harnesses with the diagrams you will see the holes where the AVCS goes is empty on the USDM harness.
.....I dont like the www.northursalia.com thing its not helpful at all. cross reference the EJ207 info on here....
http://www.ej207.com/files/Subaru%20...e%20Manual.pdf
dangerousatom is offline   Reply With Quote
Old 12-28-2011, 05:26 PM   #7
Ko3n3k3
Member#: 273925
Sorry to be repetitive and moronic I just want to be sure, here is what I'm doing. Putting an 02 WRX harness into a v7 EJ 207 ECU with an IA performance AVCS kit. All of this is being hooked up to a v7 207 engine with v8 207 heads in an RS 2.5. The wiring combo of 02 WRX harness in v7 207 ECU should be plug and play?
Old 12-29-2011, 02:11 PM   #8
N8WRX
Member#: 99395
2015 Impreza WRX
World Rally Blue
if your in a RS and using the stock Chassis harness then no its not plug and play and wiring is involved. If you are in a 2002-2003 WRX with the stock chassis harness and the stock ej207 engine harness it is as we described plug and play. There are 2 harnesses at work here chassis and engine. as far as ECU you can plug in a v7, v8, usdm wrx, and have them all work. the usdm wrx will not run avcs, either jdm ecu will.
Old 01-04-2012, 07:56 PM   #9
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The diagram that you are looking at is more than likely a UK diagram and yes there are a few differences. The JDM pinout is the same as the US with the exception of the AVCS.
Zephyr is offline   Reply With Quote
Old 01-31-2012, 06:59 PM   #10
ECMFab
Member#: 281995
^^Im getting ready to do the same thing pretty much. Ive been reading over and over all kinds of stuff and I wish someone did a write up on a how to or something. Im finding quite a bit of conflicting info.
I dont want to have to buy the ia harness if I dont need it. I have a bugeye and WRX chassis harness, v7 ECU, and v7 engine harness. I also have the WRX engine harness in case I need to cut out some connectors, but I think the v7 harness has them plugged in already. What are the "shielded" wires? Do I just need to repin the factory wires that used to be the TGVs?(on the chassis harness) Shouldnt those be the wires I need to relocate on the harness inside the car?
ECMFab is offline   Reply With Quote
Old 05-20-2012, 05:03 PM   #11
ViperWRX
Member#: 111870
02' JDM STi Swap
VF37 w/20G (337 awhp)
Here is a little diagram of what I made a few years ago when doing my 04' JDM EJ207 STI swap in my 02' USDM WRX. The shop that helped me over the phone is S.w.a.p.shop but used to be known as JDMSpecC. Hope this helps anyone else with current or future swaps. This is for wiring up AVCS exc...
2002 WRX ECU
Add Wires:
E1 Plug (Light Gray)(Located just above the turbo) to E:B84 (located at the ECU/ECM)
E1: 5 to B84:15
E1: 8 to B84: 9
E1: 9 to B84: 3
E1: 10 to B84: 2
Relocate Pins:
E:B84
Plug 4 to 6
Plug 5 to 12
Plug 11 to 17
Plug 10 to 16
F61 (Black Plug)(Located right behind the battery but infront of the Windshield Washer Resevouir)
Plug 5 to 1
Plug 6 to 2
Plug 7 to 3
Plug 8 to 4
ViperWRX is offline   Reply With Quote
Old 06-09-2012, 01:17 PM   #12
Stretchvelcroy
Member#: 299169
2002 Wrx/JDM STi v.7
Dirrrty
2002 WRX ECU
Add Wires:
E1: 5 to B84:15
E1: 8 to B84: 9
E1: 9 to B84: 3
E1: 10 to B84: 2
Relocate Pins:
E:B84
Plug 4 to 6
Plug 5 to 12
Plug 11 to 17
Plug 10 to 16
Plug 5 to 1
Plug 6 to 2
Plug 7 to 3
Plug 8 to 4
Thank you!
You deserve cookies!
Stretchvelcroy is offline   Reply With Quote
Old 06-12-2012, 04:05 PM   #13
SomDong
Member#: 274776
Sorry to bump this up.
But if you have a 02 wrx and a V7 EJ207 with harness on the engine. You don't need to swap any harnesses? You just drop it in and plug the big connectors in?
SomDong is offline   Reply With Quote
Old 06-12-2012, 04:12 PM   #14
ECMFab
Member#: 281995
You can plug them together and it will run, but you need to repin the TGVs to the AVCS and also add some shielded wires. Easiest way to do this is get the cut chassis harness like I got with mine. I was pleased to find out that the wires took a turn by the cut harness and in fact were whole and complete. Just re pinning necessary at that point!
Old 11-06-2012, 06:22 PM   #15
AdventureBug
Member#: 258848
02 Wagon 76HTA
Subiscribe, by far the easiest one to follow! anybodyhave any issues with any of the steps on here or did they work okay?
AdventureBug is offline   Reply With Quote
Old 12-06-2012, 02:11 AM   #16
. o 69 o .
Member#: 124938
Here is a little diagram of what I made a few years ago when doing my 04' JDM EJ207 STI swap in my 02' USDM WRX. This is for wiring up AVCS exc...
2002 WRX ECU
Add Wires:
E1: 5 to B84:15
E1: 8 to B84: 9
E1: 9 to B84: 3
E1: 10 to B84: 2
Relocate Pins:
E:B84
Plug 4 to 6
Plug 5 to 12
Plug 11 to 17
Plug 10 to 16
Plug 5 to 1
Plug 6 to 2
Plug 7 to 3
Plug 8 to 4
so this adds the wires for the avcs solenoids by using the TGV wires, what are the other wires for?
. o 69 o . is offline   Reply With Quote
Old 03-16-2013, 08:43 AM   #17
sub666
Member#: 38052
The wires you are relocating on the F61 plug are the same wires that you relocate on B84?
These wires you have to add, what are they for? Cam sensors? I cannot find the description for these in the ecu pinout. I would like to know what I am doing before making the swap.
E1: 5 to B84:15
E1: 8 to B84: 9
E1: 9 to B84: 3
E1: 10 to B84: 2
sub666 is offline   Reply With Quote
Old 04-07-2013, 11:57 AM   #18
sub666
Member#: 38052
on a 05 wrx plug f61 have already wires on pins 1, 2, 3, 4? what to do with those?
Old 08-03-2013, 10:37 PM   #19
AdventureBug
Member#: 258848
02 Wagon 76HTA
anybody else having an issue where the left avcs stays at 0* jumps to 35* for an instance then back to zero, and the right avcs goes to like 65*?
Also noticed that pin 5 on the light gray plug over he turbo is pin 7 on the DS1 guide...anybody know which is correct? I've tried them both and have the same issue where only L or R avcs works not both.
Old 08-11-2013, 09:15 AM   #20
bipolarnrute
Member#: 340737
Im having issues with my v7 swap, Im getting the P0365 code using an
OBD II sensor. I wont get my Tactrix cable in till tomorrow, im hoping it will help shine some more light on the issue. My car idles Rough and stops after 10 seconds. After searching all night yesterday, checking and rechecking wiring, i still cant find the issue.
I used the pic above to repin the ecu and add the 4 wires. Im gonna try moving pin 5 to 7 and see if that fixes my issue...cant make it worse...can it??
bipolarnrute is offline   Reply With Quote
Old 08-11-2013, 10:05 AM   #21
bipolarnrute
Member#: 340737
Default Which is correct? (for better reference)
2002 WRX ECU
Add Wires:
E1: 5 to B84:15
E1: 8 to B84: 9
E1: 9 to B84: 3
E1: 10 to B84: 2
Relocate Pins:
E:B84
Plug 4 to 6
Plug 5 to 12
Plug 11 to 17
Plug 10 to 16
Plug 5 to 1
Plug 6 to 2
Plug 7 to 3
Plug 8 to 4
versus
Old 08-11-2013, 09:25 PM   #22
bipolarnrute
Member#: 340737
Sooo If I looked at the image from import tuner's swap correctly then they are using Pin 7 instead of Pin 5. Just got out from work and will try it for myself when I get home
Old 08-12-2013, 01:30 AM   #23
bipolarnrute
Member#: 340737
So I swapped out 5 to 7 and still no luck for me the engine however does run longer before shutting off and noticeably not as rough. My neighbor was asleep by the time I got home so I couldn't borrow his OBD sensor to recheck the codes this time around. Tomorrow I should be receiving my openport in the mail. Hope this at least helps someone somehow
Old 08-16-2013, 08:53 AM   #24
bipolarnrute
Member#: 340737
Follow Ds1 Instructions
Old 09-03-2013, 03:30 AM   #25
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
His bout this one fellas, 2004 Wrx. USDM 2.0 harness on an 05sti longblock, but I'm using USDM 2.0 tgvs, intake manifold, cable throttle body and obviously the cam sensor relocation bracket. What do I need to do here? I want to run avcs, I want my 35r tune on my 800cc top feed and fuel tails to actually mak a bit better power down low.... Do I need a jdm sti engine harness and ECU or what. Walk me through this please.
srREXed is offline   Reply With Quote
FS : PA: 2002 WRX Return to Stock!!! (exhaust, ecu, turbos, exterior, etc.) Bugeye_Bull Engine/Power/Exhaust 8 11-14-2011 01:29 PM
FS/FT : TN :*Going back to stock* 02 wrx harness to 04 Sti complete swap Bug_i_Sti Engine/Power/Exhaust 0 03-01-2011 08:09 PM
A/C wiring help, WRX harness with Legacy A/C compressor wiring help mutiger93gt Legacy Forum 3 03-01-2010 06:34 PM
So... 2002 WRX, Timing advance value in ECU = "1" Chi_San Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-12-2009 05:36 PM
2002 wrx harness urabus1 Private 'Wanted' Classifieds 9 12-22-2003 10:19 PM
