Old 12-28-2011, 08:50 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - 2007 STI, EQ Built Block, HTA68, E85
Event: Custom Tune/Dyno
Ambient Temp: 60 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2007 STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 376whp @ 5550RPM
Peak Torque at RPM: 440ft-lbs @ 3600RPM
Target Boost: 23.5psi Peak
Fuel: E85
Engine/Power Modifications:
EQ Stage 1 Shortblock
EQ Stage 1 Heads
DW1300cc Injectors
Catless TBE
Perrin Headers
Perrin Inlet
APS 70mm CAI
TGV Deletes
Walbro
MBC
This is a car we built a while back but never got great results from the turbo because the car had a very restrictive catback. The customer swapped out the catback and installed some EL Headers and we put it back on the dyno today for a re-tune. This time the car made great power all around!
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 215-220whp
Stock 08-11 STI - 190-200whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
350-360whp - 118-120mph traps
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 12-29-2011, 04:57 AM   #2
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Nice graph. And jeeez, Ed going crazy crazy with the posting, lol. I have to start throwing some cars up again!
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 12-29-2011, 11:52 AM   #3
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
What'd it pick up from the header and catback?
Allowed more timing and asked for less boost?
Zee Biker is offline   Reply With Quote
Old 12-29-2011, 12:27 PM   #4
Hardrvin
Member#: 63647
05 FXT
12.5 @ 109
Any chance to overlay before and after?
Hardrvin is offline   Reply With Quote
Old 12-29-2011, 05:16 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I believe it was at about 340whp/390ft-lbs last time around. The car would not make any more power above about 22psi and would not take timing up top. I think the main issue was the catback was creating a lot of back pressure.
-- Ed
Old 12-29-2011, 06:19 PM   #6
strange_magic
Member#: 259257
What was the old restrictive cat back, stock?
strange_magic is offline   Reply With Quote
Old 12-29-2011, 06:40 PM   #7
Exec809657
Member#: 59050
kbiz 30r E85 STI
Phatbotti tuned
what were the idc's on this car w 1300's compared to his friends vf39 w 850's? Curious to what e85 was asking for fuel wise for these 350-376whp cars
Exec809657 is offline   Reply With Quote
Old 12-29-2011, 07:36 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
SPT
-- Ed
Old 12-29-2011, 07:37 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I believe we were hitting about 80% on the 1300's and about 90% on the 850's. Remember these are also different power levels.
Thanks
-- Ed
Old 12-29-2011, 10:39 PM   #10
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
what dyno do you have. that sheet looks like a dynocom sheet.
NW2TONE is offline   Reply With Quote
Old 12-29-2011, 11:19 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep. It's a Dynocom DC Tuner chassis dyno. We run a .85 correction factor to make it read like my old road dyno software and the lower reading mustang dynos.
Thanks
-- Ed
Old 12-29-2011, 11:50 PM   #12
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Looks like a great street build and lots of fun....
jdpsearcher is offline   Reply With Quote
Old 12-30-2011, 12:43 AM   #13
NW2TONE
Member#: 212509
your **** go faster
Thanks
-- Ed
what was the uncorrected power?
Old 12-30-2011, 02:38 AM   #14
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
376/.85 = 442whp
-- Ed
Old 12-30-2011, 11:12 AM   #15
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
nicely done
PerformanceAutoSolutions is offline   Reply With Quote
Old 12-30-2011, 09:35 PM   #16
2fst4chp
Member#: 274047
the exhaust set up i had was a turboXS steath with the rear section from a 3" spt exhaust cut and welded to fit. A friend gave me the rear section of his g200 and once again i cut that to fit the turboXS and it worked wonders as u can see.
original numbers were 346whp and 399wtq
2fst4chp is offline   Reply With Quote
Old 12-30-2011, 09:37 PM   #17
2fst4chp
Member#: 274047
id like to see this too!
Old 12-30-2011, 10:17 PM   #18
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
376/.85 = 442whp
-- Ed
Any chance that either you or your friend will be headed to the track? I'd really love to see what a 442WHP HTA68 will do! Or a 400WHP+ VF! Anything near or above 120mph traps on these turbo's would be very impressive!
xluben is offline   Reply With Quote
Old 12-30-2011, 11:53 PM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That's exactly why I use the .85 CF. Without the numbers are through the roof.
I'd expect the 350whp car to trap around 115 and the 375whp around 118-119.
-- Ed
Old 12-31-2011, 02:28 AM   #20
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
I'm glad you mentioned that, as I'm very curious to see his 2nd attempt at the track as well: previous visit to sac raceway the car would not go any faster than [email protected] no matter what. That was on the 340/390 tune.
Hopefully the perrin header, better exhaust, and re-tune will gain a full second and about 10mph more trap
VladiWrX is offline   Reply With Quote
Old 12-31-2011, 02:39 AM   #21
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I believe he managed to trap 114mph on the previous setup.
-- Ed
Old 12-31-2011, 03:15 AM   #22
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Nice graph! going to send my JDM heads to you guys soon!
YZ86 is offline   Reply With Quote
Old 12-31-2011, 09:27 AM   #23
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
-- Ed
That makes sense. I was just going by the info in the original post. It makes it seem like the 350WHP car should do 118mph and the 375WHP car should do 122mph or so.
Thanks
-- Ed
Old 12-31-2011, 12:04 PM   #24
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Under perfect conditions and a very good driver it's possible and has been done by some of my customers. But you can't expect everyone to do it . I had a customer with an 05 STI trap 117 at 350whp and an 07 WRX go 121mph with 350whp.
-- Ed
Old 12-31-2011, 12:06 PM   #25
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
Ed - can you overlay this graph with the vf39 e85 car you just did as a comparo?
BONFIRE074 is offline   Reply With Quote
EQ - 2007 STI, Blouch DOM 3XTR, E85 - 420whp at only 20psi... more to come! Equilibrium Tuning Proven Power Bragging 73 11-18-2014 12:27 PM
EQ - 2005 STI Simple Setup on E85 - 347whp/423ft-lbs! Equilibrium Tuning Proven Power Bragging 20 03-05-2012 10:28 PM
Cobb Tuned - 07 STi LTD + Built engine + 20G + E85 S2O4 Proven Power Bragging 9 07-17-2011 12:24 AM
EQ: 2005 STI, EQ Built Block, VF39, E85 - 341whp/420ft-lbs! Equilibrium Tuning Proven Power Bragging 50 12-18-2010 11:20 PM
EQ - 06 STI, EQ FMIC, EQ EL Headers, ATP GT3076 - 343whp/345ft-lbs w/ in car VIDEO! Equilibrium Tuning Proven Power Bragging 34 11-05-2010 10:41 PM
