#1 |
Member#: 303141
Currently on ecutek protune by top speed, but now have a Cobb ap I'm wanting to run. I've heard of ppl using the ap to flash over the ecutek. Just wondering if I will lose my protune map ? I'm sure I will but I've heard the ecutek doesn't get erased until I unmarry the ap. thanks in advance!
#2 |
Member#: 303141
anyone?
#3 |
NASIOC Manufacturer
Member#: 4803
The AccessPORT should be able to install over your EcuTEK lock no problem. Yes, you will lose your existing EcuTEK tune -- though your ProTUNER can likely convert your previous EcuTEK tune to an AccessPORT tune for a nominal fee.
Thanks for your interest and best of luck! Cheers Lance |
#4 | |
Member#: 303141
No way i could save the tune myself??? Thanks for the reply! |
#5 |
Member#: 97147
NESIC
Vehicle:2012 wrx gray |
I've got a similar situation. Does the tuner need to have Ecutek equipment to convert it to the Accessport tune? What needs to be done to do this?
#6 |
NASIOC Manufacturer
Member#: 4803
Hi there,
There is no way to convert an Ecutek tune to a Cobb tune other than a tuner who has access to your Ecutek map, the Ecutek software, and the Cobb AccessTUNER software to manually copy the tuning values from the Ecutek tune to the new Cobb tune. You will have to check with your tuner to see if they have that capability and it this is something they would normally do. Bill |
#7 |
Member#: 97147
NESIC
OK, then it can only be done by the original Ecutek tuner, which in my case won't work as he no longer uses or support Ecutek. But I could just load a Cobb stage 2 over the Ecutek tune if I decide that's the route I want to go, correct?
#8 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#9 | |
Member#: 303141
ecutek sucks again!! Thanks for all the help Cobb guys!!! |
| Thread Tools | |
| Display Modes | |
| Cobb AP vs Ecutek | C6turbo88 | AccessPort | 2 | 04-12-2007 06:22 PM |
| Cobb AP or Ecutek ? | PyRoXanDer | Engine Management & Tuning | 0 | 03-22-2007 03:46 PM |
| Torn between Cobb AP or EcuTek`s Easy ECU | SedonaRed03WrX | Engine Management & Tuning | 24 | 11-20-2006 02:39 AM |
| Cobb AP or Ecutek? (Atlanta) | AGL_7882 | South East Region Forum | 23 | 02-08-2006 07:33 PM |
| AP over ECUTEK? (ECUTEK already installed) | byroll01 | Engine Management & Tuning | 14 | 01-13-2006 01:00 PM |
