Old 12-23-2011, 10:36 PM   #1
NickL
Member#: 280294
87 E30
On Air
Default Kaboom goes a fuel line.
So today I started my car, drove it 10 feet and it sounded like a bottle rocket went off. Not the kapow, but the screech noise. I immediately shut my car off, tried to restart, no avail. Pushed it back and found a huge puddle under the car of fuel.
2002 wrx with an ej257 bottom end and 2.0 heads. I've heard about the recall for the leaky fuel line in cold weather, I'm not sure if my car had it taken care of before I got it. I've never smelled fuel upon start up, but it just got cold.
Anyways, the smell of fuel/ puddle is on the passenger side of the bay. I honestly haven't attempted to track it down yet out of frustration and it being late/Christmas and whatnot, so I'm gonna step away and wait until Monday. All I found from a quick look was there was fuel dripping between the oil filter/downpipe area. I couldn't find anything wet in the bay, nothing, which leads me to believe it's under the intake manifold (yayy), not really.
It's probably a topic no one can help much with, but I figured I'd post up and see if someone could give me some places to check/some ideas of where to check.
Thanks.
NickL is offline   Reply With Quote
Old 12-24-2011, 12:51 AM   #2
hoffmanEstates
Member#: 122043
04 wagonier
psm
Turn key on and start looking for fuel... as the pump kicks on it pressurizes the system
hoffmanEstates is offline   Reply With Quote
Old 12-24-2011, 11:34 AM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
^ yup. Just remember to turn the key off to be safe. And work with a fire extinguisher nearby.
Old 12-28-2011, 01:47 AM   #4
leecea
Member#: 37359
2003 WRX
If the previous owner did any fuel line replacement, maybe they saved a few dollars by not using high-pressure fuel injection hose
leecea is offline   Reply With Quote
Need larger fuel lines, should I delete the EVAP system and use all three hard lines? dexterous Built Motor Discussion 19 04-09-2011 08:39 AM
3/8" fuel lines and factory hard lines? NSFW Built Motor Discussion 14 07-14-2009 10:20 AM
vaccum lines/intake delete setup/fuel lines bloopsta26 Built Motor Discussion 2 10-24-2008 09:09 PM
Evaporation Line/ Fuel Line questions Mnstr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-13-2002 03:17 PM
Getting the fuel lines off the Fuel filter t.rod Service & Maintenance 6 02-16-2002 04:07 PM
