Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 12-21-2011, 08:47 AM   #1
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Question '93 Impreza: No Start, fuel pump?
Trying to get a potential rallycross project off the ground. 1993 Impreza FWD, manual. Been sitting for a while, replaced battery and terminals. Car gets spark and everything else works, cranks like no problem.
Removed the fuel line to the filter, no pressure but fuel was up in there. Cranking, no fuel movement, no noise from the fuel pump. Fuel Pump Relay clicks strongly, 12V at the connector and when switched/energized. Back at the fuel pump connector, I am only seeing 4 or 5 volts.
I really don't want to throw parts at it, as a FPR is $30 and a new pump is $85. The last option is to straight-wire 12V to the pump and make sure it runs I guess.
PS-- added 2 gallons of fuel as well, gauge works and level raised. When I get the fuel pump running, I will try to empty the old fuel out of the lines and replace the filter after running it for a bit to clear the crud.
Thoughts? Thanks!
JamesWilson2 is offline   Reply With Quote
Old 12-21-2011, 08:49 AM   #2
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Last option-- I see that my parts store shows a Fuel Pump Inertia Cutoff Switch for the car. Where might that be located?
Old 12-21-2011, 01:36 PM   #3
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
Just a thought---sounds like a bad wire more than a bad pump. As far as the inertial cutoff---has the car been hit hard at any point?
motohippy is offline   Reply With Quote
Car randomly doesn't start, fuel pump? burritotown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-24-2011 07:36 AM
Car Wont Start... Fuel Pump Not Priming... Any Ideas? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-09-2011 03:35 PM
2.5RS no spark...fuel pump relay clicking polak13 Normally Aspirated Powertrain 8 01-26-2006 03:25 PM
car won't start - no fuel pump sound driver8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-13-2004 07:21 PM
No EM Fuel Pump Upgrade insaneSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 09-24-2004 01:49 AM
