Old 12-01-2011, 10:02 PM   #1
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
Default Congratulations Carl & Ziptie Rally Team, Nasioc's Top Scoob 026 DIRT !!
My name is Carl Siegler. I've been racing Subaru's for 3 seasons in the Rally America Central Regional Championship. A group of local Subaru enthusiasts make up my team, Ziptie Rally (www.ziptierally.com http://www.facebook.com/ziptie.rally). My codriver is Dave Goodman. My first car was a 2004 STI that was first run as an Open Light car for one season and then converted up to Open class for the following two seasons.
This year at RallyMN I crashed the 2004 hard at 90mph and decided to build a new chassis. A 1996 Impreza coupe was purchased immediately after getting home from the rally. Over the next 5 months the team and I put over 1000 hours into building it from the ground up. We did a lot of work including fully stitch welding the chassis, building a custom wiring harness, powder coating the entire shell and cage, and fabricating a lot of unique parts.
I've only run LSPR so far in this car (DNF'd after the DBW system failed) so not many action shots yet.
Mod list
Chassis
• 1996 Impreza coupe
• Fully seam welded
• Lightened
• FIA spec rollcage
• Powdercoated white
Engine
• 2008 EJ257 shortblock
• 9.8:1 Manley pistons
• Rotated intake manifold
• Front mount intercooler
• Walbro 255lph fuel pump
• AN fuel lines
• Fobia equal length exhaust manifold / rotated up-pipe
• GT2871R w/ GEM 34mm restrictor
• ATP turbo heatshield
• P&L turbo oil lines
• KSTech intake manifold phenolic spacers
• GEMS N14 ecu
• Group N engine mounts
• Mishimoto radiator
• SPAL 13” radiator fans
• Custom 3” exhaust w/ Random Technologies 3” race cat
Drivetrain
• 2004 STi 6spd
• Carbonetic 1.5 way front LSD
• Carbonetic 2 way rear LSD
• Exedy stage 2 clutch
• ACT Prolite flywheel
• Kartboy shifter bushings
• Group N transmission mount
• Turn In Concepts crossmember bushings
• GEMS DCCD controller
Suspension/Steering
• RS&SP 55-51 rally coilovers w/ open class solid tophats
• GEM front control arms
• TSSFAB trailing arms
• TSSFAB lateral arms
• TSSFAB tubular front crossmember
• TSSFAB tubular rear crossmember
• TSSFAB T-bar
• Whiteline steering rack bushings
• Braided stainless powersteering lines
Brakes/Wheels/Tires
• Group N 4/2 pot calipers
• DBA 4000 rotors
• Hawk DTC30 pads
• Techna Fit stainless brake lines
• Custom brake hardlines (ABS delete)
• GEM brake booster delete
• Compbrake hydraulic handbrake
• Braid 15” gravel wheels
• Teamdynamics 15” gravel wheels
• DMACK Grippa gravel tires
• Yokohama A034 snow tires
Interior
• Sparco Pro ADV seats
• Schroth 6 point harnesses
• Flocked GD STi dashboard
• GD STi gauge cluster
• Sparco helmet box
• Custom intercooler/washer sprayer reservoir
• Custom doorcards
• Summit heater/blower unit
• Terratrip 303+ rally computer
• Pacific Customs battery box
• Optima redtop battery
• Terratrip map lights
• OMP codriver footrest
• Lowrance HDS-5M GPS
• Peltor FMT-120 intercom
Exterior
• AIT Bmagic widebody kit
• Lexan quarter windows
• Lexan side windows
• GD STi wing
• Roof-scoop/vent
• Aspen white paint
• JDM aluminum hood
• RS front end
• PIAA dual lightpods
Misc.
• Custom wiring harness
• ” thick aluminum front skidplate
• Steel rear diff skidplate
• HDPE floor and rear suspension guards
• Custom mudflaps, fender and wheel well guards
full build thread for more info
http://www.rs25.com/forums/f145/t158...0-31-11-a.html
Ziptie Rally is sponsored by:
Carbonetic
http://www.carbonetic.net/
Gearhead Graphics
http://www.gearheadgraphics.com/
Graham Evans Motors
whiskersusa (at) hotmail.com
Import Image Racing
http://www.importimageracing.com/
Morries Minnetonka Subaru
http://www.morries.subaru.com/index.htm
RS Motors
http://www.rs-motorsinc.com/
St. Paul Media
http://www.stpaulmedia.com/
Team Powder (powder coating)
TSS Fab
http://tssfab.us/
-Carl
RA #171
carl s. is offline   Reply With Quote
Old 12-23-2011, 08:03 PM   #2
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
my car started out looking like this
after stripping the old race car
we began work on the new one
(we don't have a shop or a fancy garage to work out of. This is all straight up diy, home built blood, sweat, and tears)
we also built the cage in my garage (last time I paid a shop to do it)
then we took it to one of my crew's dad's shop for powder coating
I did a full on custom wiring harness. If you've ever worked on a bulkhead harness you can see how little wiring this car has
AN fuel lines
TSS FAB rear subframe and links
Old 12-23-2011, 08:03 PM   #3
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
bumper beam we made to hold the intercooler
Tubes galore! TSS subframe and Fobia equal length header
widebody installed and back from paint
the rear quarter windows are removable via slide latches
door cards are simple
underbody protection
RSSP struts
lexan front windows
and that's just a brief overview of what's in the car
Old 12-31-2011, 12:38 AM   #4
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
thanks!
next event for us is sno*drift!
oh and some pics
Old 01-01-2012, 09:36 PM   #5
Ferg
built to spill
Member#: 14145
02 WRX BLOD
76 C30 Dually
Well done Carl! Hopefully winning our first ever Top Scoob for Race Cars is just the start of a great 2012 season.
Good luck at Snow Drift!
Ferg is offline   Reply With Quote
Old 01-01-2012, 09:55 PM   #6
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
congrates man...
old_duwel is offline   Reply With Quote
Old 01-01-2012, 10:24 PM   #7
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
Let's hope so! (2011 was a pretty bad season for our team between crashing and blowing the motor and having to build this new car up)
70+ entry list for sno*drift, should be pretty awesome
Also, thanks to Whiteout Rally and Aaron for entering their rally cars - hope to see you guys sometime this season!
Old 01-02-2012, 02:12 AM   #8
FlannelWagon
Member#: 209998
2007 Fxt
Urban Grey Metallic
Thank you Carl, Julian and I at Whiteout Rally, really enjoyed the excitement with the Top scoob on dirt contest. we are very happy to say congrats to you and your team at Ziptie Rally. It was a very close running the whole way.
we are just happy we made the final! Hopefully we will see you on the dirt sometime this 2012 season. Julian and I have a lot of work to do to earn the coefficients for Open call in Rally America.
FlannelWagon is offline   Reply With Quote
Old 01-03-2012, 02:07 PM   #9
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Nice build ......Good luck at snow Drift
MARKSTIV8 is offline   Reply With Quote
Old 01-03-2012, 07:09 PM   #10
Layvon
Member#: 195711
STi 04/05/06/07
Good Build Carl. I'm disappointed in no Monkey See you again at Sno*Drift
Layvon is offline   Reply With Quote
Old 01-04-2012, 04:37 PM   #11
Pidgeon
Member#: 284247
2002 Wrx
MBP!
rally
Pidgeon is offline   Reply With Quote
Old 01-05-2012, 11:29 AM   #12
I Like It Sideways
Member#: 97707
'01 BRP GC6
'06 SGM WRX,'91 Legacy SS
Congrats Carl and team! Nice work.
See you in the Sno*!
I Like It Sideways is offline   Reply With Quote
Old 01-06-2012, 12:08 AM   #13
minx1225
Member#: 89034
2015 WRX Limited
CWP
Congrats. Sweet ride and awesome video clip.
minx1225 is online now   Reply With Quote
Old 01-06-2012, 01:13 AM   #14
KennyS
Member#: 296586
2002 Impreza Wrx
Custom, Who knows
i didnt see you guys at gorman
very nice glad to see another rally car on here
if you race at some other CRS rallys I'll see you there
KennyS is offline   Reply With Quote
Old 01-08-2012, 12:58 AM   #15
optikul81
Member#: 248698
2005 Baja Turbo
When I saw ziptie rally I thought this car was yours.
of course this is what it looked like at the end of the stage
optikul81 is offline   Reply With Quote
Old 01-09-2012, 01:00 AM   #16
B-tons
Member#: 144352
2006 Impreza Wrx TR
Grey
Default sno drift!
This will be my 7th year attending the Sno Drift rally! Looking forward to seeing ya run. Thanks for the cool pics of how your car cam to life! Good luck!
John--
B-tons is offline   Reply With Quote
Old 01-09-2012, 07:40 AM   #17
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
oh no, we use way more zipties than that in a far less professional manner
as one example
Old 01-09-2012, 11:34 AM   #18
nickmanxp
Member#: 262811
Nice build can't wait to see you guys at Sno Drift
nickmanxp is offline   Reply With Quote
Old 01-09-2012, 04:39 PM   #19
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
Hehe yeah I need to use WAY WAY more zipties than that in order to be on the same level as Ziptie Rally. I also need to rebuild the car...
biggreen96 is offline   Reply With Quote
Old 01-10-2012, 04:11 PM   #20
STI403
Member#: 132912
Awesome job Carl, Nice to see another member from the Minneapolis area make it to the Top Scoob!! Carl is a great competitor! Good luck this season!
STI403 is offline   Reply With Quote
Old 01-11-2012, 08:20 PM   #21
anonmassive
Member#: 158464
YER MOM
BLURPLE
Carl is my neighbor.... congrats homie
anonmassive is offline   Reply With Quote
Old 01-11-2012, 10:02 PM   #22
codytalontsi
Member#: 218507
Awesome work! Always cool to see how the project progressed from something good to something great!
codytalontsi is offline   Reply With Quote
Old 01-12-2012, 09:43 PM   #23
B03scooby
Member#: 102929
2003 07STi,03,07 STi
SWP/ WRB/UGM#239
congrats
B03scooby is offline   Reply With Quote
Old 01-15-2012, 01:28 AM   #24
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Awesome! Thats some cool stuff there.
Killer video too! It would be cool to meet you guys sometime.
TDagen is offline   Reply With Quote
Old 01-15-2012, 12:16 PM   #25
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
Just got done with a little test and tune for sno*drift
Congratulations Turn In Concepts, Nasioc's Top Scoob 026 TARMAC !! Turn in Concepts Member's Car Gallery 154 09-10-2013 09:46 PM
Congratulations to L-SCHLEGS and his 2008 STi, Nasioc's Top Scoob 014 L-SCHLEGS Member's Car Gallery 166 01-01-2013 09:22 AM
Vote in Top Scoob 026 RACE CARS ONLY! DIRT !! Ferg Member's Car Gallery 47 12-30-2011 09:52 PM
Top Scoob 026 - Tarmac & Dirt Edition! Dena North West Impreza Club Forum -- NWIC 25 12-26-2011 07:48 PM
Congratulations preacher#1 and his Fozz Invasion, Nasioc's Top Scoob 022 preacher#1 Member's Car Gallery 141 10-28-2011 12:22 AM
