Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-27-2011, 01:07 AM   #1
shwoop_soobie
Member#: 102323
99 power poles
beware
Default weird starter problem
hey guys, not sure if this is a general question or technical but mods please move as needed...
my car has a weird starter problem. car is a 99 with an sti swap.
sometimes when I turn the key the starter engages right away and turns the engine over.
other times, the starter will just click. in this instance if I turn the key to start several times in a row, it usually engages one of times. ( click click click click vroom)
and sometimes if I am parked on a slope I can role the car just a little and let it pop in gear to slightly move the flywheel, and then the starter will engage right away; but sometimes this dosn't work.
it sounds like the starter is not getting enough power to crank it or something but it reads 12v at the starter.
from my searching, I did this, which seemed to fix most peoples starter problems, but not mine
-new (not rebuilt) starter
-new battery, new terminals and new starter cables
-cleaned all grounds.
all my interior works when key is in so I'm not sure its a bad ignition switch. but what else is there? something mechanical? something to do with bad wiring in my dash or security system?
any help is appreciated.
shwoop_soobie is offline   Reply With Quote
Old 12-27-2011, 01:16 AM   #2
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
probably bad starter or solenoid to be honest. sometimes when they get old the gear will will stick and won't go in/out like it should.
edit: take it in to get tested (pretty easy to remove) , or just spring for a new one, or even a rebuilt will last several years..
Meat Supply is online now   Reply With Quote
Old 12-27-2011, 01:20 AM   #3
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
Not sure if this info will help you or not but back when i was a Subie tech we used to replace the starter contacts on alot of cars. common problem for the subaru starters from what i remember.
Symptoms were car would start totally normal sometimes but also just click no start sometimes.
We opened up the starter and replaced just the contacts.
bugeye829 is offline   Reply With Quote
Old 12-27-2011, 01:33 AM   #4
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
^i'd check that, many times it's not the starter, but something inside. if you're handy it can be a quick fix, having a shop/repair place do it though and you might be better off with a new/rebuilt, $$ wise.
Old 12-27-2011, 02:12 AM   #5
shwoop_soobie
Member#: 102323
99 power poles
beware
its got a brand new starter/ solenoid in it.
Old 12-27-2011, 02:22 AM   #6
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
hmmmm. weird. it ispossible to get a bad unit. but beyond that i'm not sure...
Old 12-27-2011, 12:44 PM   #7
shwoop_soobie
Member#: 102323
99 power poles
beware
i dono... it is the same thing it was doing before i replaced the starter so i think that its something deeper...
Old 12-27-2011, 03:23 PM   #8
shwoop_soobie
Member#: 102323
99 power poles
beware
nobody has any input?
Old 12-27-2011, 05:38 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check the voltage right at the starter terminal UNDER LOAD as you are trying to start the car. Get a reading when the problem happens. If it's above 10V at the starter when it doesn't crank, the problem is inside the starter. If it's lower, turn on the lights and try again. If the voltage drops and the lights dim when it happens, there is either an excess current draw through the starter or a bad connection at the battery. If the voltage drops at the starter but the lights don't dim, look for a bad connection at the starter or battery end of the starter cable.
Old 01-08-2012, 06:53 PM   #10
Tglazed
Member#: 231216
Hey i am having this exact problem i have replaced everything that you have with brand new oem parts except my battery I went with an optima redline i think its called that has very good cold start amps. I have noticed it happens to me more in the cold weather. Have you figured this problem out yet i have also replaced the clutch switch and that didnt help either I am thinking that its the actual ignition.
My car is also swapped and i am starting to think its a wiring problem.
Tglazed is offline   Reply With Quote
Old 01-10-2012, 12:17 AM   #11
Tglazed
Member#: 231216
Bump this problem up
Starter problems turns into locked up engine problem Minnesota1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-05-2007 07:03 PM
starter problems aschnell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-25-2003 10:33 PM
('93-'01) '98 obs starter problem geepondy Impreza Forum 2 07-01-2003 06:51 PM
Starter problem 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2002 11:30 AM
Starter Problem darkangelgrafix Warranty Issues & SOA Problems 3 09-18-2002 10:28 AM
