Old 12-29-2011, 05:16 PM   #1
Synx
Member#: 43712
60's B-52H
03 WRX WRB
Unhappy Timing Belt Cam Sprocket Question
I am in the process of replacing the timing belt on my EJ20. When i removed the tensioner both driver side sprocket rotated/shifted clock wise (to the right) from the videos and threads i've read i would have expected the top to rotate left and the bottom to rotate right.
I know i can only move the driver side upper sprocket clockwise, but that means i will have to make a near full rotation to get it back in alignment.
Any ideas?
Synx is offline   Reply With Quote
Old 12-29-2011, 06:18 PM   #2
subi400
Member#: 216984
1996 Impreza outback
Green
As long as the pistons are off deck it doesn't matter. But if you have to rotate the sprocket all the way around, then it is fine.
subi400 is offline   Reply With Quote
Old 12-30-2011, 07:27 PM   #3
DumbstixLars
Member#: 205942
2003 WRX
2007 2.5i Wagon
This just happened to me a few minutes ago. Wasn't expecting that to happen.
DumbstixLars is offline   Reply With Quote
Old 01-01-2012, 09:41 AM   #4
turbotom05
Member#: 243048
2005 wrx sti
Had the same issue with my 05 sti. They make a special tool, i think AMS does but it very expensive. So i just used an adjustable cam holder to line them back up.
edit: found tool- http://www.iwsti.com/forums/engine-p...cket-tool.html
turbotom05 is offline   Reply With Quote
Old 01-01-2012, 04:26 PM   #5
DumbstixLars
Member#: 205942
2003 WRX
2007 2.5i Wagon
I just rotated it clockwise real slowly. I didn't feel any major resistance. Just started the car up and it idles perfect like it always has.
timing belt cam gear slip alphagoose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-30-2010 09:10 AM
05 WRX Stock parts: starter, timing belt, cams, short throw, DP, exhaust, up pipe... Paulys05wrx Engine/Power/Exhaust 4 06-29-2010 11:36 AM
Changing timing belt, cam sprocket/valve questions lsnaple Service & Maintenance 5 12-22-2007 02:42 PM
EJ20 timing belt/cam cover Really_Soaked Private 'Wanted' Classifieds 0 07-21-2005 03:03 PM
Anyone Have DOHC timing belt cam tools? yebokmj New England Impreza Club Forum -- NESIC 3 01-17-2003 05:58 PM
