12-28-2011, 06:18 AM | #1 |
Member#: 301431
AKIC
Vehicle:2005 Evolution VIII |
How to DIY: Independent Foglight Mod
There are afew detailed write ups out there and just like my DRL How to thread i wanted to make with a bunch of pictures that made sense on how to actually do this. So here it goes....
First, i followed all directions straight from scoobymods.com. Although i did have to make an account just to view the attatchments (inconveint). Last, I am not responsible for anything you do to your car. This works for sure on 2004-2005 WRX. May work on other years as well. Try at your own risk! Independent Foglights? WHY? Why? because i think it looks cool. Other than having complete control of your foglights to be on when ever you want, thats the only reason i have for taking the time to do this. To OEM Spec, Foglights will only be on when the low beams are on. So if you highbeam flash someone, your fogs shut off. They shut off to comply with the law, no more than 4 forward facing driving lights to be on at once. If you have HID foglights, its bad for them to shut off and turn back on like that. There are many different ways to achieve having independent foglights but this one specifically is imo pretty simple and easy. With doing this your foglights will turn on when you want them to. With your park lights, low beams, and stay on when you turn on your highbeams. Not only that, your foglight button indicator light will also be on when ever your foglights are on. Remove panel by removing the 3 circled screws. After the screws have been removed, gently pull the panel back toward you and it should just pop out. Here we see the Fuse box and relays. Looking closer, we want to remove the fuse box by removing 1 10mm bolt at the top and releasing the clips on the side. After that i recommend disconnecting the 2 blue plugs on the fuse box to give you more room to bring down the box like so ^^ with using needle nose pliers, release the 3 clips holding the relays in place now looking on the other side and we see a RED with GREEN stripe wire connected to the 3rd relay from the bottom CUT IT. The side that goes to the relay, we use. The side that part of the rest of the harness, we dont use. Leave the cut wire alone for a bit and go back to the fuse box. Unplug the center plug from the fuse box and locate a solid orange wire.
12-28-2011, 06:21 AM | #2 |
Member#: 301431
AKIC
Using wires and these connecters to make everything work. using this connecter we are going to "tap" into the orange wire. NOT CUT OR DISCONNECT IT. And have a new wire go to the RED & GREEN wire from the relay box now to make the indicator light turn on on your foglight switch anytime your foglights are on, follow these steps from the grey plug that connects to the foglight switch we want to locate the RED & GREEN wire and the YELLOW & BLUE wire the RED & GREEN wire connects to our "NEW Wire" ( the one thats connected to the Orange Fuse box wire and Red & Green Relay wire) the YELLOW & BLUE wire connects to a ground. I Already had another switch that went to a ground so i taped into that a good ground spot would be the bolts holding the hood release lever in the end it should all look like this do a quick test and put it all back together. |
12-28-2011, 06:22 AM | #3 |
Member#: 301431
AKIC
12-28-2011, 06:34 AM | #4 |
Member#: 29355
NWIC
[peeks head out from under rock... wonders, "is moment of self-realisation upon us?"]
[nope. chuck testa. sees nasioc users are still living up to their usernames and high member numbers. groundhog sees shadow, goes back into his cave for six more weeks of winter, or years off the board] [insult to injury: hid foglights, because it looks cool] |
12-28-2011, 09:38 AM | #5 | |
Member#: 287358
NESIC
Vehicle:2006 2.5i Regal Blue Pearl |
Awesome right up, will be doing it soon. Just ordered the blazer fogs from TRS and dont want to kill my ballast/bulbs. |
12-28-2011, 02:09 PM | #6 |
Member#: 301431
AKIC
Handsdown- sorry this wasnt your cup of tea. Move on to the next thread made by a "newbie" and bash on them
Hey glad i helped someone. Post pics when you get it all done! |
12-29-2011, 01:28 AM | #7 |
Member#: 281488
AKIC
Vehicle:2005 STi OBP |
Nice write up bruh!! Keep up the good work!!!
12-29-2011, 04:15 AM | #8 |
Member#: 301431
AKIC
Thanks! Hope this helps out
12-31-2011, 08:39 PM | #9 |
Member#: 91212
Vehicle:2011 WRX 5DR Satin White Pearl |
Starting through this thread I was all 6-to-midnight. Then I saw that it was not for an 08+ and went back from midnight-to-6.
I knew somethis was amiss when there was mention of the plug to the foglight switch, which on the GR is in the stalk. I just want to find the indicator-light-actually-works-with-the-foglight-mod-mod for the GR... |
12-31-2011, 09:06 PM | #10 |
Member#: 132400
Vehicle:2006 WRX |
nice write up! thanks!
01-03-2012, 11:40 PM | #11 |
Member#: 219426
Vehicle:2004 Subaru WRX WRB Stage II |
There was an older thread on here where the guy ran a line from a fuse, it looked kinda sketchy so I opted out of that method, saw a write up similar to this on scoobymods and now tomorrow I will be following your write up. I too should be getting HID fogs, they are the blazer fogs so it wont be blidning to traffic and with the 3000k HIDs I should have a nice deep yellow.
Great write up! One quick question, you mention they are on for everything from no headlights to high beams. But do they still turn off when the vehicle is off? I don't want to find myself going to work only to come out to a dead battery cause driving Subaru for 4 years has taught me my lights shut off when the car turns off. Last edited by subaru_steve; 01-03-2012 at 11:45 PM. |
01-04-2012, 12:18 AM | #12 |
Member#: 301431
AKIC
yes doing this mod they will still shut off when the car is off even if the button is ON. glad my write up was helpful!
01-04-2012, 04:48 PM | #13 |
Member#: 290813
TXIC
Vehicle:2011 WRX Limited OBP |
any idea if this would be the same for a 2011??
01-04-2012, 05:26 PM | #14 |
Member#: 301431
AKIC
Sorry guys , to my knowledge this will ONLY WORK ON 02-07 wrx. Actually even 07's might be a tad different
01-04-2012, 09:24 PM | #15 |
Member#: 290592
South East
Vehicle:15 Outback, 15 WRX 6MT CWP |
Awesome writeup! Ill havento give this a shot.
01-06-2012, 10:21 PM | #16 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
I have found that being able to toggle the fogs at will is a great thing in snow and fog.....and having the extra 'wide angle' light on dark nights in the boonies on narrow, winding, 2 lane back roads is great for helping avoid **** like deer I am REALLY happy with the Osram 65w Rallye H7 and Phillips(GEN3) 9011HIR combination for the 06-07 wrx.... Quite shocking, really.....the new GEN3 HIR's are just ...they throw some LIGHT |
01-06-2012, 10:41 PM | #17 |
Member#: 132400
Vehicle:2006 WRX |
I plan on doing this on my 06 tomorrow....hopefully the wires colors match up! I will keep you posted!
01-07-2012, 02:56 AM | #18 |
Member#: 219426
Just did this tonight, I have been working on my car for 3 days straight now...
- HID Projectors - Hella Supertones - Yellow Tinted Fog Lights Just to name a few Its 2:30a and I finally finished everything, including this mod which took about 10 min. Not the best picture but you get the idea... Last edited by subaru_steve; 01-07-2012 at 11:26 PM. |
01-07-2012, 02:24 PM | #19 |
Member#: 132400
Vehicle:2006 WRX |
works perfect on 2006 wrx models! all the wires are the same color and its very easy! took my about an hour but thats because i have to solder and heat shrink everything or else i cant fall asleep at night.
01-07-2012, 03:18 PM | #20 |
Member#: 301431
AKIC
Hey there ya go. Sweet!
01-08-2012, 11:04 PM | #21 | |
Member#: 16200
So that's that....now I just gotta find time to do it And I have a BernzOmatic butane torch that has a neat soldering tip that is perfect for these kinds of wiring jobs.....it is one of the neat little tools that everybody should have. It works great for stuck/frozen bolts and nuts because you can spot heat them and then spray them with penetrant while they are hot and cooling which REALLY helps wick the penetrant into where it can work....one of my 'tricks'. |
01-09-2012, 09:33 AM | #22 |
Member#: 132400
Vehicle:2006 WRX |
always wanted to know how well those bernzomatic soldering things worked...might have to pick one up now!
01-09-2012, 10:53 AM | #23 |
Member#: 129089
AKIC
Vehicle:06 Impreza2.5Bug-i OBP |
Nice write-up, Insane. I might be getting in touch with you to do this soon since I plan on installing Blazers to replace the stock fogs.
01-09-2012, 05:03 PM | #24 |
Member#: 132400
Vehicle:2006 WRX |
01-10-2012, 10:33 AM | #25 | |
Member#: 91212
http://forums.nasioc.com/forums/show....php?t=2272901 |
How to DIY: DRL Disable | insane_one | Electrical & Lighting | 29 | 03-10-2024 03:21 AM |
Independent Foglight Mod writeup for the BE Guys | MitchGT | Legacy Forum | 5 | 04-29-2005 12:20 AM |
how to change the foglight bulb | Grey Ghost | Electrical & Lighting | 12 | 04-27-2005 10:25 PM |
how to aim my foglights? | legacy2003 | Electrical & Lighting | 2 | 09-24-2004 09:14 AM |
How to aim stock foglights? | ShutUpGeek | Electrical & Lighting | 2 | 01-11-2004 07:20 PM |
