Old 05-29-2012, 08:28 PM   #51
SilvaSTi
Member#: 291384
Old: EvoVIII & EvoX
Now: '07 UGM STi 20g M@!
Has anyone done this on an '07 STi? I'm curious to know if wiring is setup the same.
SilvaSTi is offline   Reply With Quote
Old 06-14-2012, 02:38 AM   #52
SilvaSTi
Member#: 291384
Old: EvoVIII & EvoX
Guess not. Lol
Old 06-27-2012, 03:58 PM   #53
jthatch12
Member#: 321715
03 Big 16G WRX
I went to go do this mod the other day, then I realized the previous owner had already done it! It's pretty sweet
jthatch12 is offline   Reply With Quote
Old 06-30-2012, 05:10 PM   #54
illest_WRX
Member#: 324787
2004 WRX Wagon
Default Thanks insane_one.
Insane_One! Thank you for taking the time to actually take pictures of this and post it... I hated how I couldn't control when I turned on and off my fog lights and you actually took the time to make it easy for me. I did this last night in like 40 minutes and I'm glad I did because I now know that my HID's will last a little longer. Thanks again Insane_One.
illest_WRX is offline   Reply With Quote
Old 08-03-2012, 02:14 AM   #55
4Flat4Life
Member#: 321041
2004 WRX
Am i doing this right???
Everything works, and I can run the car like this,
But only if the E-brake is up, as soon as I put it down, the low beams comes on automatically, and if I turn the knob to on they get a little brighter but if I turn it to running lights they just stay on anyway until I pull the e-brake then they turn off and I can sit there with nothing but fogs and parking lights...
Did I mess something up?? Or is it impossible to actually DRIVE with nothing but the fog lights and parking lights.
(I am assuming those tiny lights in the top corners are parking lights)
4Flat4Life is offline   Reply With Quote
Old 09-09-2012, 12:13 AM   #56
insane_one
Member#: 301431
2005 Evolution VIII
thts your DRLs (daytime running lights)
insane_one is offline   Reply With Quote
Old 09-09-2012, 12:18 AM   #57
insane_one
Member#: 301431
2005 Evolution VIII
if i remember correctly, 07+ WRX / STi have different wiring.
heres how to disable your DRLs
http://forums.nasioc.com/forums/show....php?t=2288524
Old 09-22-2012, 09:11 PM   #58
coleman em1
Member#: 240533
2006 VF48 WRX Wagon
SRR
just did this mod today. i soldered all my connections tho. twas a piece of cake!! thanks insane_1 for the nice an user friendly write up!!
coleman em1 is offline   Reply With Quote
Old 10-08-2012, 10:23 AM   #59
ScubaSteve1991
Member#: 289816
2011 Subaru
Any body do this for the 2011 Sedan?
ScubaSteve1991 is offline   Reply With Quote
Old 10-09-2012, 12:05 PM   #60
johnmkv
Member#: 300848
2012 WRX
LR
Yes very easy mod^^^
johnmkv is offline   Reply With Quote
Old 10-13-2012, 12:46 AM   #61
ScubaSteve1991
Member#: 289816
2011 Subaru
What do I have to do? Is there a thread for the 2011 wrx model, where I can follow it step by step?
Old 10-16-2012, 09:46 AM   #62
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
Originally Posted by phenryiv1 View Post
Starting through this thread I was all 6-to-midnight. Then I saw that it was not for an 08+ and went back from midnight-to-6.
I knew somethis was amiss when there was mention of the plug to the foglight switch, which on the GR is in the stalk.
I just want to find the indicator-light-actually-works-with-the-foglight-mod-mod for the GR...
Originally Posted by T-Wills View Post
any idea if this would be the same for a 2011??
seeing as the GRs are 2005-2009 legacy based i would think that the legacy IFL mod would work on them. I had an 06 legacy and did it. My fog light switch was on the stalk like you say the GRs are!
here is a legacy one. not the one i did back in the day but its one. im not sure if the GRs are the same but they may be. Hope it helps
04jaxwrex is offline   Reply With Quote
Old 10-16-2012, 02:34 PM   #63
johnmkv
Member#: 300848
2012 WRX
LR
Very similar i know there was a thread of a guy doing it on a regular impreza not wrx i followed that and t worked... Basically black and green wire gets cut from the back of the relay you tap into a fuze and vampire clip/ tap into the purple/yellow wire on the stalk and your done
Old 10-16-2012, 10:50 PM   #64
ScubaSteve1991
Member#: 289816
2011 Subaru
Lol forgive me but, I'm still a little confused. Based on what you told me, here is my assumption:
Get to the back of the relay.
Black and Green gets cut.
*What fuse exactly do I "tap" into?*
*What is a "vampire clip"?
*What do you mean by "tap" into the Purple and Yellow? Also, are these two separate wires?*
Old 10-17-2012, 11:17 AM   #65
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
Old 10-19-2012, 02:20 PM   #66
ScubaSteve1991
Member#: 289816
2011 Subaru
Originally Posted by 04jaxwrex
Okay, I'm really sorry about all the questions guys. I just REALLY want this done and don't know anything about the relays and wiring. Can someone please explain to me what it means to "tap" into a wire?
Thanks a bunch,
Steve
Old 02-12-2013, 12:08 PM   #67
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
just tried this on my 05 sti. didnt work. The only thing I see different is the red/green stripe white on the back of the relay is red/blue stripe on mine... did i cut the wrong one? (not too worried, I'm good at soldering etc) but theres no other red wire coming out of that relay on mine...
tapped orange wire..
only red wire on relay.. red/blue stripe:
VTSubieRS is offline   Reply With Quote
Old 02-12-2013, 12:44 PM   #68
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
anyone have any insight?
I thought the mod would be easy following the OP directions, however, i understand these cars all vary a little bit depending on year model etc. looking at the OP pictures. where the red/green stripe wire is, i have a white blue stripe wire coming out, not close to red green... should I have spliced that one instead? I made the mistake of not following the pinout and going by color... any clarification would be great.
Would love to get the mod done while the dash is apart..
Old 02-12-2013, 03:33 PM   #69
Tiller35
Member#: 217006
When i did this on my 04 wrx, the wires were exactly as described in the OP. Red wire with green strip connected to the orange
Tiller35 is offline   Reply With Quote
Old 02-12-2013, 04:08 PM   #70
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
thanks, but that doesn't really help as I mentioned, my wires are not the same, the only red wire i have coming from the relay is red with blue stripe, and it looks like a different pinout than where the OP posted the red/green wire was.
Old 02-12-2013, 04:52 PM   #71
Handsdown
Member#: 29355
you want whatever wire comes out of the fog relay across the coil because what you're essentially doing is giving that relay a low voltage load from the orange wire to read as if it was getting that low voltage ground through the high beams.
i'm pretty sure you got the right one but maybe find a pin diagram for your year to make sure? or just test it. i think the worst thing that would happen is you fry your fog relay.
i just did this today so i can use my relay harness without that ****ing stupid ghost highbeam issue. put it off for years because i'd much rather have figured out the relay harness, but a 6ohm resistor is more expensive than just doing this mod.
hid and fog lights are now a go.
Handsdown is offline   Reply With Quote
Old 02-13-2013, 05:32 AM   #72
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
thanks... anyone else who's done the mod run into the wiring color differences? solutions?
Old 02-13-2013, 10:22 AM   #73
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
I remember reading about this mod in Sport Compact Car magazine back in the day. I tested it immediatly on a friend's bugeye 2.5RS and eventually got around to mine.
I LOVE this mod and I haven't had a single issue with it for the last decade.
THIS MOD IS A MUST!!!
car_freak85 is offline   Reply With Quote
Old 02-13-2013, 04:03 PM   #74
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
Yes it's something I want to get done.. Would love some help as my wires don't include a red/green stripe. Only red/blue stripe looking like a different pinout. Help anyone?
Old 02-13-2013, 05:37 PM   #75
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
anyone else with an 05 sti run into the color differences with wiring?
How to DIY: DRL Disable insane_one Electrical & Lighting 27 02-26-2016 03:18 PM
Independent Foglight Mod writeup for the BE Guys MitchGT Legacy Forum 5 04-29-2005 12:20 AM
how to change the foglight bulb Grey Ghost Electrical & Lighting 12 04-27-2005 10:25 PM
how to aim my foglights? legacy2003 Electrical & Lighting 2 09-24-2004 09:14 AM
How to aim stock foglights? ShutUpGeek Electrical & Lighting 2 01-11-2004 07:20 PM
