Old 02-24-2016, 07:49 PM   #1
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
Default Oil squirters + stroked EJ20 is a no-go
In a stroked EJ20 (possibly stroked EJ22's also) the pistons contact OEM oil squirters approximately 5mm before reaching BDC.
Thoughts on machining a relief into my pistons or 5-6mm off the top of the squirter? If all else fails, they'll get plugged
JDM EJ20G - converted to #5 thrust bearing
EJ257 crank
EJ257 rods
Mahle PowerPak stroker pistons - 92.5mm, 8.0:1 CR
simer1228 is offline   Reply With Quote
Old 02-24-2016, 08:34 PM   #2
DisoDisp
Member#: 187648
2007 WRX
Notch the pistons or remove the squirters.
DisoDisp is offline   Reply With Quote
Old 02-25-2016, 02:58 PM   #3
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Wierd....I stroked an ej22t and it was fine with squirters.
maciek is offline   Reply With Quote
Old 02-25-2016, 03:17 PM   #4
rtv900
Member#: 428511
2016 STI
yeah
a minimal notch out on that web would do it without hardly sacrificing any strength.
You could even do it with a carbide burr by hand if you don't have reasonable access to equipment.
Hard to know how the squirters will be affected depending what the nozzle is like inside if you cut that down. It might mess up the squirt.
Old 02-25-2016, 11:31 PM   #5
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Try a different piston. I've stroked a few with JE pistons and never had an issue contacting the squiter.
fastblueufo is offline   Reply With Quote
Old 02-26-2016, 12:44 PM   #6
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Is it really worth keeping them? Id just plug them im sure it's fine but notching the Pistons would worry me.
Old 02-27-2016, 07:00 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
An endurance race engine piston lives and dies by a good squirter arrangement...but we're not at that level.
If you have notched big ends on your rods, you don't NEED those squirters on a street or street and strip car.
I would however look at getting some JE's in there.
Old 03-08-2016, 12:50 AM   #8
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
I consulted with a few very reputable engine builders and also read the opinions of forum members, here and there. I decided to take advantage of having oil squirter's and milled a relief in the Mahle pistons.
If it's true that JE's clear squirters without modification I will certainly consider going that route if I ever cross this bridge again.
Old 03-10-2016, 05:30 PM   #9
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
Did you pressure test the squirters? I had to go through two sets to get one good set. You can also get new squirters from roger Clark motorsports in the UK. Make sure you use some red loctite in the threads.
monkeyposeur is offline   Reply With Quote
Old 03-11-2016, 12:46 AM   #10
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
They were cleaned and tested to make sure they weren't clogged. Definitely needed to be cleaned. Loctite was used although I didn't see any sign of loctite being used prior.
