Old 12-23-2011, 07:58 PM   #1
95SubieNate
Member#: 289764
99 rs
Default 99 rs swapped to 02 wrx
how hard is it going to be to swap in an 02 wrx engine to a 99 rs. all i have from the wrx is the motor and most of the wiring harnesses. i have the ecu wiring but not hvac controls. will the rs drivetrain hold up to the wrx? i know i need the turbo front cross member, but what else is needed? and can i get the complete wiring diagrams out of a chilton's manual for each car?
95SubieNate is offline   Reply With Quote
Old 12-24-2011, 10:17 PM   #2
95SubieNate
Member#: 289764
99 rs
any ideas subaru fans?
Old 12-26-2011, 11:13 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I don't think the chiltons manuals have the wiring diagrams, and you will need them. Search for Subaru Tech info and you will find a site where you can pay for a subscription to download all of them. Other searching may turn up the same manuals for free.
The RS drivetrain "can" hold up to the WRX power levels, depending on how you treat it. My '96 L tranny held up for about 3 years after my swap before it broke, but I beat on it pretty hard and was pushing 220 whp the whole time.
By "most of the wiring harness" if you mean you have the whole thing then you have most of what you need. You will also need a WRX fuel pump controller, a new fuel pump (I recommend Walboro), an intake, an exhaust, the front crossmember, a new front swaybar, the MAF sensor, and probably a few other little things I can't remember.
Mechanically it is a simple swap. The wiring is hard and takes some time to do right. If you do it, take the time to go through the wiring diagrams and do it right. When the car starts on the first try and you have no check engine light codes you will thank yourself.
Before you ask a question, search. This swap has been done many times and almost all the questions have been answered already.
speedyHAM is offline   Reply With Quote
Old 12-26-2011, 11:43 PM   #4
95SubieNate
Member#: 289764
99 rs
i see, i have the intake and stock exhaust, i have the complete wiring harness that runs around the front of the vehicle, i dont have the hvac harness or anything going towards the back of the car. thanks for the info man
Old 12-27-2011, 03:52 PM   #5
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Default Here you go
geronimo81 is offline   Reply With Quote
Old 12-27-2011, 03:55 PM   #6
imir designer
Member#: 273377
2000 WRX swapped RS
Volk wearing mofo
^^beat me to it
I have a swapped RS, but I didn't do the swap to be honest. I purchased the car already swapped. It was basically built right in front of me as it went through the process.
If you head over to RS25.com they have a bunch of information on the older GC/GF chassis and swapping. You can definitely learn a lot from that site.
imir designer is offline   Reply With Quote
Old 12-28-2011, 12:01 PM   #7
Brydon
Member#: 107569
1998 Forester S
SRP
Those threads suck.... His car will surely explode from all the power a wrx makes.
Brydon is offline   Reply With Quote
Old 12-28-2011, 01:36 PM   #8
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
^lol does this suit you?
http://forums.nasioc.com/forums/show....php?t=1486051
Haha the wrx isn't that powerful in stock form. I think his car will be fine
Old 12-28-2011, 05:21 PM   #9
Brydon
Member#: 107569
1998 Forester S
SRP
I was joking. I made close to 500whp on the stock RS tranny. No clutch dumps = long life. Infact I snapped a stock sti rod from power before the tranny gave out.
Old 12-28-2011, 09:36 PM   #10
95SubieNate
Member#: 289764
99 rs
niice, good to know fella's. i plan on using the stock rs tranny cuz i like the the gearing.
Old 01-01-2012, 12:43 PM   #11
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Quick on the draw.. search button is yer friend
sense of nature is offline   Reply With Quote
99 rs harness > 02 wrx harness sn3a Subaru Conversions 1 04-11-2010 10:15 PM
2.5 RS swap in 02 WRX...What is needed? Tr2laozboi Newbies & FAQs 7 01-01-2010 11:11 PM
05 lgt swap to 02 wrx XgT Brakes, Steering & Suspension 13 03-02-2008 10:04 AM
FS: UT: OEM 02 WRX springs, OEM 99 RS Springs, OEM 02 WRX Black Scoop - $5 Sandkicker RMIC Private Classifieds 7 12-07-2007 11:45 AM
Problem with swap from 02 RS rotors to 02 WRX D.Sweet86 Brakes, Steering & Suspension 1 11-27-2007 11:54 AM
