Old 01-01-2012, 04:18 PM   #1
Slurpyy
Member#: 213176
2003 WRX
yellow
Default Yellow stuff in oil cap
It took me awhile to break loose my oil cap on my 08 wrx with 47k i change my oil myself every 3k or so, i ised royal purple awhile back once, then delo 400e, now im on shell rotella t6.
Last two times ive changed my oil, oil cap is stuck i gotta break it loose, then theres a yellowish brownish sticky substance around the filler neck threads and in the cap itself threads not alot but i have no idea what it is i smelled it and my cap smells a little like gas im stage 2 and my logs are fine.
Slurpyy is offline   Reply With Quote
Old 01-01-2012, 10:08 PM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Does it look like this?:
(mustard)
If so, my dad's Audi had the same thing. I started a thread in OT and the general consensus was 'normal'. Seems to be a condensation thing, caused by short trips.
http://forums.nasioc.com/forums/show....php?t=2137644
z is offline   Reply With Quote
Old 01-01-2012, 11:31 PM   #3
Slurpyy
Member#: 213176
2003 WRX
yellow
Yes it does only not as much, but ya i seen a little condensation on inner most part of the oil cap, just a little but i wipe my cap and filler neck to try and clean it.
Old 01-01-2012, 11:32 PM   #4
Slurpyy
Member#: 213176
2003 WRX
yellow
Ya read your thread, its also only started since its winter now, in oregon its like 25-45 degrees pending
Old 01-01-2012, 11:40 PM   #5
scooby24
Member#: 56414
2004 Forester XT 5MT
ditto, ditto and ditto.
'11 STI, 9500 miles, T6, oil level full, normal blow by, filler cap was really hard to break loose the other day and there was a slight amount of the same goop. Lots of short trips lately, I'd very easily suspect condensation.
scooby24 is offline   Reply With Quote
Old 01-01-2012, 11:45 PM   #6
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
Short trips = not getting your engine hot enough to burn off moisture = mustard
MY EJ20TTTTTT is offline   Reply With Quote
Old 01-01-2012, 11:46 PM   #7
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
Mazda RX8's are terrible at this...
Old 01-02-2012, 09:05 AM   #8
bluesubie
Member#: 767
04 FXT
Old 01-02-2012, 10:09 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
check the pcv valve
Yellow Sludge under Oil Cap? 2010 Forester XT 15k mi Sybarite Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-29-2011 03:41 PM
FS : Prodrive oil cap, ARC oil cap and radiator cap PRODRIVEN Engine/Power/Exhaust 8 03-23-2011 08:43 AM
Front 02 Sensor,Rear 02 Sensor,MAF Sensor,Blox Shift Knob,SPT Oil Cap, bunch of stuff TopEndPull Engine/Power/Exhaust 11 08-14-2009 05:48 PM
somebody blew my motor poured rocks in my oil cap ryanpietro Off-Topic 124 04-13-2006 02:27 PM
Found yellow stuff after opening rad. cap shogunate83 Service & Maintenance 5 12-02-2002 05:36 PM
