Old 03-09-2012, 03:40 AM   #51
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
my mishimoto radiator fitted perfectly fine with full-race kit. About the vipec i guess u not going to run cruise control when its out?
Bariga is offline   Reply With Quote
Old 03-09-2012, 10:49 AM   #52
MartinSTi05
Member#: 145145
2006 wrx STi
I like it! Great recipe for a DD. Nice TS 7670 and AC. You have your cake and can eat it too.
MartinSTi05 is offline   Reply With Quote
Old 03-09-2012, 11:45 AM   #53
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Is the Mishimoto radiator stock thickness or thicker like the Koyo? With the thick Koyo and the stock radiaotor fan the fan shroud the passenger side fan was resting directly on the header. I'm sure it wouldn't have lasted as long so I got the Mishimoto fan shroud w/ fans.
Does the replacement board Vipec retain cruise control?
Old 03-09-2012, 12:42 PM   #54
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yes it will work in next update, my rad is thick like koyo,
Old 03-13-2012, 11:50 AM   #55
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I wish I had some news to report but nothing major has happened with the build.
I installed my Crawford AOS and Innovate LC-1 wideband and got some harness issues cleaned up a bit. I can post pics but I'm tired of the same old no turbo having pics
Bariga, can you snap a pic of the clearance you have between you headers and the stock passenger side radiator fan? Thanks.
Old 03-27-2012, 01:35 PM   #56
wrxturner
Member#: 309676
any update on you build bro?
wrxturner is offline   Reply With Quote
Old 03-27-2012, 01:46 PM   #57
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Clearance is about inch last time i checked cant really check now motor being sleeved
Old 03-27-2012, 02:54 PM   #58
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Uh oh. Should just let Kelly use your Turbo lol.
What happened?
Layvon is offline   Reply With Quote
Old 03-27-2012, 03:12 PM   #59
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Once I get the turbo I need to fab up the oil and coolant lines, make an intake and I'll be ready to fire her up.
I'm going to put on an old set of coilovers and replace my brake fluid this weekend but besides that, nothing to see here
What happened?
Best idea ever!!!!
Old 03-27-2012, 03:21 PM   #60
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i like my efr, ran same power as 35R with 5 psi less boost and made over 60tq and 40whp at 4k rpm vs 35R.
Old 03-27-2012, 03:24 PM   #61
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
What happened?
2 pulls @ 28 psi of boost on 92 pump gas making over 520whp i guess stock sleeves are made from cola cans
Old 03-27-2012, 03:45 PM   #62
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Its good to hear you were able to break 500whp on this little old 7670. I'm starting to question my block more and more everyday. I need to get Dom to put a LR 2.35 together for me.
Old 03-27-2012, 04:05 PM   #63
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
old 7670 next time ill be at MPS ill ask dom to print out the graph from that pull, the boost went from 3k rpm straight line up at same time with torq looked nasty
Old 03-27-2012, 10:40 PM   #64
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Nice!! Ill definitely be interested to see that graph. On 92 also haha.. wonder what E85 will get on that dyno with same-ish boost levels? Close to 575 I'd imagine.
Ive been offered a chance to proto type a quick spool valve to close off one pf the ports on the Turbo during spool up. Then open once at set boost levels.
What are your guys ' thoughts on that?
If you hit 28psi with yours by that soon... I think it'd be overkill. But I'm also all about innovation and moving that curve left!
Layvon.
Old 03-28-2012, 03:26 AM   #65
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
so you going to build single scroll system and put EFR with spool valve on it?
Old 03-28-2012, 11:43 PM   #66
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Sorry Kelly - didn't mean to jack.
But if I went with the quick spool valve yes I would. It'd be one tube with a T4 flange, one with flapper one without.
I'm torn, but leaning towards KISS. The thoughts of innovation tempt me, as I've never seen one period, let alone on a Suby.
Layvon
Old 03-29-2012, 03:00 AM   #67
kellygnsd
Member#: 32669
LINK G4 hybrid STi
No worries about jacking it in my thread. I don't have anything to add to it and I'm sure it'll get on track the second I get results.
Old 03-29-2012, 11:32 PM   #68
3MI Racing
Member#: 200987
A little birdy, in the know how on EFR's, talked me out of a 7670 and to an 8374 for my 2.1L stroker. Said that transient response was so close that the added power of the 8374 outweighed the response. We'll see...once of these years when I can get one
-Micah
3MI Racing is offline   Reply With Quote
Old 03-29-2012, 11:34 PM   #69
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Layvon.
do it!
Old 04-01-2012, 12:19 PM   #70
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Interesting Micah ... very interesting. I like this guinea pig syndrome but at the same time it sucks.
PM'd you Juan
Old 04-04-2012, 04:19 PM   #71
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Someone brought the flapper idea up in my build thread a couple years ago and mentioned how supra guys have been using them with great results. Since then, I've been curious how they'd do on our long header/uppipe subaru's.
armyssoldierboy is offline   Reply With Quote
Old 04-04-2012, 04:57 PM   #72
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I'm going to do it on mine. Hopefully I can try to get good data
Old 04-04-2012, 05:28 PM   #73
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
-Micah
I talked to that same bird, said the same exact thing.
he said 4-8 month wait
Sales guy at Full-Race
ronzogonzo is offline   Reply With Quote
Old 04-04-2012, 06:32 PM   #74
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
November, December, January, February, March now April. . . Plus 4-8. Yippie skippy. My patience will run low by august and ill hop online and get a gtx35r probably with free 2 day shopping or something. Borg isn't doing themselves favors. I understand moving plants takes time but...those first few turbos are such a tease!
Old 04-04-2012, 11:57 PM   #75
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I have about 2 more months of wait left in me. If I can't get a definitive answer on when I can expect my turbo I'm going gtx or anything else. This wait is ridiculous.
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 03:26 AM
2004 STi EFR 7670 Build Layvon Proven Power Bragging 869 02-10-2014 05:45 PM
The Foos's BW EFR 7064 build thefoos Custom Fabrication, Welding & Tools 158 02-26-2013 02:15 PM
EFR 7064/7670 and 8374 picture previews armyssoldierboy General Community 2 12-29-2010 11:38 AM
EFR 7064/7670 and 8374 picture previews armyssoldierboy News & Rumors 2 12-29-2010 10:08 AM
