Old 12-21-2011, 09:47 PM   #1
BlueBeast83
Member#: 303282
Blue!
Default Broken bolt
Hi all!
I took off the intake funnel tonite to give me some more room to change my headlamp but one of the bolt heads sheared off the bolt...
Any suggestions on how to get the rest of the bolt out of my front under hood piece? Welding is only suggestion I could find in the threads and I was looking for something a little less extreme.
Thanks in advance!
BlueBeast83 is offline   Reply With Quote
Old 12-21-2011, 10:11 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Ok - so not entirely sure which bolt you are referring to, but the general way you remove a bolt with a rounded off or otherwise damaged head is using a drill and bolt extractors (sometimes called "easy-outs") basically, you drill a hole of the right size in the bolt, then thread in the extractor (which is left hand threaded) - as you tighten in the extractor, you will eventually back out the bolt. Make sure you use a penetrant of some sort, as well (pb blaster or the like)
Can anyone tap out a broken bolt tonight? swift2fly Southern California Impreza Club Forum -- SCIC 5 10-23-2004 04:02 AM
broken bolt - now what? voam Brakes, Steering & Suspension 6 10-10-2004 10:29 PM
removing broken bolt Schlogen Service & Maintenance 11 06-21-2004 10:28 PM
broken bolt... Schlogen Normally Aspirated Powertrain 6 06-16-2004 11:00 PM
broken bolt on the wheel hub tdxflex Brakes, Steering & Suspension 4 10-21-2002 02:12 PM
