Old 12-31-2011, 11:09 PM   #1
98jdmwrx
Member#: 146962
Default need crank/cam calibration for v5 wrx (ej207)
this is needed for standalone set up.
98jdmwrx is offline   Reply With Quote
Old 01-01-2012, 03:05 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I don't know if this helps but it's the same as USDM 1989-1998 Legacy 2.2 SOHC and Impreza RS 2.5 DOHC.
Marnix is offline   Reply With Quote
Old 01-01-2012, 10:51 AM   #3
98jdmwrx
Member#: 146962
Many thanks, I'll try it.
Old 01-01-2012, 06:58 PM   #4
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Subaru G10
Dutch Scooby lover is offline   Reply With Quote
Old 01-02-2012, 11:28 AM   #5
98jdmwrx
Member#: 146962
not getting any luck. i would have assumed someone would have this info.
Old 01-02-2012, 02:05 PM   #6
Gmilos
Member#: 167516
2004 RS 20k <3 H8RS
What sa are you using
Gmilos is offline   Reply With Quote
Old 01-03-2012, 11:57 AM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
What EM are you using?
Old 01-03-2012, 11:08 PM   #8
98jdmwrx
Member#: 146962
AEM EMS4, if i can get it to work.
Old 01-04-2012, 04:41 AM   #9
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The crank and cam trigger signals are the same for all engines up to 2000. After that the crank and cam wheel pickups were changed.
Old 01-04-2012, 05:40 AM   #10
eg33GC
Member#: 206851
56 Belair
Pro Street
You can confirm a K cam gear will work using a G crank sprocket and a G ecu?
eg33GC is offline   Reply With Quote
Old 01-04-2012, 11:03 AM   #11
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'm not familiar with the EMS4 trigger options. If there is an option for WRX ver. 1-6 try that.
Old 01-04-2012, 11:26 PM   #12
beaviscih
Member#: 123362
'93 Crapcan EJ25D
FTW
Is ECU set to sequential, simi-sequential or batch fire? Someone correct me if I'm wrong but it should be set to sequential For direct fire coils IIRC.
beaviscih is offline   Reply With Quote
Old 01-05-2012, 03:55 AM   #13
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Yes the EJ20K and EJ20G crank sprockets are the same, and the cam sprockets can be interchanged aswell (metal EJ20G sprockets and later EJ20G and EJ20K plastic resin sprockets have the same cam gear signals).
Old 01-06-2012, 11:58 AM   #14
98jdmwrx
Member#: 146962
does anyone have aem tuner software that they can possibly build a map or send me theres?
Old 01-06-2012, 12:24 PM   #15
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
AEM isn't really common for Subaru's especially early ones. It's more of a Honda scene thing.
Old 01-06-2012, 12:30 PM   #16
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Does this help?
Old 01-06-2012, 12:48 PM   #17
tpsretard
Member#: 215585
94 MY94 STI
Dark Blue
tpsretard is offline   Reply With Quote
WTB: manual crank window conversion for 02 wrx long5152 SCIC Private Classifieds 0 04-22-2009 01:48 AM
Crank Pulley (stock) for 02'-05' WRX Carlito2002WGN Engine/Power/Exhaust 0 07-11-2007 09:49 PM
Custom cam gears for USDM WRX heads running on a 7 tooth cam gear. Brydon Subaru Conversions 2 05-01-2007 09:19 PM
Wtb Timing Covers And Cam Gears For 02 Wrx Brabus Private 'Wanted' Classifieds 10 10-17-2005 10:57 PM
WTB: Crank pulley bolt for 02-03 WRX Pacobeagle Private 'Wanted' Classifieds 1 08-07-2004 05:15 PM
