Old 12-22-2011, 12:22 PM   #1
96BARU
Member#: 132319
02 wrx
blue
Default Clutch problems need help please?!?!?!
ok here it goes. I have an 02 wrx with a 2.5 block 5 spd trans wuth an ra gearset. i put in an act extreme with a sprung six puck. installing all went well but the car willnot go in gear at all!!! i have tried bleeding the clutch it was fine and the master and slave are good as well and also tried adusting it on the pedal as well i called act and they said i need to use a flywheel from an 03 and up and that could be the problem. and suggestions?
96BARU is offline   Reply With Quote
Old 12-22-2011, 12:25 PM   #2
lavid2002
Member#: 226864
When someone pushes clutch in can you see the slave cylinder push the clutch fork? Start there...
lavid2002 is offline   Reply With Quote
Old 12-22-2011, 12:27 PM   #3
96BARU
Member#: 132319
02 wrx
blue
Yes it does move
Old 12-22-2011, 12:31 PM   #4
lavid2002
Member#: 226864
When I did my clutch I put the throwout bearing on the clutch fork, then mated the tranny to the engine. I had to press the clutch a few times to get the TB to seat right into the pressure plate because the clutch would just stick to the floor. How did you assemble yours?
Old 12-22-2011, 12:43 PM   #5
96BARU
Member#: 132319
02 wrx
blue
Yes same way it is seated fine that's the werid thing I called act and they said I need to use an 03 flywheel. Idk tho thought they were the same as the 02.
Old 12-22-2011, 06:18 PM   #6
lavid2002
Member#: 226864
I dont know the flywheels to tell you whether they are the same or different.
Look up the flywheels
Old 12-22-2011, 06:21 PM   #7
lavid2002
Member#: 226864
All of the flywheels I see say 2002-2005, I think they are the same
Are you sure you put the flywheel together properly? Was any part confusing to you? Have you done one before? Any other tranny work while it was out?
When you try to put it into gear does it crunch and clank or does it just feel like you're hitting a wall?
Edit" Read your second post about this, I think its pretty obvious that you have a problem where the pressure plate isn't letting off the clutch so the power to the transmission is releived and you can put your car in gear. Your TOB isn't installed properly, the system was bled wrong, or your clutch isn't adjusted properly. I am guessing its the first one.
Old 12-23-2011, 01:12 AM   #8
Tits007
Member#: 238656
2002 UFO
Rally Blue
Try rolling the car back and forth.
Tits007 is offline   Reply With Quote
Old 12-23-2011, 08:10 AM   #9
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
That's not how you lock in the TOB. You have to take the slave off and push the top of the fork towards the firewall to lock it in.
NitroTrike is offline   Reply With Quote
Old 12-23-2011, 02:28 PM   #10
96BARU
Member#: 132319
02 wrx
blue
The stock 02 flywheel is diff then the 03 and up
Old 12-23-2011, 02:31 PM   #11
96BARU
Member#: 132319
02 wrx
blue
Apparently act didn't inform anyone that u must use a 03 and up flywheel. And that goes for the hd and the extreme. I had the hd in it before and went thru two disks in the last 3 years and it's all because the flywheel in pissed all that labor and parts are now down the drained
Old 12-23-2011, 02:34 PM   #12
96BARU
Member#: 132319
02 wrx
blue
Just put the 03 flywheel in and all is good not one prob
Old 12-23-2011, 02:41 PM   #13
BugEyeBetty
Member#: 234645
2002 WRX Wagon
Midnight Black Pearl;
I just replaced my clutch in a 02. with the same problem.. that and my pedal felt like a switch with no pressure.. we had to drop the tranny again after messing with the master and slave cylinders. The throw out bearing was not seated right in the pressure plate.. In the older transmissions its not as easy to seat the throw out bearing. we seated it right and all is well now.
BugEyeBetty is offline   Reply With Quote
Old 12-28-2011, 07:41 AM   #14
lostinthesauce83
Member#: 244473
2005 IMPREZA WRX
I second rolling it back and forth. Or try forcing it into gear with the engine in idle.
lostinthesauce83 is offline   Reply With Quote
MY02 Wagon: New clutch...problems...need help bwawuz Transmission (AT/MT) & Driveline 6 11-17-2006 09:32 PM
Detailed description of my clutch problem need help Norcalrallyist Subaru Conversions 1 10-04-2006 08:59 AM
Clutch problems, need help pinter Transmission (AT/MT) & Driveline 6 07-14-2005 05:52 AM
('93-'01) Clutch problem need help dvs81n Impreza Forum 0 04-24-2001 06:13 AM
('93-'01) clutch problem, need help. Scooby25 Impreza Forum 3 04-14-2001 02:58 PM
