Old 12-30-2011, 07:19 PM   #1
It_wasntt_me
Member#: 300955
2004 WRX
Java Black Pearl
Default V1 AP! Need help ASAP!
What the heck are these for???
Thanks for the help!
It_wasntt_me is offline   Reply With Quote
Old 12-30-2011, 07:48 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
They are the initializer? plugs you need to use for flashing a base map onto the ECU, you only need to use 1 at a time but I don't remember what colour for what year... You also need to connect some wires under the dash but it's been so long I forgot those colours too... You need to find & read the instruction manual or you can easily F'Up the ECU...
wrxdrvr is offline   Reply With Quote
Old 12-30-2011, 07:50 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
blue for 2002 wrx
white for 2003-2005 wrx
it's under the dash with the green connectors
you can plug it in and forget once plugged
Nuke209 is offline   Reply With Quote
Old 12-30-2011, 07:56 PM   #4
It_wasntt_me
Member#: 300955
2004 WRX
Java Black Pearl
Originally Posted by Nuke209
blue for 2002 wrx
Where exactly do they plug in?
Old 12-30-2011, 10:00 PM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Originally Posted by Nuke209 View Post
blue for 2002 wrx
I don't believe you can plug & forget, you must un-plug and disconnect the test mode connector wires once you are done flashing the ECU...
Old 12-31-2011, 12:54 AM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
You can plug and forget these jumper blocks
But cannot for the greens
Old 12-31-2011, 10:47 AM   #7
Cobb Tuning
Member#: 4803
Hi there. Those are the initialization jumpers for 02-05 WRX. Blue is for 02 WRX and white is for 03-05 WRX. You can leave them permanently attached to the car. You will also need to connect the green diagnostic connectors when you install the AP (or when you reflash a map). Those will need to be disconnected after you are done. You can find more details about this process in our AP user manual (although you have a v1 aP, how to install the jumper and connect the test mode connectors is the same):
http://accessecu.com/support/docs/ma...UserManual.pdf
Bill
need help asap questions about cobb ap njhxc27 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-05-2010 12:13 AM
Trouble Uninstalling AP - need help ASAP! rs2.5-3.0 AccessPort 8 03-31-2008 01:15 PM
need help ASAP with ap map!! Matth3w AccessPort 20 06-23-2007 05:35 PM
NEED HELP ASAP w/Cobb AP SilverBugEye03 General Community 11 12-29-2005 06:49 PM
NEED HELP ASAP w/Cobb AP in Atlanta SilverBugEye03 South East Region Forum 3 12-28-2005 03:57 PM
