Old 12-22-2011, 10:01 AM   #1
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Default JPM Coachworks | Shift Boot, E-Brake, Armrest install
Hey Forum,
Today I received a great shipment from JPM Coachworks! Since I couldn't easily find installation instructions I decided to do another write-up.
Check out my full build thread if you are interested in more write-ups! Here is the link.
Completed picture, write-up below!
My other mods on my 2011 WRX Limited Hatch are below
This is the 7th modification on my car as of 12/22/2011. First six are below.
Mod 1 - Kartboy Short throw w/ Bushings install
Mod 2 - IAG taillight kit install
Mod 3 - Stance Coilover install
Mod 4 - Satelite Radio install
Mod 5 - Footwell Illumination install
Mod 6 - Invidia DP & Exhaust Install | Video, Sound & Pics
I always thought these three interior parts on the Subaru really come across looking cheap. Also, since I love Alcantara® I decided to go that route instead of leather.
Please check my Short Throw install if you need to know how to take the center console apart...
Here are the Pics...
Stock shift boot in console.
Underside of the boot and console.
Shift boot removed from console.
Stock boot removed from plastic ring.
New boot ready to go on, the large tab on the bottom matches with the large cutout in the new boot.
A little mark of a true craftsman....
New boot mounted on the plastic ring, ready to install back in console.
Finished
I used the stock ring inside to attach to the stock boot. I did not glue it in like the factory piece because I was able to snap it to the stock knob without a problem.
Overland04 is offline   Reply With Quote
Old 12-22-2011, 10:07 AM   #2
Overland04
Member#: 293311
2013 FXT 6-Speed
Time for the E-Brake Boot...
To remove the stock e-brake boot form the car, you need to un-snap the plastic ring by pulling up from the console. Do not try to pull out towards the drivers seat, it may break and that would suck... Also, you do not need to remove the stock e-brake handle, the stock boot slides over the handle and the new boot will slide back on. The handle is glued and needs to be heated or cut to remove.
Here is the stock boot off the car.
Stock boot removed from the plastic trim piece. Lots of glue to clean off!!
I used mineral spirits and a solid hour of time to peferctly clean all the glue off... DO NOT TAKE SHORTCUTS.... MAKE SURE IT'S CLEAN!!
CLEAN!
Ready to glue. Remember to test fit to get an idea of where to glue and where to position the boot once it's glued. Come up with a game plan because once it's glued you will be surprised how difficult handling the boot is without getting it stuck to the wrong part of the trim piece.
I taped off all of the areas the I didn't want glue, all the tabs and such...
Time to glue! I used 3M #90... Home Depot, $12.99 Don't use anything lower in strength. Also, it has a very precise spray tip compared to the cheap crap.
Spray the glue as evenly as possible to the plastic trim. Try to get it in every location that was covered from the factory.
Time to glue the boot. I did cover the entire boot with painters blue tape to protect the material from glue on the outside. Nothing worse than having a spray across your new boot, you will be really pissed if you do...
Try to get it as close to the factory as possible. Since the vinyl boot is so thin, you will find that it is a little tougher to get in those tight corners with the thicker material.
Old 12-22-2011, 10:10 AM   #3
Overland04
Member#: 293311
2013 FXT 6-Speed
Lastly I did the armrest cover...
I feel they did a great job making the cover so we can install it without sending it to them, but... I have a couple issues to talk about.
One is that I was hoping to get the foam padding with the cover. It seems that they designed the cover to have padding but didn't supply it or give instruction or suggestions on what to use.
Second, since I had no instructions I took a guess on what to do and felt I didn't make the best choices...
I thought I wanted to glue the top of the cover, I still don't know if it's right or wrong but it's going to be tough to take off if you make a mistake or wear the material off. I also made the mistake of getting glue on the stitched seams inside. It wasn't a problem until I pressed down to secure the material to the top of the cover and the glue came through the seam to the outside, GRRRRRRR!
Lastly, I still really want padding. I don't have any fabric stores near by so unless I took another guess on what to get and buy something online, I'm stuck with what I got from them, which was nothing.
EDIT: I have to give a huge thank you to Alex at JPM Coachworks for reading this post and taking the highest customer service award for offering to re-cover my armrest with padding and to write new instructions for their customers to use! I sent my armrest to them and it came back flawless. I can't say enough, thank you!!!!
Here is the stock cover.
Remove the 6 screws, then once the inside cover comes off, you will see one more underneath that needs to be removed to get the top cover off...
Once removed, glue the underside of the cover as shown and the inside 2" of the new material. Be sure to protect the outside of the material with blue tape and DO NOT GLUE NEAR THE STITCHING!!
In the picture above, the orientation is upside down!
The material says "FT" which is the front and it matches up with the plastic cover opposite as shown. The plastic cover is upside down in the picture!
Sorry for the confusion...
I lined up and centered the top first then did the same with the bottom. Worked my way from the center out towards the sides. Once I was happy with the stitch lines being straight, I tucked the the material around to the backside.
Once the underside is all tucked in tight, you can re-install the cover back onto the console and sandwich the two pieces back together.
Please use the new instructions in the PDF that is in the post below from JPM Coachworks! It's was completed using my actual armrest and possibly some of the instructions form this post, thank you Alex!!
Here are the finished pictures:
Thanks for checking it out, comment or PM me if you have questions!
Old 12-22-2011, 10:26 AM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Great photos and write up! And the end result looks excellent! I don't have much interest in doing this, but I wanted to thank you for taking the time to do this. I'm sure it will help a lot of people!
xluben is offline   Reply With Quote
Old 12-22-2011, 10:41 AM   #5
Overland04
Member#: 293311
2013 FXT 6-Speed
Thank you!! That's why I do it, love to help out others
Old 12-22-2011, 01:05 PM   #6
cliff_11WRX
Member#: 275586
2011 WRX Sedan
290whp 340wtq Cali 91oct
wow that looks amazing! this is definetly on my to do list. Great job on the writeup!
cliff_11WRX is offline   Reply With Quote
Old 12-22-2011, 01:41 PM   #7
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
looks great and pretty much solidified my choice. STi has alcantara and textured black leather on the seat and wasn't sure which to match, but I definitely want the alcantara now after seeing your pics.
and I would certainly want padding. is there nothing you could have removed from the stock cover? I tend to lean on my elbow and have already cracked the plastic top. needs more cushion.
2point0 is offline   Reply With Quote
Old 12-22-2011, 02:04 PM   #8
Overland04
Member#: 293311
2013 FXT 6-Speed
I have to believe that they we supposed to provide padding because there is enough material to support a nice 1/4" to 1/2" closed cell foam or a similar type of padding.
I hope they can either send me some or I'll try to find some in the future if I take a road trip. Either way It still looks amazing!!
Cheers!!
Old 12-22-2011, 09:28 PM   #9
volcom0749
Member#: 151436
2011 wrx
black
wow awesome write up...i ordered mine the other day and they will be in tomorrow...been searching all day for a good write up or video on the install...thanks to you, i now have it...only item i did not buy was the console cover..i didnt see it on the website? i would of definitely ordered that with the shift boot and e brake boot...
disregard that..i ordered mine from rallysport, and they didnt have the arm rest...time to order that now...looks awesome man!
volcom0749 is offline   Reply With Quote
Old 12-22-2011, 10:30 PM   #10
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks Volcom!
Good luck with the install and if you have any questions, feel free to contact me.
Cheers!
Old 12-23-2011, 03:04 AM   #11
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
Awesome write up and install job!
wrxtremeWGN is offline   Reply With Quote
Old 12-23-2011, 12:13 PM   #12
PlanB
Member#: 175608
2006 Impreza
1998 Honda VFR 800FI
Those are some nice and clean looking accessories, and an equally looking clean write-up.
PlanB is offline   Reply With Quote
Old 12-23-2011, 01:48 PM   #13
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
is this like 1000 dollar mod?
Bariga is offline   Reply With Quote
Old 12-23-2011, 02:29 PM   #14
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Nice writeup. I had lots of fun installing the e-brake boot as well. I sprayed the Super 90 in a cup and pasted it on instead of risking overspray. I had leather which is a bit thicker and tougher to fit.
Worth noting that JPM will install these boots free of charge if you send the parts in.
I had my console cover done by them, there was an extra cost for padding, but it has been worth it. I have the JDM console box though. I can't see how one could possibly get an elbow on the stock console lid, unless you run the seat way low? I've always thought it was funny Subaru doesn't have a standard equipment armrest, you have to pay extra for it.
Power6 is offline   Reply With Quote
Old 12-23-2011, 03:19 PM   #15
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
^Yeah, seat is all the way down and almost as far back as it goes. 6'4" so I need the room. Too bad the stupid rear-view mirror is right in my face.
What's this JDM console box you're referring to? The factory armrest extension? The only pics I've seen of that look like it makes the rear cupholder useless.
Old 12-23-2011, 06:35 PM   #16
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Huh funny, I'm 6'2" we might be different shape I have a 36 inch inseam. Seat all the way back of course.
JDM console box is a little nicer than the SOA extender option, it is permanent and adds an upper level of storage. I keep my AP in there.
Either armrest option doesn't stop the use of the rear cupholders. Confession: I actually own both console options, they can be installed together. JPM covered my extending console in leather with red stitching so I couldn't exactly get rid of it. I just use it in the down position with the JDM console. Every once in while on the freeway I pop the extender into "super extendo" mode, which is pretty sweet.
Old 12-23-2011, 06:36 PM   #17
dyltayvb
Member#: 204047
2011 WRX Sedan
This is the JDM Console box he is referring to. You keep the stock box and it adds a separate compartment on top. I have it and its probably my favorite thing Ive bought for my car. Looking to eventually cover it with one of JPMs leather wraps.
dyltayvb is offline   Reply With Quote
Old 12-23-2011, 07:19 PM   #18
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Thank you sir! I need to take some updated pics.
For the console lid, you also have the option of picking up a stock 2010+ STI lid, since that is now padded black leather with red stitching and reasonably priced, if you like that sort of thing.
Old 12-23-2011, 07:36 PM   #19
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Thanks for the pic. You saying the stock lid will fit on top of the expansion? I dig that. My 05 armrest extension w/compartment used a different lid and I didn't like it as much.
Old 12-24-2011, 12:59 AM   #20
dyltayvb
Member#: 204047
2011 WRX Sedan
Yes, the JDM console box uses your stock lid.
Old 12-24-2011, 02:55 AM   #21
1RandomW
Member#: 269224
'11 WRX-4 Door, SWP
it looks really nice
what is the OEM Subaru 5MT Shift Boot Trim Ring and the OEM Subaru Brake Boot Trim Ring ?
did opt for that option or is not needed
1RandomW is offline   Reply With Quote
Old 12-25-2011, 01:11 PM   #22
Overland04
Member#: 293311
2013 FXT 6-Speed
It's not needed, the trim ring is already part of the car. You just reuse the stock trim rings to mount the aftermarket boots.
Good luck!!
Old 12-26-2011, 01:54 PM   #23
Lutz Performance
Member#: 304569
Look awesome!!
Lutz Performance is offline   Reply With Quote
Old 12-30-2011, 08:12 PM   #24
06AWD
Member#: 112843
2011 SWP STI Sedan
Speedline/RCE/Cobb
Just installed my shift boot, e-brake boot and cluster hood with the help of this thread. Thank you!
06AWD is offline   Reply With Quote
Old 12-30-2011, 08:23 PM   #25
Overland04
Member#: 293311
2013 FXT 6-Speed
Awesome!! Isn't their work amazing?!?
JPM Coachworks...shift boot HOTNESS! mattius Interior & Exterior Modification 65 01-18-2012 03:26 PM
FS : Redlinegoods leather shift boot, e-brake boot, and armrest cover for 02-04 DrD Interior/Dressup/Audio & Security 1 09-03-2011 06:49 PM
JPM Coachworks Shift Boots and E brake Boots now available at RallySportDirect! RallySport Direct Interior/Dressup/Audio & Security 15 07-12-2011 01:15 PM
02-03 rs/wrx redlinegoods leather shift boot/e-brake/armrest f/s MaxedOutRS2.5 Interior/Dressup/Audio & Security 4 02-12-2008 04:09 PM
Shift Boot, E-Brake Boot, & Alpinestars Motorcycle Boots WRXerist Private 'For Sale' Classifieds 3 09-08-2005 02:12 PM
