#1 |
Member#: 61395
Vehicle:2005 WRX CGM |
So my ac compressor just stopped working today. I checked the belt and its fine, the clutch is smooth as butter and the fuse is not blown. I looked at all the connections, plugs and wires and they all look okay, however when I turn the ac on nothing happens at all. It doesn't engage, or even try to engage like its not getting the signal to turn on. Any ideas?
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
The system has a leak and enough refrigerant has leaked out to activate the low-pressure cutoff switch. Take it to a shop and have them put gauges on it, they will probably confirm that the system is either very low or empty. Next step is to locate the leak and repair it.
#3 | |
Member#: 61395
#4 |
Member#: 214971
South East
Vehicle:2005 WRX Silver |
Hey, I have the same issue. Any follow up on whether or not that was the issue? Though it seems painfully obvious that it is, haha.
#5 |
Member#: 214971
South East
curiosity bump
#6 |
Member#: 198067
Vehicle:2009 IMPREZA 2.5i 4d WHITE Premium |
In the past I've used this product with good results on my 2001 Audi A4.
http://www.google.com/products/catal...d=0CH4Q8wIwAQ# |
#7 |
Member#: 61395
I put more refrigerant in the system and the compressor now engages...next step is to find the leak.
#8 |
Member#: 198067
#9 |
Member#: 214971
South East
#10 |
Member#: 214971
South East
The Owner's Manual and the label on the AC heat exchanger lists the refrigerant as being HFC134a. Is this ok to mix with the "recharge kits" that use R134a?
Edit: Sooo indicators online seem to point at they're the same thing... anyone confirm? Thanks. Also, any more opinions on the "stop leak" solutions? Last edited by skep18; 03-19-2012 at 05:12 PM. |
#11 | |
Member#: 198067
If you just add one container with the stop leak, it should be good.
They are the same (hydroflurocarbon). Quote:
#12 |
Member#: 152728
South East
Vehicle:2006 WRX TR WRB |
i had the same problem. Leak was at the lines going in the compressor. Replaced the Orings and everything is fine now.
#13 | |
Member#: 214971
South East
#14 |
Member#: 89963
same problem, i had the system refilled and it still will not engage, even after installing a new compressor and relay. the fuse is good too. seems the ecu is not sending the ground signal to the relay.
Thoughts? |
| Thread Tools | |
| Display Modes | |
| FS/FT : 2002-2005 WRX AC Compressor, AC Condenser, and all AC lines-Entire AC System-$100- | streetking04wrx | Engine/Power/Exhaust | 13 | 02-17-2011 10:39 AM |
| ac compressor pulley won't turn | legacy1907 | Factory 2.0L Turbo Powertrain | 8 | 08-05-2009 01:16 AM |
| FS: AC System AC Compressor/Belt/4 AC lines/Bracket | the real suby dude | Engine/Power/Exhaust | 3 | 03-26-2009 04:51 PM |
| AC compressor and condensor fan won't come on | RSXiMUS | Service & Maintenance | 2 | 05-27-2008 12:44 PM |
| ac compressor, 95 1.8l, need part & help | germanturbo | Service & Maintenance | 2 | 05-01-2006 03:30 PM |
