Old 12-20-2011, 09:59 PM   #1
VarnishXIII
Member#: 174869
2002 2.5i impreza
Default Hemi v8 swap into 2002 impreza
Ok so this is just mainly a thought I've seen a Chevy ls motor swap into one so I want to know if it's possible to do with a hemi or the smaller v8. Currently this is a back up plan cuz I have a 2002 impreza with a blown motor the plan is to pull the motor and figure out wat exactly is wrong and if it can be rebuilt or not if not im going to swap in a v8 so I'd like to know if anyone has any experience with this and how hard it would be to do?
VarnishXIII is offline   Reply With Quote
Old 12-20-2011, 11:26 PM   #2
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
as long as it fits between the frame rails & you do something for clearance on the hood if you need any, you can ALWAYS fit anything to anything with the custom adapting motor mounts, trans mounts, as well as matching up prob just about any trans to any motor with a bellhousing adapter plate
Exec809657 is offline   Reply With Quote
Old 12-21-2011, 01:30 AM   #3
ArSoN9
Member#: 285777
2004 STi-
Ive seen a couple small block V8 swaps as well as LSX chevy block swap like u said. So we know it can be done, put like the guy above said you will need to fab up some custom mounts and probably a few other parts so ensure everything fits. The tunnel should be large enough to run most trannys but you may have to go RWD since space may restrict the front diff
ArSoN9 is offline   Reply With Quote
Old 12-21-2011, 03:25 AM   #4
fooshsti
Member#: 297045
2005 Stage 2 STi
Why dont you just get a wrx or sti engine and slap it in? I think itll be easier and maybe cheaper too.. Youd have your AWD still also
fooshsti is offline   Reply With Quote
Old 12-21-2011, 04:16 AM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Get a rough measurement of the total height of a Subaru engine, from the bottom of the oil pan to the top of the throttle body. Most engines will be too tall
Get a rough measurement of the total length of the subaru engine, from the crank pulley to the bellhousing. You will find most engines are too long
You can make anything fit but you'll lose power to the front wheels, have to raise the hood and have less ground clearance.
There is a reason so many home made and kit Airplanes/Helicopters use Subaru engines
Old 12-21-2011, 03:27 PM   #6
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
^^the size and the reliable part, its efficient
rebuild your motor or swap in another ej, it'll be much easier, and in the end of your v8 swap after all the $, you might regret it, cool, but not as cool/easy to track down all our bolt-ons avail
Old 12-21-2011, 03:51 PM   #7
jzk25
Member#: 179120
This is correct but not for the reason you think. The problem is the rack is mounted much higher in the engine bay than most cars. Can be changed but not without creating it's own issues with steering geometry.
This is a crossmember I modified to house a toyota engine in a Legacy.
The rack is now a lot lower and will need correcting at the tie rod ends to stop bumpsteer etc.
jzk25 is offline   Reply With Quote
Old 12-21-2011, 05:39 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
there is a guy on here that has a LSX motor swapped into his, i believe it may be still up for sale
fastnoypi is offline   Reply With Quote
Old 01-30-2012, 09:05 PM   #9
VarnishXIII
Member#: 174869
2002 2.5i impreza
i figured out the block is gonna be salvigable so im probly just going to rebuild enless i find a good deal on a sti motor. the thought of swapping in a v8 though is still in my mind ive been working on seeing wat all id need to modify to do such a thing so far i think i could fit a small block v8 in it with not to bad of modifications but like someone said i would have to go rwd and i dont think i wanna get rid of my awd just yet lol
Sti v8 swap into 2.5 CYF313 MWSOC Private Classifieds 6 05-11-2010 07:50 AM
Will a 2003 Forester 2.5 be a direct swap into 2002 Impreza Outback Sport red civic standard Normally Aspirated Powertrain 0 03-23-2010 07:48 PM
sti steering rack swap into 2002 wrx krawwwcu Subaru Conversions 2 05-21-2006 11:36 AM
JDM V7 swap into 2002 WRX, Will it pass NYS inspection?? jonepachek Subaru Conversions 1 08-20-2005 01:25 PM
Jdm Ej20 V7 sti motor swap into 2002 WRX WRXerRacer Subaru Conversions 28 12-30-2004 10:20 PM
