Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 12-22-2011, 10:25 AM   #1
P-Train
Member#: 279233
2008 WRX
Default Royal Purple Maxfilm
Not sure if this is the right section for this, but has anyone on here used Royal Purple's Maxfilm penetrating lubricant. It looks like a quality product I just am looking for some firsthand opinions of it.
P-Train is offline   Reply With Quote
Old 12-22-2011, 11:26 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
OK....here's what ya do
get 1qt bottle of the cheapest Dexron ATF you can get at advance auto or p00p boiz or autozone
then get a quart of acetone from walmart or lowes or wherever
get an old oil bottle and dump half the atf in that and half the acetone in.......pour the rest of the acetone in the atf bottle
the result will be 2 quarts of the best ever---not kidding.....rust buster fluid you will ever use
and you likely spent less than $4 for 2 quarts which should last for a LONG-LONG time
Uncle Scotty is online now   Reply With Quote
Old 12-22-2011, 11:45 AM   #3
P-Train
Member#: 279233
2008 WRX
Interesting, I'll have to give that a try. I've always used PB Blaster. I'm asking about the maxfilm from a lubrication standpoint vs just a rust penetrator.
Old 12-22-2011, 12:42 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
meh.....i wouldnt buy anything that says 'royal purple' on it
if you want the BEST....or as good as ya gonna get for a REASONABLE amount of $$$
look at LPS products...they are all the REAL DEAL
http://www.lpslabs.com/product_pg/lu...Lubricant.html
I have used many of these and the results have always been outstanding
Kroil is also an excellent product
http://www.kanolabs.com/
Old 12-22-2011, 12:52 PM   #5
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
And they say Scott is a meanie....he probably just gave you the best advice on all counts ever.
Old 12-22-2011, 02:00 PM   #6
P-Train
Member#: 279233
2008 WRX
Thanks! I've used some of LPS's high pressure bearing grease at work and it served me well.
Also where do you come up with your concoctions? I've seen the transmission cocktail and I will probably be throwing that in my car since I've been getting some grinding. Do you just pick up products and try them?
Old 12-22-2011, 02:07 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I identify a need and research things and see what happens.....I didnt invent the ATF/acetone mix....that is an OLD-OLD redneck solution to not havin to drive to town and spend $$$ on PB Blaster
and I have found that I like the Liquid Wrench better than PB Blaster as well
Old 12-22-2011, 02:21 PM   #8
P-Train
Member#: 279233
2008 WRX
I see... thanks for passing on the redneck wisdom good sir.
Royal purple Purple ice Coolant additive bjonga Engine Management & Tuning 3 08-08-2004 09:47 AM
Royal Purple Engine Oils???? JoeBloggz23 New England Impreza Club Forum -- NESIC 6 04-24-2001 08:41 AM
('93-'01) Vendors who resell Royal Purple or Redline North Ursalia Impreza Forum 1 04-13-2001 08:06 PM
Royal Purple Racing Oil STi-Nismo Dood Normally Aspirated Powertrain 15 02-15-2001 06:38 AM
Royal Purple Oil. wrxman555 Normally Aspirated Powertrain 15 10-23-2000 06:12 AM
