Old 12-30-2011, 04:59 PM   #1
gf8love
Member#: 300591
Default speed sensor mechanical to electronic
Hey guys did the swap ver 4 sti with electronic speed sensor in to my 97 impreza with a mechanical speed sensor setup. The problem I am having is because the ecu is not seeing the speed sensor the car runs like crap. So in order to swap it all over to electronic so it will run right what needs to be done? I already have the electronic speed sensor and the wiring but am not sure how to integrate it in to the writing harness to work.
gf8love is offline   Reply With Quote
Old 12-30-2011, 05:31 PM   #2
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
What ECU are you using this with? Is it a engine and trans swap, or just the engine using the 97 trans?
Dominator is offline   Reply With Quote
Old 12-30-2011, 06:13 PM   #3
gf8love
Member#: 300591
It's an engine and trans swap using a matching ver 4 sti ecu
Old 12-30-2011, 09:32 PM   #4
suberdave
Member#: 101865
88 GL-10 STi
pull the speed sensor out of the trans and put your cable in it. (you may have already done this) then look at your wiring diagram for your car, not the new engine, and you will find a vss wire coming from the IP cluster. tap into this and run it to the V4 ECU where it wants a VSS input.
i have done this many times, it is not a problem.
post what year and model the car is and i can help with where you will find the wire you need.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-30-2011, 10:12 PM   #5
gf8love
Member#: 300591
The car is a 97 impreza l wagon
Old 01-03-2012, 08:38 PM   #6
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
-=Suberdave=-
Tthis.
if you did the wiring merge correctly on the chassis, then the wire from the cluster should already be going to the ECU, but since the cluster isnt getting signal, thats why its not working. just swap your cable speed sensor into the transmission (they are swappable with the electronic speed sensors)
elislider is offline   Reply With Quote
Old 01-04-2012, 07:14 PM   #7
gf8love
Member#: 300591
I will have to get the cable all swapped up and ill see what happens. I did not do the wiring a local subaru swapper did the merge for me so we will see
Old 01-04-2012, 07:15 PM   #8
gf8love
Member#: 300591
Will the mechanical speed sensor work with the transmission that was setup for the electronic?
Old 01-05-2012, 01:28 AM   #9
suberdave
Member#: 101865
88 GL-10 STi
yeah am currently running a 1988 GL cable in a 2003 JDM STI Trans. i have also installed 3 V5-6 EJ207s into 93-95 body cars, pulled the VSS out of the trans and installed the cable in its place. all are working just fine.
-=Suberdave=-
Old 01-09-2012, 05:25 PM   #10
chochocho
Member#: 61348
i have a 1991 legacy ss that will be running a link ecu and sti v8 motor and v7 6 speed.
i am having the same issue as the 91 legacy reads mechanically but the newer stuff (6 speed) all run electrically. the link ecu would need to see speed for gear dependent mapping.
any assistance would be helpful. thanks.
yat
chochocho is offline   Reply With Quote
Mechanical to electronic speed cable? SubaruImpreza_power Electrical & Lighting 2 06-02-2008 04:19 PM
WTB: electronic vehicle speed sensor from tranny Scoobyslack1 Private 'Wanted' Classifieds 1 03-06-2008 06:57 PM
vehicle speed sensor, how to change? johnkaldar Service & Maintenance 5 08-28-2006 06:40 PM
mechanical vehicle speed sensor with the 6MT not8player Transmission (AT/MT) & Driveline 0 07-31-2006 04:55 PM
Can a MY05 Legacy GT tranny be fitted for mechanical Vehicle Speed Sensor? yebokmj Transmission (AT/MT) & Driveline 2 02-10-2006 10:41 PM
