Old 12-28-2011, 04:49 AM   #1
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Default Kellygnsd's EFR 7670 build
Since the engine in my '07 STi decided to **** itself recently and the 7670 TS IWG housings have been shipping slowly I've decided to go forward with my STi build. The engine that's going in the car is a hybrid engine from my old WRX that I lost in a fire. Back when I ran it ran it put down 375 whp on airboy @21psi on 91 CA octane. Here's the current build list:
Engine
EJ257 w/ 100mm Wisecos, 8.5:1 CR
Stock STi rods
ACL rod and main bearings
Killer B oil pickup
Cosworth oil baffle
P&L modified oil pump
Cosworth timing belt guide
Fluidampr
Okada Plasma direct coils
Crawford AOS V2
Heads
DPR ported S20 heads
Cosworth 272 non-AVCS cams
+1 mm intake and exhaust valves
Supertech valvetrain 8K rpm limit
Fuel, Air, & Cooling
FIC 1180 cc injectors
Aeromotive fuel rails and regulator w/ custom lines
DW 300 fuel pump
Marren Injection fuel pressure damper
TGV deletes
PnP intake manifold
Grimmspeed PnP throttle body
Koyo Radiator
Mishimoto radiator shroud w/fans
FSR Motorsports FMIC w/ Garrett core
Turbo and Misc. stuff
Full Race twin scroll EFR 7670 turbo kit
ACT 6-puck sprung disk/HD pressure plate
Greddy EVO2 catback exhaust
Innovate LC-1 Wide-band
Link G4 extreme standalone EMS logging
  1. turbo rpm
  2. oil temp
  3. oil pressure
  4. fuel pressure
  5. FMIC inlet temp
  6. Whatever else
I'll be pulling the old engine in the next couple of days and wiring up the Link and the external sensors and hope to have everything done in about 3 weeks or so but considering I still have no turbo there is no real rush. I'll throw some pics up soon and keep this thread updated as everything comes together. If this setup is half as fun as my old ATP30R setup we will have a winner. Stay tuned for more
Old 12-28-2011, 06:44 AM   #2
vicious_fishes
Member#: 158864
2003 SOHC destroker
you're going to snap your rods.
vicious_fishes is offline   Reply With Quote
Old 12-28-2011, 08:04 AM   #3
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
+1 Gorgeous setup though, should be fun until it lets go
No Limit Motorsport is offline   Reply With Quote
Old 12-28-2011, 09:14 AM   #4
kellygnsd
Member#: 32669
LINK G4 hybrid STi
That's what I was afraid of and will be the reason I don't go balls out until I get an MPS long rod motor.
Old 12-28-2011, 10:09 AM   #5
vicious_fishes
Member#: 158864
2003 SOHC destroker
why not just get it right from the beginning? i.e pour all the money you did into this into that? you'd get the MP engine much faster then?
alternatively just spend the small amount of cash more on some new rods, it's an insiginificant amount compared to what else you've clearly put into this...
Old 12-28-2011, 10:48 AM   #6
kellygnsd
Member#: 32669
LINK G4 hybrid STi
This was a back up motor that was basically just a holdover from my last car. The only thing I'm worried about is the bottom end but I think it will hold ~450whp while I get a proper STi motor built.
If the stock motor hadn't failed I wouldn't be in any hurry to get it on the road but this at least gives me time to get the ECU sorted out before i drop a GOOD motor in. If everything wasn't already together I would have considered adding rods but this engine has been an assembled long block in waiting for over a year.
The heads on this motor are really the only thing I care about and the only thing I really want to save. If I get good results on this trial run I may use the non-AVCS heads again in the STi since I'm not really looking forward to shelling out the dough for another set of fully built heads.
Old 12-28-2011, 11:22 AM   #7
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Makes sense. Losing a rod and having the piston smack the head would suck. Sounds like you know what you are doing.
Old 12-28-2011, 12:51 PM   #8
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
its a 100mm bore anyway.. i wouldnt push it any farther than stock sti rod power for that reason as well.
you gonna go with our 2.5 +2 engine or 2.34 +2
NW2TONE is offline   Reply With Quote
Old 12-28-2011, 02:10 PM   #9
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I agree. My dream engine would be a sleeved 2.34 long rod motor. Does he offer +2 and +4mm rods.
Old 12-29-2011, 12:27 AM   #10
NW2TONE
Member#: 212509
your **** go faster
yeah we do. The +4s are custom order and take longer than custom pistons too get.
Dominic currently has a sleeved big bore +3.5mm longer rod in his rs with s20 cnc'd heads and gigantic cams. but were pulling those off to go with avcs heads with 199-b intake and a 276 i think exhaust
Old 12-29-2011, 04:47 PM   #11
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Does Dom prefer new blocks over used for his builds?? Once I get the STi engine out of the car I wanted to tear it down and get to rebuilding it.
Old 12-29-2011, 05:24 PM   #12
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
New blocks unless it's getting sleeved.
EtoS is offline   Reply With Quote
Old 12-29-2011, 10:25 PM   #13
vicious_fishes
Member#: 158864
2003 SOHC destroker
then there are those of us that had to go oversized pistons with a bore because they marked the wall :/
Old 01-06-2012, 05:58 PM   #14
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
In for results.
armyssoldierboy is offline   Reply With Quote
Old 01-07-2012, 11:13 AM   #15
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I got the old engine out this week and transferred everything over to the new engine. Should have time to drop the new engine in this weekend but I still need to wire up the Link and test out all the I/O.
Old 01-08-2012, 01:39 PM   #16
Layvon
Member#: 195711
STi 04/05/06/07
annnd subscribed. I was about to ridicule 100mm wisecos also, but then I read the thread. I'll be interested to see how you and bariga turn out. I'm in the process of getting a 7670 on the road too. Just got my heads, now paying for fuel setup then onto short block.
Can you PM me some info on the link G4 once you get it going? That is my last obstacle to figure out, which EM to go with.
Good luck, and in for results also!
Layvon is offline   Reply With Quote
Old 01-08-2012, 06:22 PM   #17
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
what does the Link going to do with
oil temp
oil pressure
fuel pressure
Bariga is offline   Reply With Quote
Old 01-08-2012, 07:12 PM   #18
kellygnsd
Member#: 32669
LINK G4 hybrid STi
oil temp
oil pressure
fuel pressure
Mostly for logging purposes so I know exactly what went wrong when **** does go wrong but I'm also playing with the idea of a a lower redline and/or shutdowns for low oil pressure and temp and a alternate fuel map when fuel pressure delta drops.
Old 01-11-2012, 08:36 AM   #19
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Got the engine in last night
Old 01-11-2012, 10:22 AM   #20
CatfaceType-R
Member#: 81102
I'm jelly, it's screaming for an upgraded throttle body and a ac delete in that pic . Good luck and keep up the good work.
CatfaceType-R is offline   Reply With Quote
Old 01-11-2012, 10:43 PM   #21
stu
Member#: 25768
35R bugeye
Slowbaru
im pretty sure your stock rods will be fine at this power level. i ran 486 whp for over 5 years beat on it pretty good and the stock rods were fine.
stu is offline   Reply With Quote
Old 01-14-2012, 11:43 AM   #22
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Installed the DW 300 fuel pump, new fuel filter and this last night
The adapter harness fits under the plate where the stock ECU used to be
The ECU mounts to the back of the glove box enclosure
This week I'll get the pressure, temp, and speed sensors wired up then get to installing the FMIC.
Also, since the dealer said they couldn't just sell me the WRX length coil boots seperate and I would have to buy complete coils at $120 a pop I picked up a set of Okada plasma direct coils for $375 brand new. Maybe I'll do some back to back coil testing if I ever get the right boots for my STi coils.
Old 01-14-2012, 12:41 PM   #23
-Nic-
Member#: 291154
2004 STi
Am I the only one that worries about unbalanced flow between cylinders when people rotate the throttle body like that? Or is it inconsequential at part throttle?
-Nic- is offline   Reply With Quote
Old 01-14-2012, 01:01 PM   #24
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I guess we'll have to see. I have an EGT bung on each side so when I get that setup I may be able to tell if flow is somewhat even between runners.
Old 01-15-2012, 12:16 AM   #25
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Nice!
Any details on the Link?
Where'd you get it, how much $, how much splicing is required with the adapter?
Merp is offline   Reply With Quote
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 02:26 AM
2004 STi EFR 7670 Build Layvon Proven Power Bragging 869 02-10-2014 04:45 PM
The Foos's BW EFR 7064 build thefoos Custom Fabrication, Welding & Tools 158 02-26-2013 01:15 PM
EFR 7064/7670 and 8374 picture previews armyssoldierboy General Community 2 12-29-2010 10:38 AM
EFR 7064/7670 and 8374 picture previews armyssoldierboy News & Rumors 2 12-29-2010 09:08 AM
