Old 08-12-2002, 12:52 PM   #1
Mr. Addon
Member#: 13499
2002 wrx sedan
sedona red
Default stage 4 [email protected]
I am running the turboxs stage 4 with a vf-30 set at 18 psi. Stock wheels with falken azenis set at 35 psi. My 60'was 1.723 with alot of wheel spin. I might have been able to drop the tire pressure 1 pound or so. Humidity was 47 percent. I had the spare tire out and about 3 to 4 gallons of gas in the tank. Full interior and I weigh 175lbs. The best thing about the night is that I made the quick 16. I was 15 fastest and the only car that was driven there and didnt have slicks on and wasnt on the bottle.
p.s. the track I ran at is 2 degrees uphill. with a high elevation and is supposed to be 2 tenths slower than any other track around. I will be running on Sept. 7 at the all subaru shoot out.
Hope to see you all there.
Neil
Mr. Addon is offline   Reply With Quote
Old 08-12-2002, 01:59 PM   #2
BluSuby
Member#: 12154
04 Sti
99 Outback
Nice run Neil. Where did you run it at? Numedia? BTW The all Subaru shootout is on the 14th not the 7th.
Bryan
BluSuby is offline   Reply With Quote
Old 08-12-2002, 04:37 PM   #3
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Congrats!
Those are really good times with a TXS Stage 4.
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 08-12-2002, 04:50 PM   #4
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Neil, awesome time! And as Bryan asked, where did you run? We'll have to meet up some time!
-Matt
W&L Subaru
Central PA Subaru Enthusiast Group
Shik is offline   Reply With Quote
Old 08-12-2002, 05:19 PM   #5
Romanikque
Member#: 7675
Ah 1.7 60' nice to see some one that can drive their car. Good times.
-MAX
Romanikque is offline   Reply With Quote
Old 08-13-2002, 12:14 AM   #6
Mr. Addon
Member#: 13499
2002 wrx sedan
sedona red
Yes, that is where I ran. Numedia... and thanks for correcting me on the date of the subaru shootout. I am also anxious to me all of you fellow i-clubbers, it should be one interesting day!
Neil
Old 08-13-2002, 01:24 AM   #7
STEALTH-WRX
Member#: 7822
Multi layer snot green
get a bottle, lose some car weight, drop some tire pressure, see your timeslip turn into an 11
STEALTH-WRX is offline   Reply With Quote
Old 08-13-2002, 04:17 AM   #8
wRxbeater11
Member#: 12682
Mr. Addon, whihc intercooler? turboxs or stock?
melo
wRxbeater11 is offline   Reply With Quote
Old 08-13-2002, 07:09 AM   #9
VetteVert
Member#: 5961
2005 STi
CGM
That is a damn strong ET for that MPH, I doubt ET gets much better than that if the MPH doesn't. Either way it sounds like you are one hell of a driver
VV
VetteVert is offline   Reply With Quote
Old 08-13-2002, 08:29 AM   #10
Carlo
Member#: 18376
367 WHP!
460 HP at the crank!
Awesome times on Stage 4
Good Work!
Carlo
Carlo is offline   Reply With Quote
Old 08-13-2002, 11:22 AM   #11
Mr. Addon
Member#: 13499
2002 wrx sedan
sedona red
Melo,
That is with stock intercooler. Mods are:
vf-30
supra fuel pump
sti injectors
ngk pfr7g-11 spark plugs
gram goode up pipe
gram goode turbo back no cat
unorthodox crank pulley
hks evc-4 set at 18.3psi
turboxs unichip stage 4 custom tune 275whp 250.2ft/lb
stock air box with k&n air filter
*stock clutch that is starting to slip at the track after a few runs
kartboy short throw plus bushings
whiteline adjustable rear swaybar set at stiffest
whiteline lowering springs
cusco rear strut brace with v-brace
plus a bunch of cosmetic mods.
NEIL
Old 08-13-2002, 11:27 PM   #12
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
Thumbs up
great numbers, at what rpms did you luanch at.
MAXXPSI is offline   Reply With Quote
Old 08-14-2002, 01:24 PM   #13
Mr. Addon
Member#: 13499
2002 wrx sedan
sedona red
maspsi
I launched at the rev limiter. You GET about 7-9 psi. That is how to get low 60' times. You cant just hold it at a certain rpm and launch. When I did that the last time at the track I was running 13.1-13.2 at 100-102. My new approach dropped my e.t. 6-7 tenths. You must have wheel spin at the line or your car will bog and 60' times will suck.
Good luck,
Neil
Old 08-14-2002, 01:43 PM   #14
nmyeti
Member#: 4980
Originally posted by Mr. Addon
maspsi
Good luck,
Neil
Neil,
I would not suggest a rev limiter drop with stage 4. Phil and I have both had better 60 foot times with a more "normal" launch style. Just make sure you floor it BEFORE you start letting the clutch out.
-Nathan
nmyeti is offline   Reply With Quote
Old 08-14-2002, 02:05 PM   #15
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
Question
ok what i do is i start reving her up to 4grand then drop at 4500 is this what you mean or iam doing something wrong..i
Old 08-14-2002, 05:04 PM   #16
Romanikque
Member#: 7675
Thats the right idea. By taching up to lik 4-4.5 and then a comb flooring a droping the clutch you get the same result of doing a rev limiter drop, but with out as much stress on the car.
-MAX
Old 08-14-2002, 11:09 PM   #17
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
Thumbs up
thanks
Old 08-15-2002, 01:45 PM   #18
Mr. Addon
Member#: 13499
2002 wrx sedan
sedona red
nmyeti,
whatever works for you.
I must be doning something right since Mark said I have the fastest time other then Phil on the stage four and he has a tremendous amount of time on the dyno.
this works for me!!!
p.s. will I see you at the east coast shot out?
Neil
Old 08-15-2002, 02:09 PM   #19
nmyeti
Member#: 4980
nmyeti,
Neil
Neil,
Yes, you'll see me up there...
As for fastest stage 4 time other than phil, that may be true, but again Phil and i have both run faster times with less abuse than a redline clutch drop... its just not needed.
In any case great times...
-Nathan
Old 08-16-2002, 01:27 AM   #20
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
awesome times, I swear you and turboxs and others are trying to steal all my money by making me wanna go further with my car(upgraded to stage 2 this week, may test it tomorrow night at the strip)
Nathan- Any news on your car. Any sea level runs yet and/or future plans to the car( i.e. stg 5- fmic, new engine management, built motor, dog gears )
HS WRB-rex is offline   Reply With Quote
Old 08-16-2002, 09:17 AM   #21
nmyeti
Member#: 4980
Nothing that i am willing to talk about on the I-club.
-Nathan
Old 08-16-2002, 09:36 AM   #22
BluSuby
Member#: 12154
04 Sti
99 Outback
I can't wait until the 14th.... Let see, 10's were run in California, next up Central PA..
Old 08-16-2002, 01:28 PM   #23
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
I see, secret ehh. Well I'll remember to ask around next time I drop by at TXS
Old 08-16-2002, 01:52 PM   #24
MAXXPSI
Member#: 14696
2003 Dodge Silver
SRT-4
Question
any idea what the Stage 5 kit will be. whats left as far as bolt ons, are they going to internal..
Old 08-16-2002, 04:57 PM   #25
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
The things I want the most:
1. Stroker kit - NOT new cams - smog checks are required in most states.
2. Engine managment that doesn't cost an arm and a leg and is still usable by most people.
3. Air to water intercooler - for hot places, I think this is the best you can hope for.
Sordid Philosopher is offline   Reply With Quote
