Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 12-21-2011, 05:41 PM   #1
Sarerishor
Member#: 132957
2004 FXT
Question Moving from Summit to Salt Lake county, emissions woes
Ahoy everyone, I haven't posted here in a really long time.
Background:
I've had my car registered in Summit county since 2004 under my parent's address - bumming that address like a boss. They've since moved and I need to move registration under my address in Salt Lake county. As you all know, Summit county doesn't require an emissions test. I thought my current setup (see below) would pass emissions without any issues, but unfortunately the Jiffy Lube nearby said "nay" and failed it on the basis that I only have one cat and no o2 sensor.
Official results state:
Catalyst: TAMPERED
OBD System: TAMPERED
Setup:
Catted Cobb DP, WBR catback with resonator on midpipe (forester specific), catless uppipe, AcessPORT stage 2 map
Next Steps:
Judging from some of the threads I've read, mostly dated to 2010, I might just be SOL. Is my only option to put my stock exhaust back on to pass the emissions test or is there a shop which will pass my setup? Alternatively, would a different catback or midpipe with a cat solve the problem? I assume the latter would still have issues with the lack of an o2 sensor.
Thank you in advance for the discussion and I apologize if I have missed a post already in existence which deals with this exact issue.
Sarerishor is offline   Reply With Quote
Old 12-21-2011, 09:47 PM   #2
WarmAndSCSI
Member#: 181155
2008 Evo X
Octane Blue
Is there a reason you cannot use your parents' address in Summit county any more? You're already bending laws to get your car passed and use it legally; I don't personally see the harm in bending another (pointless) law and leaving it registered in Summit county.
WarmAndSCSI is offline   Reply With Quote
Old 12-21-2011, 09:58 PM   #3
Himynameisgreg
Member#: 200420
'15 LR WRX
'05 AW STI Track Car
Originally Posted by Sarerishor View Post
They've since moved
12345
Himynameisgreg is offline   Reply With Quote
Old 12-21-2011, 10:51 PM   #4
toddguy
Member#: 158534
99 2.5 Wagon
76 Datsun 280Z
if it's not too bad to throw on the stock exhaust, i'd just do that. unless you find someone that will do it.
i just feel like it's a stretch to ask a tech to risk his license to pass your stuff.. but that's just me.
:nottryingtobeadick:
toddguy is offline   Reply With Quote
Old 12-21-2011, 11:29 PM   #5
Sarerishor
Member#: 132957
2004 FXT
I absolutely agree. I wouldn't want anyone to risk their license for me unless they already do it on their own for whomever knowing full well the risk involved.
I think I'll probably end up swapping the stock exhaust in for the test... I just wanted to make this thread to see if there were other less time-consuming options which I was not aware of or had not thought of.
Thank you thus far for the discussion.
Old 12-21-2011, 11:45 PM   #6
toddguy
Member#: 158534
99 2.5 Wagon
76 Datsun 280Z
or if there are any emissions techs on this here forum that pass fellow subarus... speak up! if you want to...
Old 12-22-2011, 12:28 AM   #7
azn2nr
Member#: 35276
have the dmv change your mailing address to something else so you still get your mail from them but keep the car registered in summit.
azn2nr is offline   Reply With Quote
Old 12-22-2011, 12:40 AM   #8
ethernet
Member#: 229206
2012 WRX hatch
SWP beautifulness
I'm sure you can find someone that will pass it the way it is. They are around from what I hear. I haven't had to search for one though...
ethernet is offline   Reply With Quote
Old 12-22-2011, 02:25 AM   #9
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
2007 Denali Land Yacht
Thanks for the insightful post.
godfather2112 is online now   Reply With Quote
Old 12-22-2011, 02:40 AM   #10
Momosaurus WRX
Member#: 214737
How did you get a "tampered" for obd system?
Momosaurus WRX is offline   Reply With Quote
Old 12-22-2011, 03:10 AM   #11
WarmAndSCSI
Member#: 181155
2008 Evo X
Octane Blue
Originally Posted by Himynameisgreg View Post
12345
Sorry, read it as "I've since moved."
Old 12-22-2011, 08:29 AM   #12
Eww Evo
Member#: 299687
TT3
06' Wrx Project
It's so hard to pass Emissions crooked -_____-
Eww Evo is offline   Reply With Quote
Old 12-22-2011, 09:51 AM   #13
Whattheo
Member#: 188224
MMV WRX 5D
CGM
Get a PO box in summit county.
Or other illegal ideas;
Make a fake emissions report, can't be that hard and you know that DMV worker doesn't check.
Bribe or threaten black mail to a tester, booze or drugs works well, its not your job to loose.
Steal someone else's registration sticker off there licence plate, you know they don't need it as bad as you do.
Don't register it and run from cops when they try to pull you over, your cars fast right?
The views expressed in this post do not necessarily reflect the views of Whattheo
Whattheo is offline   Reply With Quote
Old 12-22-2011, 10:56 AM   #14
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
I would suspect its the lack of the o2 sensor and the readiness code still being set. No doubt the tech said it was tampered and not the computer reading it out.
smdandb2 is offline   Reply With Quote
Old 12-22-2011, 11:18 AM   #15
zizux
Member#: 199836
2011 STi
Will a Subaru pass a readiness test with a AP installed?
I didn't think they will, especially sense stage II disables codes.
Sounds to me like you failed on visual alone.
It shouldn't be to hard to find somebody to pass you on visual given your down pipe does have a cat. The real issue is that on OBDII+ cars they just plug it in to see if you have any codes relating to the o2 sensors and such. This is the readiness test, you would probably have to uninstall your AP in order to pass this test.
zizux is offline   Reply With Quote
Old 12-22-2011, 01:52 PM   #16
wrxl98
Member#: 101244
2003 wrx sportwagon
silver cobb stage 2.5+
Back in the day under Dear Leader Jimmah Cahtah the national speed limit was 55 MPH. As a result, 90% of the citizen taxpayers (what a concept these days huh?) were lawbreakers.
The OP spent an extra $100 for a catted DP and his tailpipe emissions could be pure as the driven snow but he can't LEGALLY register his car. Pathetic.
wrxl98 is offline   Reply With Quote
Old 12-22-2011, 02:20 PM   #17
Not-EWRX
Member#: 158043
2013 Wrx Hatch
He failed because they have installed new machines that can tell if the ECU has been tampered with. This has been poping up more and more around here. Sounds like Cobb needs to make a fix for the problem and program their software such that these machines can't tell it's been tampered with.
Has anyone else that is running a Cobb modified map passed recently? Post up where you went. I'm willing to bet it's ONLY THE NEW MACHINES that can detect this info.
Not-EWRX is offline   Reply With Quote
Old 12-22-2011, 03:23 PM   #18
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
Maybe it's just me, but I find it rather comical that you make illegal on public road modifications then bitch about not passing emissions.
Never had to worry about that problem
Old 12-22-2011, 07:25 PM   #19
Sarerishor
Member#: 132957
2004 FXT
Even with the stock exhaust on, would I have to uninstall the AP to avoid that OBD from failing as zizux suggests? It's not that big of a deal, just wondering if anyone knows the answer before making an assumption on the matter. I haven't tampered with my setup since putting it together in 2006 so I'll have to re-read some guides to make sure I do it all correctly.
Are there any catback setups, or midpipe which would connect to my WBR axleback, which include a cat? Installing a second cat, uninstalling the AP, and putting an o2 sensor (not sure how this is done) on the DP should fix all of that; I would just run that setup, with the AP installed, after emissions. It kind of makes me sad I uninstalled the stock uppipe, but given the stories I've heard of peaces of the uppipe cat breaking off I guess I'm not that sad.
Sorry I don't know how to embed more than one quote in a post:
@Momosaurus WRX: As previously mentioned, I have an AP installed which tricks the OBD, hence that reading.
@Not-EWRX: I went to the Jiffy Lube on 1700 S. and Foothill... I had a coupon, lol.
@wrxl98: Lol, some people may choose one of those paths.
@zizux: It's possible I failed on visual alone, but with the cat on the Cobb DP and a fat resonator on the WBR catback (could be mistaken for a cat by an unexperienced technician I suppose) I'm not sure. :shrug:
@azn2nr: I was under the impression that I had to move the registration to my current residence.
I don't think any of the language which I've used hints at "bitching about not passing emissions". I have merely stated facts and I was curious how everyone else was handling it themselves if they've encountered the same issue I have. The purpose of this thread was to be insightful and helpful for myself and anyone else who may have this problem now or in the future when they stumble upon this thread. As I was in Summit county before, it was not illegal (AFAIK) since there were no emissions to be passed. Thank you for contributing though.
Old 12-23-2011, 02:23 AM   #20
toddguy
Member#: 158534
99 2.5 Wagon
76 Datsun 280Z
well said sir.
Old 12-23-2011, 08:41 AM   #21
martinez801
Member#: 295702
2004 2004 WRX
If stock parts are put back on in order to pass emissions would a re tune be required when putting your exhaust back in?
martinez801 is offline   Reply With Quote
Old 12-24-2011, 12:46 AM   #22
Sarerishor
Member#: 132957
2004 FXT
It seems to me that you'd only have to uninstall your AP and no re-tune would be required, but someone who knows better and is not speculating should chime in.
@toddguy: Thanks. :wishestherewasapeacehandemoticon:
Old 12-24-2011, 01:01 AM   #23
azn2nr
Member#: 35276
you just need to drive your car nice if you put the stock exhaust back in.
sarerishor, im sending you a pm to clear my coment up.
Old 12-27-2011, 01:54 PM   #24
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
That is what I am curious about.
I wonder how a stage1 car would fare these days. It should pass the visual test completely since technically stage1 is just software.
I have a friend that just did his emissions, and it passed no problems with readiness codes being forced. It was here in the Salt Lake Valley as well.
Honestly, my gut says the ECU Tampered result isnt directly from reading the ecu. I think its from the lack of catalyst/o2 and the ecu saying the system is ready. The techs have to input the results from their visual inspection in order to print the certificate, and if they say o2 or catalyst is not present and the ecu says it is ready and functioning the machine is smart enough to determine the ecu has been tampered with.
Old 12-27-2011, 02:11 PM   #25
Not-EWRX
Member#: 158043
2013 Wrx Hatch
You guys are not looking at the information that is right in plain view. They are hooking up the car to a computer and it is stating the following:
Catalyst: TAMPERED
The reason it is stating this is because you have modified the control systems in the cars computer from their factory setting. The computer is looking at the progaming for the catalyst system on the car and saying "it's ****ed up" "try again". I bet the guy at Jiffy lube is flattered that you thought he would get under the car and make this determination, but he didn't even have too.
It's also stating that the OBD system has been messed with.
What you need to do is find a shop that doesn't have such smart computers. This problem you are encountering is a new problem and didn't exist until recently when some shops got new machines. Wiether or not all shops have these new machines remains unknown.
HAS ANYONE PASSED EMISSIONS WITH A COBB SYSTEM INSTALLED RECENTLY? If so where did you go?
X-country move from Philly to Salt lake! Advice welcomed! Killacush General Community 16 10-21-2011 02:27 PM
Moving to Salt Lake City mongolloid Rocky Mountains Impreza Club Forum -- RMIC 36 07-08-2010 02:22 AM
Motion to deport Lake County from MWSOC Prevent Mid West Subaru Owners Club Forum -- MWSOC 23 06-23-2010 09:11 AM
horatio102 goes to Salt Lake CosmoTheCat Off-Topic 23 03-11-2006 07:30 PM
Moving to Salt Lake, Where to live? Sports Wagon Rocky Mountains Impreza Club Forum -- RMIC 45 04-22-2005 01:52 PM
