Alaskan Impreza Club
Old 01-01-2012, 01:33 AM   #1
Edmo8
Member#: 283295
Default Misfireing
My 06 Subaru wrx is misfiring in 1,2,3 Cylinders i have no idea what's going but there is some burning oil coming from the bottom of the turbo. Need some help and help would be good. Could it be a bad turbo that's causing the problems?
Edmo8 is offline   Reply With Quote
Old 01-01-2012, 10:41 AM   #2
edo2000
Member#: 68709
2012 WRX
red
If your turbo oil seal is bad, leaking oil into the intake, that could definitely cause the problem. I would replace/fix the turbo, change out the plugs and see if the problem is solved. Sounds like the turbo issue needs to be fixed anyway. One way to check for oil in the intake is to remove the intercooler and check for excess amounts of oil in the Y pipe and throttle body (a very small amount is normal). Good luck.
edo2000 is offline   Reply With Quote
Old 01-01-2012, 10:59 AM   #3
Edmo8
Member#: 283295
Thanks for help
misfires misfire misfires galore! bugeyerex02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-12-2010 05:46 PM
misfire...misfire...misfire... BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 05-28-2009 02:18 AM
first cylinder 1 misfire, after plugs, 1,3,4 misfire! DieselClown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 08-26-2008 02:59 PM
Multiple Misfire and Misfire Cylinder 3 Anub1s Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-19-2005 12:40 PM
misfires,misfires,misfires eatsrice Engine Management & Tuning 6 08-04-2004 08:47 AM
