Old 12-22-2011, 02:36 AM   #1
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Default UOA: 11 WRX, 3296 mi, 5W-30 Castrol Edge Syntec
2011 WRX, 3296 mi on 5W-30 Castrol Edge with Syntec (black bottle).
Looks like I'll be sticking with this oil.
FYI first oil change was factory fill. Second oil change was 5W-30 Castrol Edge with Titanium. Funny how the cheaper Syntec stayed in grade better and had a higher flashpoint. Don't believe all the marketing hype.
furiouswrx is offline   Reply With Quote
Old 12-23-2011, 10:11 AM   #2
bluesubie
Member#: 767
04 FXT
Nice TBN in your NASCAR 20 weight qualifying oil, but you're probably smart to not to run it much past 3k miles. Good moly level in this stuff and that magnesium is way high! I guess this is to help meet the GF5 requirements for piston cleanliness. I wish GF5 also spec'ed improve wear control. I'll be interested in seeing a trend to see if your wear levels remain the same on this N. American Syntec.
-Dennis
Old 12-24-2011, 01:03 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
no 5w30
just no....as in none
Old 12-24-2011, 02:21 PM   #4
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Originally Posted by bluesubie View Post
...and that magnesium is way high! I guess this is to help meet the GF5 requirements for piston cleanliness.
Prices are always changing, but 'classically' magnesium is simply less expensive than calcium, which is the usual alternative, and magnesium 'classically' leaves much harder deposits than calcium.
I must've recollected the specs incorrectly. I had recalled that the last spec or two tightened wear control requirements noticeably. Not directly, but by making the test tougher while keeping the wear limit the same. Am I thinking of a different spec?
bulwnkl is offline   Reply With Quote
Old 12-24-2011, 11:09 PM   #5
bluesubie
Member#: 767
04 FXT
Ahh, so that's probably why RT6 is so cheap.
Wear control for GF5 appears to be the same.
http://www.gf-5.com/the_story/performance/
-Dennis
Old 12-24-2011, 11:45 PM   #6
kh15
Member#: 132400
2004 sti
wrb
Originally Posted by Uncle Scotty View Post
no 5w30
care to explain? one guy on a forum vs. a car company full of engineers and hundreds of thousands of Subaru's around the world running 5w30. GO!
You may have had a bad experience but that doesn't mean everyone will. I know guys with early model Subaru's pushing 150k and get their oil changed at quick lube places when every they so happen to remember its time to change their oil. No need to clutter threads up with half (blank) advise that is not properly supported or elaborated on. Not to mention this poor newb just wants to advice as he is probably new to the scene and your just confusing him even more which in turn will make him create a new thread like "what oil weight should i use" and im sure you would love that!
kh15 is offline   Reply With Quote
Old 12-25-2011, 12:33 AM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
people like you make me convinced the human race is d0000med.......
this has been covered, HERE, more times than the Kennedy assassination
and im NOT gonna ****ing go over it again
Old 12-25-2011, 04:46 AM   #8
kh15
Member#: 132400
2004 sti
wrb
car burns no oil, runs strong, oil temp is in proper range, subaru recommends it, my uoa's are great according to blackstone, oil change intervals followed closely, stage 2 at 18psi for the last 80k...Uncle Scotty says im wrong!
I give up!
Old 12-25-2011, 08:30 AM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I give up!
hey...guess what...sometimes they DONT blow up
YOU got lucky.....maybe because you change it too often for it to get too thin
others arent that smart......
weiner....weiner!!!!!!!!! you just won the short bus trophy....next up......the 'I spent too much on oil changes because I think I'm doing it right'
what the **** ya want???
a ****ing cookie????
Old 12-25-2011, 08:40 PM   #10
kh15
Member#: 132400
2004 sti
wrb
Merry Christmas cool guy
Old 12-25-2011, 08:46 PM   #11
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I run German Castrol which is 0w30
LIQUIDSK8S is offline   Reply With Quote
Old 12-25-2011, 09:16 PM   #12
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
^^ Can't even start to compare this with most 5W-30's. It's in it's own class. RP
drivin blind is offline   Reply With Quote
Old 12-25-2011, 09:45 PM   #13
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
True, it's best compared to 5w40's......of which it bests most of them.
Old 12-26-2011, 01:31 AM   #14
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
which brings up another point......with SO MANY readily available oils that are SO VASTLY SUPERIOR TO VIRTUALLY EVERY 5W30 that one could buy and use, instead......and suffer NO ill effect what so ever.....and with which you could at LEAST double your oci....which would make BETTER OIL cheaper overall....
why the hell would you want to buy and use inferior oil at all
this baffles me to no end
Old 12-26-2011, 02:03 AM   #15
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Could be worse.......he could've been running Mobil1
Old 12-26-2011, 05:05 PM   #16
kh15
Member#: 132400
2004 sti
wrb
This comment is not intended to start any arguments or debate wars!
... Shouldn't all these opinions on oils be in the least supported by UOA's? Unless you know all the specific specs and tolerances of your motor how can you properly tell if your car runs best on a particular weight? And if its burning oil or not is a poor answer because that could be a handful of other issues.
Old 12-26-2011, 06:42 PM   #17
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
you dont read this forum much, do you????
there are many-MANY uoa's posted here and on the bitog site
they all tell the same story....
5w30 is, almost universally, bad....mmmmkay??
Old 12-26-2011, 10:20 PM   #18
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
-Dennis
I may have been thinking of Sequence IIIG, which is indeed tighter for GF-5 vs. GF-4, but in the area of piston deposits, not valve/lifter wear. The Sequence IVA test was tightened for GF-4, but left along for GF-5. Either way, I was behind one spec change in my recollections.
Old 12-27-2011, 02:25 AM   #19
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Just posting this for community information. This 5W 30 does work when changed at 3300 mi intervals. No abnormal wear and good TBN. I'll probably switch to 5W 40 Rotella T6 in the summer.
Old 12-28-2011, 12:35 PM   #20
cleans13
Member#: 172919
2002 wrx hybrid
psm
my turbo's been drinking my shell rotella t6 5w40. it's pissing me off. it's getting cold so i need to switch to a thinner oil. do they all end up drinking oil?
cleans13 is offline   Reply With Quote
Old 12-28-2011, 06:13 PM   #21
bluesubie
Member#: 767
04 FXT
The cold cranking viscosity for 5W is measured at -30C. http://www.pqiamerica.com/coldcrank.htm
If you still want to go thinner than RT6, there's M1 0W-40 or GC 0W-30. Oil consumption is a mysterious thing and thicker viscosity doesn't always mean less consumption.
-Dennis
Old 12-28-2011, 06:50 PM   #22
flycaster
Member#: 60142
2011 WRX
Grey
If my car was "drinking" any oil, I'd be looking elsewhere for the problem. Moreover, we see temps here down to -10f, and I run T-6 all year. No cold crank issues at all, none.
flycaster is offline   Reply With Quote
Old 12-28-2011, 06:55 PM   #23
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Although it's heresy to most, RT6 was consumed by my Baja every bit as fast as any 5W30 ever has been. It also DESTROYED my mpg. 'Regular' 10W30s are not consumed so fast in my Baja as RT6 was, and they give distinctly better economy; it (RT6) was very disappointing. So, YMMV.
Old 12-28-2011, 07:01 PM   #24
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
I used Valvoline NextGen 5W30 recycled oil for these results. I doubt Uncle Scotty can argue with the results.
mikeythejew is offline   Reply With Quote
Old 12-28-2011, 07:02 PM   #25
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
double post
UOA: 2011 WRX @ 25K mi - Subaru Synthetic 5W-30 kingme Service & Maintenance 25 10-26-2012 01:37 PM
UOA: 05 2.5RS, 5124 mi, 5W-30 Pennzoil Platinum ScottyB Service & Maintenance 4 12-21-2011 11:21 PM
UOA: 11 WRX, 3182 mi, 5W-30 Castrol Edge Titanium FST furiouswrx Service & Maintenance 8 10-31-2011 01:08 AM
UOA: 2003 WRX 150k Castrol Syntec foxboroxt Service & Maintenance 5 03-31-2008 09:13 AM
UOA: 2006 WRX 5MT Castrol Syntec 5w-30 Mind Service & Maintenance 18 03-08-2007 09:29 AM
Message Board Statistics All times are GMT -4. The time now is 11:33 AM.
