Welcome to the North American Subaru Impreza Owners Club Tuesday November 24, 2009
Texas Impreza Club
Texas Impreza Club Forum sponsored by Gillman Subaru Houston
and Gillman Subaru San Antonio
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 08-12-2002, 06:29 PM   #1
Vigorous
Member#: 7087
2002 2.5RS
Default Help: Laptop Keyboard Repair
I think a sping in my laptop broke. The spacebar feels soft, and it doesnt work, g and h doesnt either.
How can I fix it? Or do I have to send it to the store? I called some area places, and they want TONS of money for it. Any computer repair i-club technicians?
Vigorous is offline   Reply With Quote
Old 08-12-2002, 06:30 PM   #2
jprutch
Member#: 11495
2002 Impreza WRX
Platinum Silver Metallic
what is the make and model of your laptop
jprutch is offline   Reply With Quote
Old 08-12-2002, 06:42 PM   #3
dazz1
Member#: 10363
5.9 Turbo Cummins
There are usally four clips and one spring on each keys.
Check and make sure the clips are not broken.
If needed, you can replace just the Keyboard.
dazz1 is offline   Reply With Quote
Old 08-12-2002, 06:48 PM   #4
Vigorous
Member#: 7087
2002 2.5RS
Its a Compaq Presario...looking for its model number right now. Its like 2 years old. Got it from an ex-compaq employee. So the model number isnt on it.
How much would a replacement keyboard cost?
Old 08-12-2002, 08:18 PM   #5
HellWagon
Member#: 16172
Yeah if you can find the model # I can order the part for you here at work (or at least find out what it costs).... they are a snap to put in.
undo a couple clips, a screw, and one ZIF socket cable.
HellWagon is offline   Reply With Quote
Old 08-12-2002, 09:51 PM   #6
Sam2
Member#: 15265
2002 WRX Wagon
WR Blue
Worth a try, hold the laptop open upside down, give it a good shake and palm back and forth across all they keys. You're working to dislodge whatever bit of dirt, paper, crumbs, etc, have lodged into the keyboard. Can also try a vacuum cleaner, being careful in case you've a keyboard with removable keycaps. Last resort is start keyboard disassembly from inside, they're quite tedious and hard to repair, but you might be lucky. Most usually, techs won't even try, component replacement is the usual way to fix.
Sam2 is offline   Reply With Quote
Old 09-14-2002, 07:56 AM   #7
Vigorous
Member#: 7087
2002 2.5RS
Was lazy, and just started using a keyboard.
The model is Compaq Presario 1800 series.
Can anyone help me out.
Old 09-14-2002, 02:41 PM   #8
pylorns
Member#: 12753
02 06' VW Passat
prob. cost 20-40 bucks are easy to change out.
pylorns is offline   Reply With Quote
Old 09-20-2002, 07:30 PM   #9
Vigorous
Member#: 7087
2002 2.5RS
Alright, I just bought the new keyboard.
I took out the old one, and I put the new one in, and stuck the ribbon back in. But its not working.
Do i just put the ribbon back in? or does it have a specific slot or something? or am i suppose to fold it in a certain way?
Help!
Old 09-20-2002, 07:43 PM   #10
HellWagon
Member#: 16172
make sure you press in the ZIFF tabs on the the sides of the socket for the cable.
Old 09-20-2002, 07:59 PM   #11
Vigorous
Member#: 7087
2002 2.5RS
ZIFF tabs??
Old 09-20-2002, 08:15 PM   #12
HellWagon
Member#: 16172
Zero Input Force. The whole idea is that since the cables are kink sensative you just move the two tabs out and slide the cable out. Or in reverse slide the cable in and push the two tabs in otherwise there is no friction holding the cable in.
Anyway this is how it is in all the compaq armadas and the Evo series.
Old 09-20-2002, 09:51 PM   #13
Vigorous
Member#: 7087
2002 2.5RS
Found the manual online. I took out the keyboard the wrong way. I just pull out the keyboard cable without using the ZIF tabs. Not a good thing eh?
Now, theres this ONE tiny screw that is pissing me off. Its star shaped, but its sooooo small. Heading to Ace Hardware for the tool. ARGH! One stinkin screw.
Old 09-21-2002, 06:20 AM   #14
Kartoffel
Member#: 12976
grocery getter
EDIT: ahh, you got a keyboard already. Good deal.
Call Compaq and ask if you don't have a replacement yet. There's a compaq factory store on the north side of town right next to Fry's.
I replaced the keyboard on my iBook once. Apple quoted me $75 and UPS'ed me a new one, but they forgot to bill me. It was kinda weird, but I'm not complainin'
Kartoffel is offline   Reply With Quote
Old 09-21-2002, 08:59 AM   #15
HellWagon
Member#: 16172
That sounds quite Mac, they aren't very "organized"
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 05:04 PM.
