Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 12-27-2011, 03:10 AM   #1
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
Default Fuel Pump Controller/Relay compatibility?
Here is the deal after getting into the meat of my swap/conversion I seem to have gotten everything but the Fuel Pump Controller. The clip is an 02-03 JDM WRX EJ20.
After searching through several threads I have seen a few tidbits of info but nothing definitive. Are all the turbo fuel controllers pretty much the same?? If not which ones are compatible?? Need to know so I can track down the proper part.
Impulsivegoat23 is offline   Reply With Quote
Old 01-04-2012, 10:19 AM   #2
wvrallywagon
Member#: 130540
97 GF8, Legacy GT
Aspen White, Rio Red
bump, would also like to know. Basically if an 02 and 05 are the same FPC
wvrallywagon is offline   Reply With Quote
Old 01-04-2012, 06:47 PM   #3
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The fuel pump controllers more or less do the same thing. The best route to go is pick up a 04 WRX unit as it comes with a short pigtail on it which makes it much easier to wire into the system.
Zephyr is offline   Reply With Quote
Old 01-08-2012, 12:40 AM   #4
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
you can wire up any full-on fuel pump through a relay to the WRX ECUs "fuel pump controller signal 1" output if you don't want to mess with a controller. still have to hook up the tank pressure, level sender and fuel temp sensor though. IIRC it chucks a code but you can turn it off. may not though.
glhs377 is offline   Reply With Quote
Old 01-15-2012, 02:29 AM   #5
Impulsivegoat23
Member#: 25761
2002 2.5 RS
Alpine White
Actually picked up one with the short pig tail, believe its an 04 STI controller.
Funny you should mention the tank pressure, level sender and temp sensor as my ecu plugs don't seem to have wires where the pinouts show these should be. I had thought those were related to Emissions standards that were US reated.... any thoughts on this?
Old 02-01-2012, 02:28 PM   #6
drummerdude
Member#: 255999
2002 Impreza RS 5MT
blue
if both can be used, why the different part numbers between sti fuel controller and the wrx fuel controller?
drummerdude is offline   Reply With Quote
Old 07-27-2012, 12:56 PM   #7
sub_sifu
Member#: 301690
bump on this. Mine went bad. I want to know what I can replace with...and ideally just plug in the new one. I don't see why my 02 wrx wouldn't already have this pig tail I can just plug it in to.
sub_sifu is offline   Reply With Quote
Old 07-27-2012, 01:24 PM   #8
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
If you have a WRX and the FPC went bad just replace it with a standard 02 WRX one or go to a junkyard and find one. I have one that I'll let go of. Shoot me a PM.
how to wire twin fuel pumps from the stock fuel pump controller?? DJIMPREZA Built Motor Discussion 5 01-08-2011 12:58 AM
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
05 WRX Fuel Pump Controller, New 650 Injectors, STI Fuel Pump,TXS Catch Cans mrtrex Engine/Power/Exhaust 16 06-09-2008 06:55 AM
93 subaru impreza L fuel pump and relay location fyr3 Newbies & FAQs 0 09-04-2006 04:01 PM
NEED ASAP!: 04/05 STI Fuel Pump Control Unit aka Fuel Pump Controller. dan2304k Private 'Wanted' Classifieds 0 05-25-2006 07:25 PM
