Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-29-2011, 06:49 AM   #1
THB07STI
Member#: 298651
2007 impreza sti
gray
Default no heat
jus drove to work and when i turned up the heat it stayed on for a while but in 10-15 min jus air was blowing when i had the climate set all the way to heat
THB07STI is offline   Reply With Quote
Old 12-29-2011, 09:04 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Most likely causes-
-Low coolant level (check both the reservoir and radiator with engine cold), if low fill to proper level and look for leaks
-Thermostat sticking open
Old 12-29-2011, 10:16 AM   #3
c10seth
Member#: 258526
2014 WRX Limited
Originally Posted by Mulder View Post
Most likely causes-
+1
Seth
c10seth is offline   Reply With Quote
So we have no heat... Any temporary heating solutions better than Kero heaters? AcquaCow Off-Topic 104 02-16-2010 07:19 PM
no heat shields six1five Normally Aspirated Powertrain 3 01-16-2004 01:32 AM
Heater - no heat impRSa Electrical & Lighting 5 10-03-2003 02:14 PM
NO HEAT AT WORK: grounds for leaving early? touch New England Impreza Club Forum -- NESIC 29 12-04-2002 12:26 AM
No heat at idle, only when moving, and long warm up period? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-01-2002 01:01 PM
