Old 12-30-2011, 12:34 AM   #1
itwillboost
Member#: 289693
2013 BRZ
Sterling Silver Met.
Default No crank, no start
My car will not start, and it will not crank. This all happened a day after my clutch master cylinder went bad. I redid the lines and the master and now my clutch has pressure again, but now it won't start. The battery is fine and the sensors are all plugged in. I checked the stock alarm setup and it's not disabling the car from starting. I want to check the clutch safety switch if it blew, other than that I am at a lost. Any ideas ?
itwillboost is offline   Reply With Quote
Old 12-30-2011, 02:36 AM   #2
itwillboost
Member#: 289693
2013 BRZ
Anyone ? I checked the neutral safety and it's working fine, so I am slightly at a loss. Starter has power but is not cranking meaning something has to be preventing it, the fuel pump also isn't turning but the ecu appears fine and the alarm isn't enabled.
Old 12-30-2011, 02:41 AM   #3
daseca07
Member#: 277630
2007 WRX TR
power going to starter and starter not doing anything? sounds like you have a bad starter
daseca07 is offline   Reply With Quote
Old 12-30-2011, 03:35 AM   #4
itwillboost
Member#: 289693
2013 BRZ
That would make sense, but it's not even trying to turn over. Almost like something is stopping it, which is why I thought the neutral safety switch. I don't know if this car has any other imobiliziers than the alarm system.
No Cranking, car will start when push started. Luckyduck919 Normally Aspirated Powertrain 3 11-28-2010 03:21 AM
No Crank no start mmkay? Trogasarus Electrical & Lighting 3 11-20-2009 12:45 AM
can anyone help with this problem?? No crank, No fire. Not all dash lights ncarn8 Electrical & Lighting 4 11-12-2009 07:21 PM
Crank/no start - no spark - ideas? PeteDucati Built Motor Discussion 12 04-29-2007 05:29 PM
XT6 (92), Does anyone have a illustration of the timing belt(s) Crank No Start. munkis Normally Aspirated Powertrain 0 10-21-2002 12:25 AM
