Old 12-29-2011, 08:24 PM   #1
maxx686
Member#: 287807
2011 WRX
Default 2011 wrx Ap stage 1 aem 91 oct CA
I just put in the aem cai and the car seems to have lost power and low end torque. Im running the ap stage 1 aem normal boost level but only reaching 15.2 psi on a hard pull. I put in the hwg map and then i was boosting at 17 psi. With the hwg it felt faster obviously but the low end was still not there and i don't want to over boost. I know there is a +/- 0.8 psi but when i was running the stage 1 map with the stock car it would hit perfect 15 psi every time and the car felt way better. What i was wondering is the car sucking to much air in and having a hard time pushing it out, with the limited stock turbo back exhaust system therefore get a higher flowing system and run stage 2 or should i just get the car tuned? any suggestions would be help full thanks!
Sorry for my english
maxx
maxx686 is offline   Reply With Quote
Old 12-30-2011, 10:08 AM   #2
Cobb Tuning
Member#: 4803
maxx
Hi Maxx,
Whenever you reflash a new map, you reset all the learned parameters of the engine control unit (ECU). This can sometimes make the car feel a little soft for a period of time until the functions are "re-learned". Give it about a week and see if it still feels off. Also, make sure that you flashed the AEM map via the reflash and not the realtime function.
Stage 2 would be the next step as far as mods and you will see some noticeable gains from it. You will also generally see gains with a custom dyno tune, regardless of stage 1 or stage 2. This is because the map would be customized to your exact car (car-to-car variation and different local gas quality can make each car unique in how it responds to the tune). But, a custom tune is not a requirement to run the stage 1/2 map with AEM intake.
Bill
Old 01-02-2012, 05:36 PM   #3
maxx686
Member#: 287807
2011 WRX
Thanks bill for the info!
Low Rpm/Low speed Hiccup/Hesitation. 2011 WRX AP Stage 1 darren94 AccessPort 3 08-22-2011 09:46 PM
Gas mileage question for 2011 with AP stage 1 jrose29 AccessPort 16 06-08-2011 09:03 PM
Question about AP Stage 1 AEM Tune team23jordan AccessPort 11 04-25-2011 12:52 PM
Ap Log for 2011 WRX - Stage 1, 93 - CYLINDER KNOCK - PLEASE HELP.......... thegarius AccessPort 3 04-09-2011 08:03 PM
2011 WRX Cobb Stage 1 datalog Jaker Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-04-2011 05:35 PM
