Old 01-10-2012, 01:35 PM   #26
kh15
Member#: 132400
Very nice! Im looking for something I can retrofit INSIDE of my oem foglight housings though...
kh15 is online now   Reply With Quote
Old 01-10-2012, 03:53 PM   #27
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Originally Posted by aleutdude View Post
Nice write-up, Insane. I might be getting in touch with you to do this soon since I plan on installing Blazers to replace the stock fogs.
I'm in the same boat. I have a set of Blazer fogs at home but never got around to installing them since the headlight retrofit took so much time. I did take apart my foglight assembly to see if i could retrofit the blazer fogs into their to keep the same mounting locations but it would require a lot of cutting and moddifying the fog housing. Maybe I can pick up some used ones off here and work on it on the side. Would love to have the better fogs but who knows how much work it will take.
subaru_steve is offline   Reply With Quote
Old 01-11-2012, 10:21 PM   #28
kh15
Member#: 132400
Im looking into some lexus IS300 projectors now, looks like they may fit better....
Old 01-13-2012, 12:58 AM   #29
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ima get me some hella 90mm modules and swap them in for the stock garbage fogs
Old 01-13-2012, 07:06 AM   #30
SubieMonte
Member#: 264803
2005 WRX Wagon
Sweet! Can you give us a walk through with pics?
SubieMonte is offline   Reply With Quote
Old 01-13-2012, 07:54 AM   #31
Yulri
Member#: 162299
2007 Impreza WRX OBP
93 Impreza L, 91 Legacy L
just an fyi is300 fog projectors do fit into the stock 06-07 housings
also uncle scotty could have you posted up pics of what your light set up looks like? I recall reading about those bulbs a long time ago and I'm curious how itd look like on an 06-07
Yulri is offline   Reply With Quote
Old 02-28-2012, 07:25 PM   #32
GarrettKoonsman
Member#: 243999
2003 WRX
MBP
Sorry to bump a fairly old thread but am i right to assume that if I just stop after connecting the red/green wire to the orange the fog lights will still work independently and the light just won't come on?
My foglight buttons light doesn't work anyways so there is no reason for me to go that far into it if i don't have to
GarrettKoonsman is online now   Reply With Quote
Old 03-01-2012, 01:29 PM   #33
sharpshooter23
Member#: 312077
2003 WRX
Pics not working for me!
sharpshooter23 is offline   Reply With Quote
Old 03-01-2012, 01:33 PM   #34
insane_one
Member#: 301431
2005 Evolution VIII
that is correct sir.
sorry i exceeded my bandwith usage on Photobucket. Check back on the 8th. Thats when it resets.
insane_one is offline   Reply With Quote
Old 03-01-2012, 08:15 PM   #35
GarrettKoonsman
Member#: 243999
2003 WRX
MBP
Pics are still working on iPhone app for those wanting to do this before the 8th
Old 03-02-2012, 03:30 PM   #36
GarrettKoonsman
Member#: 243999
2003 WRX
MBP
After completing this my fog lights will now stay on without my headlights but they shut off when my brights are on? Could this be because I have done the DRL delete mod?
Old 03-02-2012, 04:35 PM   #37
kh15
Member#: 132400
no you messed something up. I did the drl mod and this mod and it worked fine.
Old 03-02-2012, 04:38 PM   #38
GarrettKoonsman
Member#: 243999
2003 WRX
MBP
What could I have possibly done wrong? I guess it could be because I stopped after connecting the Red/Green wire to the orange one and did not go any further as I don't care about the illumination because it doesn't work on my button anyways. Otherwise I just connected a wire to red/green and ran it to orange.
Edit: I did have to cut the orange wire because T-Taps weren't working. But I soldered everything back together properly and used heat shrink so they are all still connected. It has to be something to do with the second portion of the mod (illumination)
Old 03-03-2012, 11:09 PM   #39
Uncle Scotty
Member#: 16200
OK buy Nates beans
w0w...just saw this...again...
I have been so jammed up with my job...ive had about 6 days off, total, since xmas eve.
I have not DONE the Hella 90's....nhluhr did it to his 06 sti and posted it all up here and on iwsti
it 'LOOKS' all pretty stock when done....but ya get lights that actually DO something
and if you have an 06-07 impreza and have any hesitation on doing the 65w Osram Rallye H7 lows and Phillips 9011 HIR high beams.....
just DO IT......jesus...it is just incredible how much light the combination throws.....worth every penny.
hell....id pay DOUBLE if i had to, after using them for a while now
Old 03-05-2012, 10:16 PM   #40
GarrettKoonsman
Member#: 243999
2003 WRX
MBP
So this is the strangest thing ever. As my previous post said I didn't do the portion of the mod to make my indicator light work as I didn't care. However, my fogs weren't working with the high beams but were otherwise independent. So today I get in the car and all of a sudden the indicator light is working and the fogs are now working with the high beams. I literally didn't touch anything so I have no idea how this is even possible. My car may be possessed.
Old 03-09-2012, 06:16 PM   #41
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
Satin White Pearl
I always wanted to do this to my 2012 sports premium impreza fogs. I wonder if there will be a write up on it later.
JDMSTA is offline   Reply With Quote
Old 03-13-2012, 03:36 PM   #42
johnmkv
Member#: 300848
2012 WRX
LR
Anyone have a dyi for the 2012 wrx on how to go independent fogs?
johnmkv is offline   Reply With Quote
Old 03-19-2012, 10:44 PM   #43
camerong
Member#: 225101
2006 WRX TR
Edit: Mine were working until I flashed my brights on and the fuse blew. Now my DRL's wont turn on. I replaced the 20amp fuse and then I accidentally flashed my brights on again while driving the other night and it blew again. Any suggestions?
camerong is offline   Reply With Quote
Old 04-10-2012, 08:17 PM   #44
boostin23
Member#: 204172
---- 05 STi
Did you just tap into the Red wire w/ green stripe?
I saw this in the other thread:
Originally Posted by Big-E View Post
The red wire with the green strip is in fact the ground wire from the high-beam switching relay located behind the glove-box.
When the car is running, with the headlamps off, there is power being fed to them. Subaru uses a switched ground system to control the headlamps.
Although off, there is power running through this circuit (red wire with green stripe) and it feeds the fog-lamp relay and switch. The relay so you can of course turn the lamps on and the switch so that when its turned on, the little green indicator lamp illuminates.
If for any reason you simply tap into the red wire with the green stripe and not fully disengage it from the relay (whether unlock or cut) you will effectively feed power backwards into the headlamp system, which will cause problems such as blowing fuses.
So you're NOT supposed to just tap into it... you're supposed to snip it (as stated in this thread) or disable it.
Also thinking about doing this to my car this weekend.. time permitting
boostin23 is offline   Reply With Quote
Old 04-26-2012, 09:41 AM   #45
silmarilion
Member#: 191270
06 STI
This is exactly what I've been looking for. I, too, have the blazer hid fogs and wanted this ability so I wouldn't have to power them down when switching my highs on & off. It's a longevity issue.
Thanks for an awesome diy! The other writeups for this all have drawbacks but I see none to this one. Thanks again.
silmarilion is offline   Reply With Quote
Old 05-23-2012, 01:58 PM   #46
rex.effect
Member#: 99745
2013 C-Max Hybrid
Titanium White TriCoat
anyone know what wire colors and relay to do this on a 2011 sedan? I did this on my 04wrx and 05 sti and would love to have it on my 11. pics would be a HUGE bonus, lol
rex.effect is offline   Reply With Quote
Old 05-26-2012, 09:57 PM   #47
SubieMonte
Member#: 264803
2005 WRX Wagon
Finally decided to tackle this today. It worked! Sort of. When I turn on my parking light switch the HVAC lights and clock flicker. Interesting.
And the light on the fog light switch doesn't work. I used the wire clamps to connect into the other wires. I did not strip the plastic off the new wire.
Any ideas what might have happened?
Old 05-27-2012, 10:24 PM   #48
SubieMonte
Member#: 264803
2005 WRX Wagon
So..... When the jumper connection is used should I strip the plastic off the cut end that goes into the jumper?
Old 05-29-2012, 02:50 PM   #49
rex.effect
Member#: 99745
2013 C-Max Hybrid
bumpity bump bump. anyone?
Old 05-29-2012, 06:52 PM   #50
popeball
Member#: 193385
i followed the instructions exactly but my foglights are not independent, they require the parking lights to be on. other than that everything works. is there any way for me to now get the foglights to run by themselves, without any other exterior lighting?
i have a 2006 2.5i
thanks
popeball is offline   Reply With Quote
How to DIY: DRL Disable insane_one Electrical & Lighting 27 02-26-2016 03:18 PM
Independent Foglight Mod writeup for the BE Guys MitchGT Legacy Forum 5 04-29-2005 12:20 AM
how to change the foglight bulb Grey Ghost Electrical & Lighting 12 04-27-2005 10:25 PM
how to aim my foglights? legacy2003 Electrical & Lighting 2 09-24-2004 09:14 AM
How to aim stock foglights? ShutUpGeek Electrical & Lighting 2 01-11-2004 07:20 PM
