Old 12-27-2011, 02:01 PM   #1
2002wrxwv
Member#: 291567
Default 02 WRX Problem
Recently had a timing belt, water pump, and new aluminum radiator put on my 02 WRX which has 96,000. After we brought it home it made a whirring sound that was never there before. Then about 300 miles after the job i was on a pull and the tone of the car changed and when i came to the next stop sign it was idling rough and the check engine light came on. I checked the codes with my AP and it said cylinder 1,2,3,4 misfire. Ive replaced the fuel filter and cleaned the MAF. Spark plugs only have 3,000 on them. Any help?
2002wrxwv is offline   Reply With Quote
Old 12-27-2011, 02:09 PM   #2
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
take
it
back
Old 12-27-2011, 02:12 PM   #3
2002wrxwv
Member#: 291567
I live an hour away from the shop. Going to cost me a tow bill. Already called them and they act like its nothing they did and i know they are going to screw me on it. Just gona slap a new part on i dont need and charge me ridiculously for it.
Old 12-27-2011, 02:13 PM   #4
2002wrxwv
Member#: 291567
Also forget to mention that the car runs fine at anything above idle.
Old 12-27-2011, 02:14 PM   #5
Uncle Scotty
OK buy Nates beans
sell it
quick
Old 12-27-2011, 02:16 PM   #6
2002wrxwv
Member#: 291567
Why would I do that?
Old 12-27-2011, 02:21 PM   #7
c10seth
Member#: 258526
2014 WRX Limited
Maybe let the Better Business Bureau know if they are going to be that stand-offish with you? I've had run-ins like that years ago with a motor builder.
Seth
c10seth is offline   Reply With Quote
Old 12-27-2011, 03:23 PM   #8
2002wrxwv
Member#: 291567
Yea idk i just want it fixed
Old 12-27-2011, 04:31 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Find a nearby shop (get recommendations from your regional forum), take it there and have them diagnose the issue and correct it if they can. Then go after the original shop for reimbursement.
It may be as simple as a hose being left off or the belt is off a tooth or two.
Old 12-27-2011, 04:35 PM   #10
2002wrxwv
Member#: 291567
If the belt was off would it run right at regular driving speeds? I feel no loss of power what so ever. Just very rough idling.
Old 12-27-2011, 05:52 PM   #11
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Before you go badmouthing the shop, bring it in and have them take a look - sucks that it's an hour away, but that's the shop you chose. Maybe they'll blame it on something else, maybe they'll see a vacuum hose off which you missed (I am sort of assuming you have been under the hood and verified that no hoses are disconnected or connectors unplugged, spark plugs haven't worked themselves loose, etc.)
What you need to worry about is if the belt jumped a tooth or two (maybe the guides aren't on there right, the tensioner is messed up, etc.)
DrD is offline   Reply With Quote
Old 12-27-2011, 06:50 PM   #12
2002wrxwv
Member#: 291567
I called the shop that did the job and they seemed to careless if it got fixed or not. And they are the closest shop to me as a matter of fact. If it did jump time and is off a couple teeth how would it run fine at anything above idle?
Old 12-27-2011, 11:02 PM   #13
j.boring
Member#: 263605
Will you be home tomorrow I will conte look at it i've had 3 of them leery me know my number is 9970502 tomorrow is my wifes bday so if I don't answer leave me a message I'll call you back
j.boring is offline   Reply With Quote
02 WRX PROBLEM please help ShagginWagon02 Newbies & FAQs 1 08-23-2006 12:09 PM
02 WRX Problem! Help benibarra23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 06-22-2006 11:27 AM
02 Wrx problems newblue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-15-2006 09:53 PM
used 02 wrx problems? justin21 North West Impreza Club Forum -- NWIC 3 12-06-2005 04:08 PM
STI intercooler in 02 WRX problems konradjk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-20-2005 10:49 AM
