Old 12-21-2011, 03:11 PM   #1
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Default bad FPR or pump?
relatively stock ej20g from 95 WRX RA.
extended crank on startup. priming pump once greatly improves results.
walbro pump seems a bit quieter than it used too. it's 5 years old
will check pressure later today. filter is pretty new
basically, how do i diag whether it's the FPR or the check valve in the pump bleeding down?
thanks in advance
AsphaltsCry is offline   Reply With Quote
Old 12-21-2011, 04:46 PM   #2
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
So pressure gauge in line after filter. Koeo 40, then drops right back to zero. Koer 30, and rises with revs. Disconnect vacuum from fpr, pressure rises.
Sounds like the pump, what do y'all think?
New walbro's easier to get and replace, but how do i know for sures?
Old 12-22-2011, 07:18 PM   #3
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
damn...
all the wiseasses on here and nobody has something to say?!
where's that unclescotty when you need him... or Rob
-jami
Old 12-23-2011, 12:07 PM   #4
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
I could swear that your initial base fuel pressure should be 43psi and that it should rise with revs . So yes you should be looking at replacing your walbro. What is Koeo and Keor ?
TommyAtomic is offline   Reply With Quote
Old 12-23-2011, 12:39 PM   #5
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Koeo- key on engine off
Koer- key on engine running
I thought the pump was for sure quieter, coupled with a lower pressure than spec, condemns it I suppose
Thanks
Old 12-24-2011, 05:46 AM   #6
newblue
Member#: 115019
2002 Impreza WRX
I will say I had similar symptons and it ended up being my FPR.
newblue is offline   Reply With Quote
Old 12-24-2011, 06:02 AM   #7
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
I wonder if the difference between the two failures is which end of the fuel system the pressure loss takes place.
The check valve is at the beginning of the supply side, while the fpr is at the beginning of the return
Perhaps if I clamped off the return, then put the key to on, while monitoring pressure, the outcome would indicate which.
If the pressure remains=fpr and if the pressure still drops= check valve in fuel pump.
Moot point as I just ordered a new walbro...
Old 12-26-2011, 06:49 PM   #8
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
Still waiting on the new pump, however just out of morbid curiosity, i measured pressure again, with the return line clamped next to the filter and to my dismay, the pressure not only remained, but jumped to 65 or 70.
This seems to confirm a fpr failure...
Buehler... bueler... anyone?
Old 12-27-2011, 12:00 AM   #9
suberdave
Member#: 101865
88 GL-10 STi
that would explain the fuel pump getting less loud...
if it is pumping less pressure it will not be as loud as if it is pumping agenst a good FPR at a higher pressure.
i say you should have done this test before ordering a new pump.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 12-27-2011, 12:06 AM   #10
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
No $hit.
Too bad peeps always chime in to confirm a hypothesis I've already tested...
Old 01-05-2012, 07:38 AM   #11
wagonryan
Member#: 163756
1996 R/RA
Look on the bright side: you solved my problem too.
Which fpr do you replace it with?
wagonryan is offline   Reply With Quote
Old 01-07-2012, 07:52 AM   #12
AsphaltsCry
Member#: 65296
1998 low turbo SF
red / black
I used my old 1.8
Bad clutch, bad installation or bad fluid? dawsonj Transmission (AT/MT) & Driveline 13 07-30-2011 11:48 PM
who's badder? big bad john, or bad bad leroy brown? Meat Supply Off-Topic 25 01-28-2011 06:50 PM
A/C pump noise, bad clutch or pressure leak?? MAtwal Service & Maintenance 3 12-29-2009 04:13 AM
FPR or fuel pump problem? Caballero_STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-28-2008 05:57 PM
2 OE FPR or one SX FPR on a WRX bugeye? Rice Devil Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-15-2007 05:37 AM
