Old 12-28-2011, 04:51 AM   #1
insane_one
Member#: 301431
2005 Evolution VIII
Post How to DIY: DRL Disable
First off, I KNOW there are a bunch of How-to/ DIY threads on disabling DRLs but i never came across one that actually had good pictures. Sorry but pictures work for me and im sure it will help others out alot.
Second, give credit where credit is due. The thread below is where the most instructions made sense to me but not enough pictures.
http://forums.nasioc.com/forums/show...ht=drl+disable
Last, i am not responsible for anything you do to your car.
Now to start the DIY....
This should work on all 02-07 Subaru WRX's
DRL = Daytime Running Lights
Why do we want to disable them?
If your going to run HID's in your headlights, you need to disable the DRLs. My main reason is because i think it looks stupid to have lights on ALL THE TIME. Especially during the day. There are also times where i WANT to drive with my lights of to not be seen.
There are 2 parts that need to be disconnected, there is a DRL unit in the engine bay and a plug that needs to be disconnected behind the glove box. You could disconnect either one and be done to have DRL's disabled, but disconnecting both will completely disable DRL's.
First off, the engine bay. Picture is a bit close but you will find the DRL unit on the passenger side shock tower.
A bit closer, the circled plug is what you will be disconnecting. You can either unplug it here and leave it mounted incase you want to have DRL's again or you can remove the unit completly.
If you choose to remove the unit completely the unit is held in place by 2 10mm bolts.
After removing the bolts and the unit from its place i found it easyer to unplug it from the harness.
Unit removed completely
Part 1 complete
insane_one is offline   Reply With Quote
Old 12-28-2011, 04:51 AM   #2
insane_one
Member#: 301431
2005 Evolution VIII
Part 2
Going to the passenger side of the car, beside the glove box is a plug you need to disconnect to complete disabling the DRLs. If you could see through plastic the DRL plug would be right about here
Now, you can take 5 seconds and shove your hand in that space to disconnect it or you can take 5min removing your glove box. Up to you.
The plug that needs to be disconnected
5 seconds later...
And you are done!
Old 12-28-2011, 07:47 PM   #3
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
my 06 wrx, dash apart to replace cabin air filter
aerosaaber is offline   Reply With Quote
Old 12-29-2011, 07:50 AM   #4
GFB
Member#: 281725
2006 STI
I had no need to remove the DRL module itself, I just unplugged it from the glovebox area. Why did you need to remove the module?
GFB is offline   Reply With Quote
Old 01-10-2012, 01:16 AM   #5
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
I just tried to do this and my car looks neither like aerosaaber's nor insane_one's. Unless the DRL plug is farther up under the dash, closer to the outside wall. I can see 5 plugs, none of them is plugged into a black box. Gonna check my service manual. Can anyone help me? Sorry for no pic, can take one to clear this up if needed.
AWDmonk is offline   Reply With Quote
Old 01-10-2012, 06:36 PM   #6
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
i just did the plug. no module.
VTSubieRS is offline   Reply With Quote
Old 01-11-2012, 03:34 AM   #7
insane_one
Member#: 301431
2005 Evolution VIII
i removed the DRL Unit compeltely because i dont ever plan to put it back and its less stuff in the bay.
AWDmonk- you have a 2.5i. not sure its the same, i dont see why not though.
Old 01-11-2012, 07:56 PM   #8
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Nice write up fellow AKIC'er, I'll have to do this to my girlfriends car. I hate the DRLs.
Dominator is offline   Reply With Quote
Old 01-12-2012, 03:55 AM   #9
insane_one
Member#: 301431
2005 Evolution VIII
Glad to be of help!
Old 01-12-2012, 10:16 PM   #10
emazz104
Member#: 281811
04 WRX
World Rally Blue
Nice write up, I did this a little while back, didn't do the engine bay one though.
It should be there, I didn't see mine at first, and yes, it's the same on a 2.5i.
emazz104 is offline   Reply With Quote
Old 01-14-2012, 04:02 PM   #11
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
Yep, it's farther up under the dash than i thought. My gorilla hands didn't quite fit so the glovebox came out. On the plus side, the cabin filter is really easy to replace. Man was it dirty.
Old 01-15-2012, 10:38 PM   #12
emazz104
Member#: 281811
04 WRX
World Rally Blue
In my opinion it's easier to take out the glove box, at least the first time.
I highly doubt I would have found it with the glove box in, and if I did, it would have taken more time then to just unscrew the glove box.
Old 02-16-2012, 09:40 AM   #13
nftyper
Member#: 77269
2002 WRX Wagon
09 FXT 00 Foz L
Thank you for this
nftyper is offline   Reply With Quote
Old 02-16-2012, 12:18 PM   #14
insane_one
Member#: 301431
2005 Evolution VIII
glad i could help! can we stickie this or add to the DIY Threads
Old 02-16-2012, 12:33 PM   #15
modular
Member#: 308850
2012 Impreza Sport
Camellia Red
Anyone figure out how to do this to the '12's yet? Things are not the same as far as I can tell.
modular is offline   Reply With Quote
Old 02-18-2012, 09:08 AM   #16
modular
Member#: 308850
2012 Impreza Sport
Camellia Red
No one yet? None of these plugs are on the 2012 Impreza.
Old 02-18-2012, 08:38 PM   #17
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
to be 100% clear, the glovebox has been removed for this picture.
while you are there, replace the cabin air filter. thank me after.
Old 02-19-2012, 02:41 AM   #18
insane_one
Member#: 301431
2005 Evolution VIII
READING would have told you that. This DIY is specific to 02-07 WRX's
Old 02-19-2012, 08:14 AM   #19
modular
Member#: 308850
2012 Impreza Sport
Camellia Red
I did read the whole thread and searched the site as well. I figured since this thread is generically labeled and has no specific years I would keep things organized and post here. If you wanted it to just pertain to 02-07 WRX's maybe include that in the thread title? I already looked for all the plugs shown and they do not seem to exist on the 2012 Impreza. I pulled the large DRL relay out of the main fuse box but that kills the high beams as well. The search continues......
Old 02-19-2012, 02:17 PM   #20
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
Perhaps you could read the first post in this thread, it includes
the post I made with my picture also states "my 06 wrx"
Old 02-19-2012, 07:23 PM   #21
modular
Member#: 308850
2012 Impreza Sport
Camellia Red
Huh, the things I have read about this forum are starting to ring true..................
Old 02-19-2012, 08:48 PM   #22
insane_one
Member#: 301431
2005 Evolution VIII
sorry that we are of no help. but what you hear about nasioc is very true, get used to it.
Old 01-06-2015, 07:01 PM   #23
smoky
Member#: 221439
2004 STI
The engine bay DRL unit seems to be referred as an injector resistor a lot on the interweb. I did search the wiring diagram and it is actually the DRL resistor and has nothing to do with injectors, so don't be afraid to remove it and save a bit of weight
Reference for those who want to double check:
On the 2004 STI service manual, page WI-135 show that there is a DRL resistor and it is connector B5, on page WI-175 you have the confirmation of where the B5 connector is.
smoky is offline   Reply With Quote
Old 10-04-2015, 07:59 PM   #24
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default How to DIY: DRL Disable
rezzing this thread to say i unplugged the module under the hood and disconnected the plug under my dash/glovebox and my DRL's are still working.
did i do something wrong? its not my parking light switch on the steering column
02 wrx wagon, not original owner
Titter is online now   Reply With Quote
Old 10-04-2015, 08:10 PM   #25
In10city
Member#: 363489
2006 Subaru WRX STi
Confirmed this doesn't disable airbags?
In10city is offline   Reply With Quote
How to rewire DRL to fog lights? Azxster Electrical & Lighting 5 06-22-2009 10:53 PM
How to enable DRL daytime running lights on JDM GC8 WRX? stigc8 Interior & Exterior Modification 12 04-18-2008 09:20 AM
how to swap DRL to small parking light on 07?? cowboysuby Electrical & Lighting 4 01-15-2008 12:25 AM
how to kill DRL? Azn-Jap STI Vancouver Impreza Club Forum -- VIC 27 03-26-2007 11:49 PM
how to re-wire DRL to power high beam instead? MrZone Electrical & Lighting 11 05-15-2004 03:47 PM
