#26 | |
Member#: 315603
Vehicle:2006 Impreza CGM |
#27 |
Member#: 315603
well i got mine fired up tonight.
so if you need any help, i can honestly say i have a running eg33 GD impreza as far as i can tell, and somebody correct me if i`m wrong. but i`m the first person to swap an eg33 into a 2006+ |
#28 |
Member#: 244473
South East
Vehicle:2005 IMPREZA WRX Black |
Oh...ok.. so instead of tapping the g33(which doesn't have a hole for the bolt) you just tapped the tranny and to a larger size and used a shorter bolt.
#29 |
Member#: 315603
exactly
#30 |
Member#: 299703
Loving this thread. I just discovered the eg33 swaps and I think they are awesome. I would love to do a gc swap. where did you get the eg33 from? What would be some good sources for me to find one?
Thanks |
#31 |
Member#: 226864
Vehicle:2005 PSM WRX 18.5lb. 93 oct, DP, UP |
Epic Build! Videos of it running needed
![]() Do you have room to get to timing components once the motor was in place? Or do you have to pull the radiator if you wanted to go down there. What did you do with the motor mounts? ![]() |
#32 |
Member#: 315603
timing belt could be done easily with the motor in the car.
used the ej25 motor mounts, and it dropped right in |
#33 |
Member#: 244473
South East
awesome, I now know what I am doing this sunday. So how does it drive?
#34 |
Member#: 315603
took about 100kms of driving to get the bugs out, but now it drives awesome, tons of torque. acceleration is very uniform which makes it deceiving. it doesn't have that rush when a turbo would kick in. you can mash the gas at any rpm and it just starts pulling. very similar to my old mustang
#35 |
Member#: 244473
South East
nice, because the old ej205 was very anemic. I grew tired of having to stomp on it just to pull out into traffic.
#36 |
Member#: 150922
NESIC
Vehicle:97 OBS EZ30R 94SVX LSi Bourduex Pearl |
Key point bringing up the mustang cause once always felt the Impreza was ver mustang esk being maneuverable and light with good power.
#37 |
Member#: 299703
Either of you planning to add boost?
#38 | |
Member#: 304662
Vehicle:2001 Impreza L coupe Sedona red Pearl |
I know there are/were factory turbo'd ones but they didn't put out as much power as they should from what I've seen and read. So you two have to flip a coin. The loser has to do the turbo build. Cams, pistons, rods, and whatever else. Fair right? ![]() That would be a sick build though. |
#39 |
Member#: 67127
Vehicle:3.3 I <3/h8 my GF3 1.8-2.5-2.2-2.5-2.2-3.3 |
H6 turbo... It's been done.
http://forums.nasioc.com/forums/showthread.php?t=959768 EG33 turbo, it's been done. Mostly in the aircraft industry though. EG33's NA can get 350whp (which is beastly). In turbo form it's a monster, but keep in mind, it's got more displacement than a supra or a skyline, so we're talking a pretty big snail here (or 2). But just think, reliable 600whp subaru? |
#40 |
Member#: 244473
South East
well I do have an Holset he351w turbo, sitting in the trunk of my wrx. But installing that will be down the road. I will need to get the fuel system up to par first, and the turbo as an rpm sensor I would like to tap into.
#41 |
Member#: 315603
boost could be an option in the future. possibly with low mounted twins. first step for me is getting a megasquirt up and running, because the stock ecu leaves much to be desired.
#42 | |
Member#: 304662
I just feel like the h6 got left behind but has soooo much unknown potential. You gotta think. The current 2.5L can run 300, 400, and even 500whp. All from a four cylinder. The h6 can make that reliably like someone said. So it could see 700whp in theory and still have room or more power. Correct? Which is why I'd like to start seeing some more h6 builds. Those coupled to an STI 6mt would just be a dirty set-up. Especially in an older impreza body, like the 93-01 coupes. ::drool:: One of the two recent swap people in this thread were saying how the h6 just pulls at any time. Now imagine that with like 400 more whp and turbo'd! Too bad I'll never be able to afford a crazy swap like this. So I'll just have to wait and see if anyone does it. Which I'm sure people already have but not well documented. |
#43 |
Member#: 315603
the problem with building a crazy eg33 is:
A) engine management. you'd have to run a standalone for sure. B) internal engine parts. crankshaft is good, any sti rods will work, but pistons have to be custom made. aside from that its all fabrication. but if you had the fabrication skills to move the rad forward, you could probably build a turbo set up. |
#44 |
Member#: 150922
NESIC
Well... Bore to 99.5 and use any aftermarket pistons for an EJ25... That's what I want to do in my SVX.
#45 | |
Member#: 150922
NESIC
#46 | |
Member#: 150922
NESIC
#47 | |
Member#: 304662
I think I was thinking of the legacy's that were turbo'd, and related them to the legacy's that have the h6. Somewhere those two thoughts combined for my incorrect statement above. ![]() As a side question, do the legacy's that have the h6 use a 6mt at all? Or are they all auto's? |
#48 |
Member#: 150922
NESIC
In the UK and Aus there are 3.0L Spec B's. US only has the 2.5 turbo Spec B's.
#49 |
Member#: 206851
Vehicle:99 V4 EJ20K RS |
#50 |
Member#: 315603
yeah you say that, but just like when you replied to me in the h6 resource thread you never actually provided any info.
reasons i want to run megasquirt specifically are: - no more MAF sensor - extremely simplified wiring for a cleaner install - boost control - extremely low cost compared to competitors - a sense of DIY accomplishment |
| Thread Tools | |
| Display Modes | |
| 02 wrx or 05 wrx Engine swap | juscool | Subaru Conversions | 5 | 08-29-2009 08:45 AM |
| 05 wrx interior swap for your sti interior | nuhga | MWSOC Private Classifieds | 4 | 02-16-2006 08:27 PM |
| WTT: OH: 05 wrx interirer swap to STI | nuhga | Private 'Wanted' Classifieds | 0 | 02-13-2006 09:51 PM |
| 05 wrx ecu swap to 05 ecutek problem? | nuhga | Engine Management & Tuning | 1 | 11-12-2005 06:27 PM |
| PSM 05 STi for 05 WRX trunk swap | psmBoXer | South East Region Forum | 0 | 10-20-2005 11:07 PM |
